<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Regarding the issue of recovering voxl-suite！]]></title><description><![CDATA[<p dir="auto">First, I encountered issues while installing the Docker environment on VOXL2. The main problem occurred with the sudo apt update command. After executing this command, it showed that I couldn't <strong>fetch Docker from the Docker website</strong>. I suspect it is a network issue with VOXL2, so I tried changing the source. However, I still got stuck due to Python3 issues. I then attempted to uninstall Python3, and finally, the following problem appeared<br />
(<strong>the version number after voxl-suite <em>disappeared</em></strong>) :</p>
<p dir="auto"><img src="/assets/uploads/files/1720796080539-2024-07-12-22-36-03%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE.png" alt="2024-07-12 22-36-03屏幕截图.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Therefore, I have two issues that need your kind assistance:</p>
<ol>
<li>Is the network problem here related to an inability to connect to the <strong>external network</strong>?</li>
<li>How can I recover voxl-suite? Should I <strong>reflash the SDK</strong>?<br />
Honestly, I appreciate your previous help that has gotten me this far, but since I am a beginner, I hope you can <strong>explain it to me carefully</strong>. Thank you very much for your assistance!</li>
</ol>
]]></description><link>https://forum.modalai.com/topic/3636/regarding-the-issue-of-recovering-voxl-suite</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Mar 2026 20:29:10 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3636.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Jul 2024 15:03:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Regarding the issue of recovering voxl-suite！ on Mon, 15 Jul 2024 16:29:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2393">@cy208183395</a> VOXL doesn't need to be connected to a network in order to upgrade an SDK via the <code>install.sh</code> script, you can follow the steps here: <a href="https://docs.modalai.com/flash-system-image/#flashing-a-voxl-sdk-release" rel="nofollow ugc">https://docs.modalai.com/flash-system-image/#flashing-a-voxl-sdk-release</a></p>
]]></description><link>https://forum.modalai.com/post/18239</link><guid isPermaLink="true">https://forum.modalai.com/post/18239</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Mon, 15 Jul 2024 16:29:42 GMT</pubDate></item><item><title><![CDATA[Reply to Regarding the issue of recovering voxl-suite！ on Sat, 13 Jul 2024 06:36:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/4">@tom</a></p>
<ol>
<li>I connected to my personal WiFi, but this WiFi cannot connect to the external network.<br />
<img src="/assets/uploads/files/1720852549705-2024-07-13-14-35-36%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE.png" alt="2024-07-13 14-35-36屏幕截图.png" class=" img-fluid img-markdown" /></li>
</ol>
<p dir="auto"><img src="/assets/uploads/files/1720852561015-2024-07-13-14-35-08%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE.png" alt="2024-07-13 14-35-08屏幕截图.png" class=" img-fluid img-markdown" /></p>
<ol start="2">
<li>Which tutorial should I follow? Please point it out for me. Thank you!</li>
</ol>
]]></description><link>https://forum.modalai.com/post/18218</link><guid isPermaLink="true">https://forum.modalai.com/post/18218</guid><dc:creator><![CDATA[cy208183395]]></dc:creator><pubDate>Sat, 13 Jul 2024 06:36:22 GMT</pubDate></item><item><title><![CDATA[Reply to Regarding the issue of recovering voxl-suite！ on Fri, 12 Jul 2024 16:44:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2393">@cy208183395</a></p>
<ol>
<li>
<p dir="auto">Do you have wifi connected to your VOXL 2?</p>
</li>
<li>
<p dir="auto">I would recommend downloading the latest SDK from <a href="http://downloads.modalai.com" rel="nofollow ugc">downloads.modalai.com</a> and flashing it with the <code>install.sh</code> script to get you back to a known good spot</p>
</li>
</ol>
]]></description><link>https://forum.modalai.com/post/18191</link><guid isPermaLink="true">https://forum.modalai.com/post/18191</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Fri, 12 Jul 2024 16:44:14 GMT</pubDate></item></channel></rss>
