<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[voxl-open-vins-server imu_to_cam RPY(deg) different output logs]]></title><description><![CDATA[<p dir="auto">I am currently working with the VOXL 2 and attempting to run the voxl-open-vins-server alongside the voxl-feature-tracker. To configure the system, I set custom RPY (Roll, Pitch, Yaw) values for the drone in the extrinsics.conf file. However, when I attempt to log the values, the output does not match the expected results, and localization is not functioning properly.</p>
<p dir="auto">Here is the extrinsics.conf file with the custom settings I applied:<br />
<img src="/assets/uploads/files/1734782789133-78cdf2ea-2c8b-4c26-895c-a8f34c2c215f-image.png" alt="78cdf2ea-2c8b-4c26-895c-a8f34c2c215f-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Here is the log output,<br />
<img src="/assets/uploads/files/1734782739773-8cd64453-6d0b-47bb-bd0a-2a9b90e19206-image.png" alt="8cd64453-6d0b-47bb-bd0a-2a9b90e19206-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/topic/4051/voxl-open-vins-server-imu_to_cam-rpy-deg-different-output-logs</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 13:50:45 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/4051.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 21 Dec 2024 12:07:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to voxl-open-vins-server imu_to_cam RPY(deg) different output logs on Tue, 21 Jan 2025 16:16:28 GMT]]></title><description><![CDATA[<p dir="auto">Unsure, if you have resolved this so I am going to attempt to help but I am going to need more information if possible. I am unsure how the setup is for the drone seems like you have one camera (Tracking_rear) pointed straight backwards and two cameras (Tracking_front, Tracking_down) facing forward at a 30 degree downward angle?<br />
I am not sure that you are showing with the log output.<br />
Have you tried hand testing using the command <code>voxl-inspect-pose -l</code> and seeing how RPY and translational movement (moving the drone up, right, forward) are behaving for the local frame?</p>
]]></description><link>https://forum.modalai.com/post/20550</link><guid isPermaLink="true">https://forum.modalai.com/post/20550</guid><dc:creator><![CDATA[Aaron Porter]]></dc:creator><pubDate>Tue, 21 Jan 2025 16:16:28 GMT</pubDate></item></channel></rss>
