<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Changing video resolution of voxl-streamer]]></title><description><![CDATA[<p dir="auto">I found a video on the forums from SDK 0.9 that shows how to change voxl-streamer from 720p to 4K. This video also showed changes to the bitrate and decimation. I am running SDK 1.3+ on a Sentinel and would like to similarly change resolutions. I see in the new SDK documentation that bitrate is ignored at least. Is changing the resolution the same procedure as described in the video? Will bitrate still be ignored if I adjust the resolution? Need I adjust the decimation?</p>
]]></description><link>https://forum.modalai.com/topic/3977/changing-video-resolution-of-voxl-streamer</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 13:22:12 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3977.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 Nov 2024 18:55:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Changing video resolution of voxl-streamer on Wed, 04 Dec 2024 05:08:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2366">@groupo</a> , can you please provide some more details:</p>
<ul>
<li>are you using <code>voxl-streamer</code> to stream an h264 / h265 encoded stream (generated by <code>voxl-camera-server</code>) or is <code>voxl-streamer</code> consuming raw frames (raw8 or yuv) and encoding them to h264 / h265? If the input to <code>voxl-streamer</code> is not encoded, then voxl-streamer will encode them (using hardware video encoder)</li>
<li>voxl-streamer is not set up to resize the image, so the image size is defined by the source that is providing the images or encoded video stream (most likely <code>voxl-camera-server</code>).</li>
<li>you can modify your <code>/etc/modalai/voxl-camera-server.conf</code> to change the resolution of the stream that you are feeding into <code>voxl-streamer</code> (such as preview, small_video, large_video, etc) and that should automatically be reflected in the resolution that <code>voxl-streamer</code> outputs.</li>
</ul>
<p dir="auto">Feel free to provide more specific details about which exact stream (name) you are feeding into <code>voxl-streamaer</code> or let me know if you have any other questions.</p>
<p dir="auto">Alex</p>
]]></description><link>https://forum.modalai.com/post/19966</link><guid isPermaLink="true">https://forum.modalai.com/post/19966</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Wed, 04 Dec 2024 05:08:23 GMT</pubDate></item></channel></rss>
