<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Battery Charger for Starling 2 Max]]></title><description><![CDATA[<p dir="auto">HI Team,</p>
<p dir="auto">I have purchased the recommended charger for the Starling 2 max -&gt; <a href="https://www.amazon.com/ISDT-Q6-Nano-Charger-Discharger/dp/B09VRVPHW8/" rel="nofollow ugc">https://www.amazon.com/ISDT-Q6-Nano-Charger-Discharger/dp/B09VRVPHW8/</a>, and when I try to change my battery, it shows the operation is not supported. I am attaching the images for the reference. can you please help me with this issue</p>
<p dir="auto"><img src="/assets/uploads/files/1730751178161-whatsapp-image-2024-11-04-at-14.12.20-1.jpeg" alt="WhatsApp Image 2024-11-04 at 14.12.20 (1).jpeg" class=" img-fluid img-markdown" /><br />
The above are my connections.</p>
<p dir="auto">I tried to start the charge task with the below settings<br />
<img src="/assets/uploads/files/1730751333691-whatsapp-image-2024-11-04-at-14.12.20.jpeg" alt="WhatsApp Image 2024-11-04 at 14.12.20.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">But I am getting this issue<br />
<img src="/assets/uploads/files/1730751398041-whatsapp-image-2024-11-04-at-14.12.11.jpeg" alt="WhatsApp Image 2024-11-04 at 14.12.11.jpeg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/topic/3906/battery-charger-for-starling-2-max</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 16:02:57 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3906.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 Nov 2024 20:17:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Battery Charger for Starling 2 Max on Tue, 05 Nov 2024 17:17:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zachary-lowell-0" aria-label="Profile: Zachary-Lowell-0">@<bdi>Zachary-Lowell-0</bdi></a> Thank you for letting me know. this is my first time working with a multi-cell battery and a smart charger. I will be careful not to connect multiple batteries at the same time.</p>
]]></description><link>https://forum.modalai.com/post/19577</link><guid isPermaLink="true">https://forum.modalai.com/post/19577</guid><dc:creator><![CDATA[vamsi]]></dc:creator><pubDate>Tue, 05 Nov 2024 17:17:07 GMT</pubDate></item><item><title><![CDATA[Reply to Battery Charger for Starling 2 Max on Tue, 05 Nov 2024 17:14:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: tom">@<bdi>tom</bdi></a> Thank you for the response I now know what the issue is I will just connect a single battery, use 2s in the settings, and use an XT30 to XT60 converter to connect my XT30 to the "Battery" on the charger.</p>
]]></description><link>https://forum.modalai.com/post/19576</link><guid isPermaLink="true">https://forum.modalai.com/post/19576</guid><dc:creator><![CDATA[vamsi]]></dc:creator><pubDate>Tue, 05 Nov 2024 17:14:33 GMT</pubDate></item><item><title><![CDATA[Reply to Battery Charger for Starling 2 Max on Tue, 05 Nov 2024 15:41:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vamsi" aria-label="Profile: vamsi">@<bdi>vamsi</bdi></a> this is EXTREMELY dangerous please do not do this - you will without a doubt either overcharge or lose a cell if you charge like this - and will without a doubt lead to a very large fire. This charger does NOT support two battery charging.</p>
]]></description><link>https://forum.modalai.com/post/19571</link><guid isPermaLink="true">https://forum.modalai.com/post/19571</guid><dc:creator><![CDATA[Zachary Lowell 0]]></dc:creator><pubDate>Tue, 05 Nov 2024 15:41:12 GMT</pubDate></item><item><title><![CDATA[Reply to Battery Charger for Starling 2 Max on Tue, 05 Nov 2024 01:10:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vamsi" aria-label="Profile: vamsi">@<bdi>vamsi</bdi></a> I highly recommend reading the user manual for the battery charger: <a href="https://www.isdt.co/down/pdf/Q6nano_EN.pdf" rel="nofollow ugc">https://www.isdt.co/down/pdf/Q6nano_EN.pdf</a></p>
<p dir="auto">You should only be charging one battery at a time, what you're trying to do is not possible.</p>
<p dir="auto">The XT30 connector needs to be plugged in to the "Battery" connector on the charger with only a single 2s battery connected to the balance lead input. You'll also want to configure the settings accordingly (2s not 4s)</p>
]]></description><link>https://forum.modalai.com/post/19562</link><guid isPermaLink="true">https://forum.modalai.com/post/19562</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Tue, 05 Nov 2024 01:10:06 GMT</pubDate></item></channel></rss>
