<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Position Drift in Outdoor GPS Flight (non-VIO)]]></title><description><![CDATA[<p dir="auto">I am attempting to fly the VOXL m500 outdoor using GPS  without VIO. Sat count usually gets up to around 16-18 with HDOP ~0.7 VDOP~1.0. I get a valid local position and can fly in position mode, however I am experiencing large amounts of position drift (~3-5 meters along all 3 axis). That is after start up, while the vehicle is sitting still, I can see the values in LOCAL_POSITION_NED changing as if the vehicle were moving. I used the parameter set recommended in the parameter helper file for outdoor GPS flight with no luck. I also have tried tuning EKF2 with no luck. I booted up the vehicle in multiple different locations to see if something about one particular area was the issue, but the drift occurred regardless of location.</p>
<p dir="auto">Do you have any recommendations where to look next? Unless I missed a parameter somewhere I am at a dead end in getting this resolved.</p>
]]></description><link>https://forum.modalai.com/topic/387/position-drift-in-outdoor-gps-flight-non-vio</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 16:31:53 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/387.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 10 Aug 2021 21:54:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Position Drift in Outdoor GPS Flight (non-VIO) on Tue, 10 Aug 2021 21:57:08 GMT]]></title><description><![CDATA[<p dir="auto">Here is a link to my .param file: <a href="https://drive.google.com/file/d/14DA0fQ8Q4PowwlFXMUfU_w1wteXpM9rk/view?usp=sharing" rel="nofollow ugc">https://drive.google.com/file/d/14DA0fQ8Q4PowwlFXMUfU_w1wteXpM9rk/view?usp=sharing</a></p>
]]></description><link>https://forum.modalai.com/post/1853</link><guid isPermaLink="true">https://forum.modalai.com/post/1853</guid><dc:creator><![CDATA[blakekrpec]]></dc:creator><pubDate>Tue, 10 Aug 2021 21:57:08 GMT</pubDate></item></channel></rss>
