<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Soft-Reboot not working]]></title><description><![CDATA[<p dir="auto">Hey,<br />
my VOXL is behaving strangely in that whenever I initiate a reboot from QGroundControl, regardless of connection type, the whole VOXL Flight just powers off (consumes 0.25A as seen on my power supply), disconnects and all LEDs turn off.<br />
Weirdly enough the LEDs on two external devices keep blinking.</p>
<p dir="auto">Same behaviour with all external devices detached.<br />
So I have to go and unplug/ replug the Quad <em>every time</em> I change a parameter that requires reboot... Any ideas?<br />
cheers</p>
]]></description><link>https://forum.modalai.com/topic/410/soft-reboot-not-working</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 23:53:36 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/410.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 21 Aug 2021 22:38:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Soft-Reboot not working on Tue, 24 Aug 2021 06:26:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/modaltb" aria-label="Profile: modaltb">@<bdi>modaltb</bdi></a> said in <a href="/post/1972">Soft-Reboot not working</a>:</p>
<blockquote>
<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/m4v3r" aria-label="Profile: m4v3r">@<bdi>m4v3r</bdi></a> ,</p>
<p dir="auto">If you have VOXL connected via ADB and issue a reboot command via QGC, do you lose the ADB connection?</p>
</blockquote>
<p dir="auto">Hi, yes if it's rebooted in ADB it's the same behavior.<br />
This particular VOXL did live through several crashes and stuff though (I am a test-pilot mainly afterall ... ;D) so it might just be busted.</p>
<p dir="auto">A different one, setup exactly the same, behaves as expected.<br />
Thanks for the insight though.</p>
]]></description><link>https://forum.modalai.com/post/1979</link><guid isPermaLink="true">https://forum.modalai.com/post/1979</guid><dc:creator><![CDATA[m4v3r]]></dc:creator><pubDate>Tue, 24 Aug 2021 06:26:46 GMT</pubDate></item><item><title><![CDATA[Reply to Soft-Reboot not working on Mon, 23 Aug 2021 17:21:42 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/m4v3r" aria-label="Profile: m4v3r">@<bdi>m4v3r</bdi></a> ,</p>
<p dir="auto">The 'reboot' command from QGC (should) only reset the STM32 micro processor so that's a bit odd.</p>
<p dir="auto">The 'reboot' command does make the QGC connection drop out momentarily normally.</p>
]]></description><link>https://forum.modalai.com/post/1972</link><guid isPermaLink="true">https://forum.modalai.com/post/1972</guid><dc:creator><![CDATA[modaltb]]></dc:creator><pubDate>Mon, 23 Aug 2021 17:21:42 GMT</pubDate></item></channel></rss>
