<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[streaming video to QGC over LTE]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/3290/rtsp-streaming-to-qgc-on-android-issues-on-voxl-mini">RTSP Streaming (to QGC on Android) issues on VOXL Mini</a></p>
<p dir="auto">Re: <a href="/topic/111/streaming-video-over-lte">Streaming video over LTE</a></p>
<p dir="auto">Along the same lines of the two replies above... I am trying to receive video from the drone in QGC over LTE.</p>
<p dir="auto">I have a private LTE network and know the IPs of both my QGC and drone, thus can circumvent the VPN solution. I have already connected drone and QGC in this manner.</p>
<p dir="auto">What I have tried:</p>
<p dir="auto">I can set the rtsp link in QGC but in both the linux and android versions (both v4.4.0) but the second my Sentinel is connected via QGC the option to set anything in QGC goes away. if I disconnect my drone from QGC, the option reappears. I am not sure if this is 'taking'. I do not believe so as the QGC console always reports status messages looking for video stream from 192.168.8.1.</p>
<p dir="auto">I have tried changing the default uri in voxl-mavcam-manager to the ip of my drone on the LTE network with the 8900 port, and tried disabling auto_ip as well.</p>
<p dir="auto">I also tried to use VLC to open a rtsp stream to no avail. Likely I am not doing something proper in the config files</p>
]]></description><link>https://forum.modalai.com/topic/3660/streaming-video-to-qgc-over-lte</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 21:57:29 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3660.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Jul 2024 17:42:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to streaming video to QGC over LTE on Thu, 19 Sep 2024 17:24:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2366">@groupo</a> Exactly</p>
]]></description><link>https://forum.modalai.com/post/19070</link><guid isPermaLink="true">https://forum.modalai.com/post/19070</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Thu, 19 Sep 2024 17:24:31 GMT</pubDate></item><item><title><![CDATA[Reply to streaming video to QGC over LTE on Thu, 19 Sep 2024 17:22:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/4">@tom</a> oh i see. I did not know it would happen either way. That makes sense then. I assume then eth0/usb0 are not given an Ip then because nothing is plugged into them?</p>
]]></description><link>https://forum.modalai.com/post/19069</link><guid isPermaLink="true">https://forum.modalai.com/post/19069</guid><dc:creator><![CDATA[groupo]]></dc:creator><pubDate>Thu, 19 Sep 2024 17:22:02 GMT</pubDate></item><item><title><![CDATA[Reply to streaming video to QGC over LTE on Thu, 19 Sep 2024 17:18:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2366">@groupo</a> The problem is that wwan0 will also get an IP by default if a 5G modem is installed whether or not it is actually connected to a network so I wouldn't want that to take priority over wlan0.</p>
<p dir="auto">Its tough to come up with a single solution that would work for each user so I have to choose the one that works for the majority of cases, some users may have to manually edit the file to fit their use case</p>
]]></description><link>https://forum.modalai.com/post/19068</link><guid isPermaLink="true">https://forum.modalai.com/post/19068</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Thu, 19 Sep 2024 17:18:41 GMT</pubDate></item><item><title><![CDATA[Reply to streaming video to QGC over LTE on Thu, 19 Sep 2024 17:15:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/4">@tom</a> do you think it should go above wlan0? If someone was using the drone only via LTE (BVLOS) they may not have access to the WIFI network. Wlan0 by default exists as it comes up when the drone turns on (at least in ap mode, maybe not in station mode?) versus wwan0 which only comes up if it is connected to a network</p>
]]></description><link>https://forum.modalai.com/post/19067</link><guid isPermaLink="true">https://forum.modalai.com/post/19067</guid><dc:creator><![CDATA[groupo]]></dc:creator><pubDate>Thu, 19 Sep 2024 17:15:04 GMT</pubDate></item><item><title><![CDATA[Reply to streaming video to QGC over LTE on Thu, 19 Sep 2024 17:10:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2366">@groupo</a> <a href="https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-utils/-/commit/562e196d9b7a74fbcda4405880062ab056fd1e3e" rel="nofollow ugc">https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-utils/-/commit/562e196d9b7a74fbcda4405880062ab056fd1e3e</a></p>
<p dir="auto">This change will make it into our next release (1.3.4)</p>
]]></description><link>https://forum.modalai.com/post/19066</link><guid isPermaLink="true">https://forum.modalai.com/post/19066</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Thu, 19 Sep 2024 17:10:54 GMT</pubDate></item><item><title><![CDATA[Reply to streaming video to QGC over LTE on Thu, 19 Sep 2024 17:08:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/4">@tom</a> Thanks Tom!</p>
]]></description><link>https://forum.modalai.com/post/19065</link><guid isPermaLink="true">https://forum.modalai.com/post/19065</guid><dc:creator><![CDATA[groupo]]></dc:creator><pubDate>Thu, 19 Sep 2024 17:08:08 GMT</pubDate></item><item><title><![CDATA[Reply to streaming video to QGC over LTE on Thu, 19 Sep 2024 17:02:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2366">@groupo</a> I'll add it, it's an uncommon use-case which is why it hasn't been in there.</p>
]]></description><link>https://forum.modalai.com/post/19064</link><guid isPermaLink="true">https://forum.modalai.com/post/19064</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Thu, 19 Sep 2024 17:02:44 GMT</pubDate></item><item><title><![CDATA[Reply to streaming video to QGC over LTE on Thu, 19 Sep 2024 15:28:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2366">@groupo</a> I updated to 1.3.3 and notice wwan0 is still not in network_interfaces_preferences.txt. Should it be?</p>
]]></description><link>https://forum.modalai.com/post/19061</link><guid isPermaLink="true">https://forum.modalai.com/post/19061</guid><dc:creator><![CDATA[groupo]]></dc:creator><pubDate>Thu, 19 Sep 2024 15:28:40 GMT</pubDate></item><item><title><![CDATA[Reply to streaming video to QGC over LTE on Tue, 23 Jul 2024 20:06:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2366">@groupo</a> any traction on this?  does step 1 actually impact anything with regard to the stream from voxl-streamer?</p>
]]></description><link>https://forum.modalai.com/post/18348</link><guid isPermaLink="true">https://forum.modalai.com/post/18348</guid><dc:creator><![CDATA[groupo]]></dc:creator><pubDate>Tue, 23 Jul 2024 20:06:11 GMT</pubDate></item><item><title><![CDATA[Reply to streaming video to QGC over LTE on Fri, 19 Jul 2024 18:51:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2366">@groupo</a> Hey I think I actually got this one on my own <img src="https://forum.modalai.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60e.png?v=r4gp3i66d9g" class="not-responsive emoji emoji-android emoji--sunglasses" title=":sunglasses:" alt="😎" /></p>
<ol>
<li>
<p dir="auto">I set default_uri in voxl-mavcam-manager.conf to the IP of my drone on the LTE network (rtsp://10.0.1.1:8900/live)</p>
</li>
<li>
<p dir="auto">I had to modify /etc/modalai/network_interfaces_preferences.txt to include wwan0. I put it at the top of the list, but I believe so long as it is above wlan0 it should be fine for my use case.</p>
</li>
</ol>
<p dir="auto">Is there a better solution to this? Should wwan0 not be in that .txt? TIA</p>
]]></description><link>https://forum.modalai.com/post/18301</link><guid isPermaLink="true">https://forum.modalai.com/post/18301</guid><dc:creator><![CDATA[groupo]]></dc:creator><pubDate>Fri, 19 Jul 2024 18:51:12 GMT</pubDate></item></channel></rss>
