<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[issue with starting the cameras on my VOXL 2 device.]]></title><description><![CDATA[<h2>I am facing an issue with starting the cameras on my VOXL 2 device. Previously, all cameras were visible in the VOXL web portal, but currently, only the "hires" camera is showing up. Additionally, the cameras are not working in QGroundControl or VLC.<br />
I have tried several troubleshooting steps, such as configuring the video settings in the General tab of QGroundControl, adding the RTSP URL, and setting the aspect ratio, but there is still no output.<br />
When I run voxl-camera-server, only the "hires" camera is enabled, while others are not visible. Could you please guide me on how to get all cameras working again in both VOXL web portal and QGroundControl/VLC?<br />
This is the VOXL version:<br />
Vol version: --------------------------------------------------------------------------------<br />
system-image: 1.3.1-M0054-14.1a-perf<br />
kernel:       #1 SMP PREEMPT Tue Aug 2 05:23:05 UTC 2022 4.19.125</h2>
<h2>hw version:   M0054</h2>
<h2>voxl-suite:   0.8.1</h2>
<h2>This is what I get when I do:<br />
voxl2:/$ voxl-inspect-services<br />
Service Name         |  Enabled  |   Running   |  CPU Usage</h2>
<p dir="auto">docker-autorun       | Disabled  | Not Running |<br />
docker-daemon        | Disabled  | Not Running |<br />
modallink-relink     |  Enabled  | Not Running |<br />
voxl-camera-server   |  Enabled  |   Running   |     0.0<br />
voxl-cpu-monitor     |  Enabled  |   Running   |     0.0<br />
voxl-dfs-server      | Disabled  | Not Running |<br />
voxl-imu-server      |  Enabled  |   Running   |     0.0<br />
voxl-mavlink-server  |  Enabled  |   Running   |     0.0<br />
voxl-modem           |  Enabled  |   Running   |     0.0<br />
voxl-portal          |  Enabled  |   Running   |    15.0<br />
voxl-px4-imu-server  | Disabled  | Not Running |<br />
voxl-px4             |  Enabled  |   Running   |     0.0<br />
voxl-qvio-server     |  Enabled  |   Running   |     0.0<br />
voxl-softap          | Disabled  | Not Running |<br />
voxl-static-ip       | Disabled  | Not Running |<br />
voxl-streamer        |  Enabled  |   Running   |     0.0<br />
voxl-tag-detector    | Disabled  | Not Running |<br />
voxl-tflite-server   | Disabled  | Not Running |<br />
voxl-time-sync       | Disabled  | Not Running |<br />
voxl-vision-px4      |  Enabled  |   Running   |     0.0<br />
voxl-wait-for-fs     |  Enabled  |  Completed  |</p>
]]></description><link>https://forum.modalai.com/topic/3772/issue-with-starting-the-cameras-on-my-voxl-2-device</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Mar 2026 03:57:16 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3772.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Sep 2024 05:41:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to issue with starting the cameras on my VOXL 2 device. on Mon, 23 Sep 2024 07:08:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/4">@tom</a> It worked! I tightened the screws, and it turns out it was a hardware issue. I've installed the Tailscale VPN on both the drone and my machine, and I've completed the calibration and binding. However, I'm having trouble starting the camera; it's not turning on in VLC or QGroundControl.</p>
]]></description><link>https://forum.modalai.com/post/19098</link><guid isPermaLink="true">https://forum.modalai.com/post/19098</guid><dc:creator><![CDATA[Rawdha R]]></dc:creator><pubDate>Mon, 23 Sep 2024 07:08:37 GMT</pubDate></item><item><title><![CDATA[Reply to issue with starting the cameras on my VOXL 2 device. on Thu, 19 Sep 2024 16:59:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2448">@Rawdha-R</a> What do you see with <code>systemctl status voxl-modem</code>?</p>
<p dir="auto">If it is indeed not enumerating because of hardware there's nothing on the software side that will resolve it so we need to determine whether it is hw or sw at this point</p>
]]></description><link>https://forum.modalai.com/post/19063</link><guid isPermaLink="true">https://forum.modalai.com/post/19063</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Thu, 19 Sep 2024 16:59:41 GMT</pubDate></item><item><title><![CDATA[Reply to issue with starting the cameras on my VOXL 2 device. on Thu, 19 Sep 2024 07:40:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/4">@tom</a><br />
<img src="/assets/uploads/files/1726731256208-screen-shot-2024-09-19-at-11.34.12-am.png" alt="Screen Shot 2024-09-19 at 11.34.12 AM.png" class=" img-fluid img-markdown" /><br />
I have double-checked that the 5G add-on board is fully seated, and I followed the same process that worked successfully before the update. Given the current issue, what would you recommend I check next to help resolve this? I have attached a screenshot where I tried to reconfigured the modem and the issue still persists.</p>
]]></description><link>https://forum.modalai.com/post/19056</link><guid isPermaLink="true">https://forum.modalai.com/post/19056</guid><dc:creator><![CDATA[Rawdha R]]></dc:creator><pubDate>Thu, 19 Sep 2024 07:40:50 GMT</pubDate></item><item><title><![CDATA[Reply to issue with starting the cameras on my VOXL 2 device. on Wed, 18 Sep 2024 22:11:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2448">@Rawdha-R</a> Seems as though your 5G add-on board isn't fully seated and isn't able to enumerate</p>
]]></description><link>https://forum.modalai.com/post/19055</link><guid isPermaLink="true">https://forum.modalai.com/post/19055</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Wed, 18 Sep 2024 22:11:13 GMT</pubDate></item><item><title><![CDATA[Reply to issue with starting the cameras on my VOXL 2 device. on Wed, 18 Sep 2024 04:53:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/4">@tom</a><br />
This is what I got when I tried ifconfig there is no wwan0 in the list<br />
<img src="/assets/uploads/files/1726635183530-screen-shot-2024-09-18-at-8.52.57-am.png" alt="Screen Shot 2024-09-18 at 8.52.57 AM.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/post/19049</link><guid isPermaLink="true">https://forum.modalai.com/post/19049</guid><dc:creator><![CDATA[Rawdha R]]></dc:creator><pubDate>Wed, 18 Sep 2024 04:53:57 GMT</pubDate></item><item><title><![CDATA[Reply to issue with starting the cameras on my VOXL 2 device. on Mon, 16 Sep 2024 16:36:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2448">@Rawdha-R</a> What do you see with <code>ifconfig</code>? I'm not seeing a <code>wwan0</code> network interface that I would expect to see with 5G modem</p>
]]></description><link>https://forum.modalai.com/post/19037</link><guid isPermaLink="true">https://forum.modalai.com/post/19037</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Mon, 16 Sep 2024 16:36:41 GMT</pubDate></item><item><title><![CDATA[Reply to issue with starting the cameras on my VOXL 2 device. on Mon, 16 Sep 2024 08:39:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/4">@tom</a> I'm having trouble pinging the drone. I've set it up using a 5G modem (since the drone that I have doesnt have a wifi dongle) [VOXL AL &amp; 5G Development drone-sentinel 5G LTE Modem] to connect to QGroundControl and proceed with installing the VPN on the drone. However, when I attempt to ping <code>google.com</code>, I get an error stating "unknown server," and I'm unable to see the drone's IP address. Prior to updating the SDK, I had successfully configured the modem and connected to QGroundControl via Tailscale VPN and I don't know why I'm getting these issues now. Any assistance in resolving this issue would be appreciated.<br />
<img src="/assets/uploads/files/1726473612172-screen-shot-2024-09-16-at-12.00.05-pm.png" alt="Screen Shot 2024-09-16 at 12.00.05 PM.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1726473923379-screen-shot-2024-09-16-at-12.05.15-pm.png" alt="Screen Shot 2024-09-16 at 12.05.15 PM.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1726474505824-screen-shot-2024-09-16-at-12.14.58-pm.png" alt="Screen Shot 2024-09-16 at 12.14.58 PM.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1726475624959-screen-shot-2024-09-16-at-12.33.35-pm.png" alt="Screen Shot 2024-09-16 at 12.33.35 PM.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/post/19034</link><guid isPermaLink="true">https://forum.modalai.com/post/19034</guid><dc:creator><![CDATA[Rawdha R]]></dc:creator><pubDate>Mon, 16 Sep 2024 08:39:01 GMT</pubDate></item><item><title><![CDATA[Reply to issue with starting the cameras on my VOXL 2 device. on Mon, 16 Sep 2024 03:41:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/4">@tom</a></p>
<p dir="auto">It worked! I have attached a screenshot of the update:<br />
<img src="/assets/uploads/files/1726137806924-screen-shot-2024-09-12-at-2.41.23-pm.png" alt="Screen Shot 2024-09-12 at 2.41.23 PM.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1726137897858-screen-shot-2024-09-12-at-2.44.44-pm.png" alt="Screen Shot 2024-09-12 at 2.44.44 PM.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/post/19033</link><guid isPermaLink="true">https://forum.modalai.com/post/19033</guid><dc:creator><![CDATA[Rawdha R]]></dc:creator><pubDate>Mon, 16 Sep 2024 03:41:28 GMT</pubDate></item><item><title><![CDATA[Reply to issue with starting the cameras on my VOXL 2 device. on Wed, 11 Sep 2024 16:44:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2448">@Rawdha-R</a> Okay that is a good sign, it seems as though the board is going into fastboot correctly and the ubuntu machine is recognizing it that way. I still wonder if there is some permissions weirdness in play. What if you try running the install script with <code>sudo</code> permissions?</p>
]]></description><link>https://forum.modalai.com/post/18995</link><guid isPermaLink="true">https://forum.modalai.com/post/18995</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Wed, 11 Sep 2024 16:44:30 GMT</pubDate></item><item><title><![CDATA[Reply to issue with starting the cameras on my VOXL 2 device. on Wed, 11 Sep 2024 06:36:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/4">@tom</a><br />
Hello,</p>
<p dir="auto">I followed your instructions and ran sudo dmesg -wH to monitor the kernel messages while reproducing the issue. I observed the output, which I’ve attached as a screenshot.</p>
<p dir="auto">For context, I am running Ubuntu on a virtual machine (VM) and not directly on my hardware. I attempted the first flight of the drone, (VPN Tailscale) and while everything else was running smoothly, the only issue I faced was that the cameras did not turn on.</p>
<p dir="auto"><img src="/assets/uploads/files/1726034188647-screen-shot-2024-09-11-at-9.55.23-am.png" alt="Screen Shot 2024-09-11 at 9.55.23 AM.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/post/18978</link><guid isPermaLink="true">https://forum.modalai.com/post/18978</guid><dc:creator><![CDATA[Rawdha R]]></dc:creator><pubDate>Wed, 11 Sep 2024 06:36:28 GMT</pubDate></item><item><title><![CDATA[Reply to issue with starting the cameras on my VOXL 2 device. on Tue, 10 Sep 2024 17:16:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2448">@Rawdha-R</a> Interesting, if you run <code>dmesg -wH</code> in another terminal while going through this process do you see the device enumerate and then drop out maybe?</p>
<p dir="auto">Also, are you running Ubuntu in a VM or directly on your hardware?</p>
]]></description><link>https://forum.modalai.com/post/18956</link><guid isPermaLink="true">https://forum.modalai.com/post/18956</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Tue, 10 Sep 2024 17:16:55 GMT</pubDate></item><item><title><![CDATA[Reply to issue with starting the cameras on my VOXL 2 device. on Tue, 10 Sep 2024 04:46:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/4">@tom</a> Yes the permissions are there, I have attached a screenshot of the permissions. In the previous post sceenshot it shows as "[INFO} Found fastboot device", but once I send 1 and enter it's stuck. <img src="/assets/uploads/files/1725943565122-screen-shot-2024-09-10-at-8.45.51-am.png" alt="Screen Shot 2024-09-10 at 8.45.51 AM.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/post/18950</link><guid isPermaLink="true">https://forum.modalai.com/post/18950</guid><dc:creator><![CDATA[Rawdha R]]></dc:creator><pubDate>Tue, 10 Sep 2024 04:46:13 GMT</pubDate></item><item><title><![CDATA[Reply to issue with starting the cameras on my VOXL 2 device. on Mon, 09 Sep 2024 17:11:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2448">@Rawdha-R</a> Seems as though there is a permissions issue where fastboot isn't able to see the device.</p>
<p dir="auto">These are the permissions my user has, can you confirm your user has <code>sudo</code>, <code>dialout</code>, and <code>plugdev</code> permissions, and if not add them and restart your computer.![alt text](<img src="/assets/uploads/files/1725901877732-9e55a8de-be79-47b7-b0f0-db654645f521-image.png" alt="9e55a8de-be79-47b7-b0f0-db654645f521-image.png" class=" img-fluid img-markdown" /> image url)</p>
]]></description><link>https://forum.modalai.com/post/18932</link><guid isPermaLink="true">https://forum.modalai.com/post/18932</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Mon, 09 Sep 2024 17:11:19 GMT</pubDate></item><item><title><![CDATA[Reply to issue with starting the cameras on my VOXL 2 device. on Mon, 09 Sep 2024 06:06:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/4">@tom</a> said in <a href="/post/18902">issue with starting the cameras on my VOXL 2 device.</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2448">@Rawdha-R</a> I think the best first step would be to load the latest SDK on your VOXL 2 as that SDK is a few years old at this point.</p>
<p dir="auto">I would recommend flashing the latest SDK (1.3.3) from <a href="http://downloads.modalai.com" rel="nofollow ugc">downloads.modalai.com</a> under "VOXL 2 Platform Releases"</p>
<p dir="auto">Just follow the instructions here to do so: <a href="https://docs.modalai.com/flash-system-image/#flashing-a-voxl-sdk-release" rel="nofollow ugc">https://docs.modalai.com/flash-system-image/#flashing-a-voxl-sdk-release</a></p>
<p dir="auto">Reply</p>
</blockquote>
<p dir="auto">I tried flashing the latest SDK (1.3.3) from downloads modalai under VOXL 2 platform release[link text]<img src="/assets/uploads/files/1725861936761-screen-shot-2024-09-09-at-9.59.59-am-resized.png" alt="Screen Shot 2024-09-09 at 9.59.59 AM.png" class=" img-fluid img-markdown" />  It is stuck at this point, please see the screenshot above.</p>
]]></description><link>https://forum.modalai.com/post/18930</link><guid isPermaLink="true">https://forum.modalai.com/post/18930</guid><dc:creator><![CDATA[Rawdha R]]></dc:creator><pubDate>Mon, 09 Sep 2024 06:06:30 GMT</pubDate></item><item><title><![CDATA[Reply to issue with starting the cameras on my VOXL 2 device. on Thu, 05 Sep 2024 16:14:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2448">@Rawdha-R</a> I think the best first step would be to load the latest SDK on your VOXL 2 as that SDK is a few years old at this point.</p>
]]></description><link>https://forum.modalai.com/post/18902</link><guid isPermaLink="true">https://forum.modalai.com/post/18902</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Thu, 05 Sep 2024 16:14:47 GMT</pubDate></item></channel></rss>
