<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Video streaming delay]]></title><description><![CDATA[<p dir="auto">Hi dev team,</p>
<p dir="auto">I'm testing video stream using voxl-rtsp, voxl-streamer.</p>
<p dir="auto">I found a few seconds latency for streaming in my home wifi connection.</p>
<p dir="auto">even I use pddl module, latency is simular.</p>
<p dir="auto">could you please recommend to reduce latency for streamming?</p>
<p dir="auto">Thanks,</p>
]]></description><link>https://forum.modalai.com/topic/360/video-streaming-delay</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 07:53:55 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/360.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Jul 2021 21:54:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Video streaming delay on Thu, 16 Feb 2023 21:38:48 GMT]]></title><description><![CDATA[<p dir="auto">I also have the same issue, I have used the portal and QGroundControl to view camera feed but there is a delay in both, enough so that it is not reliable to fly depending on the feed alone. I have tried disabling the portal and the docker to see if it would help but not much of a difference. If someone could help us figure out a way to stream the Hires RGB camera in 4k resolution with minimal delay if possible? Or even just lower the delay with 1080p resolution?<br />
Please and Thank You.</p>
]]></description><link>https://forum.modalai.com/post/8546</link><guid isPermaLink="true">https://forum.modalai.com/post/8546</guid><dc:creator><![CDATA[mirasul]]></dc:creator><pubDate>Thu, 16 Feb 2023 21:38:48 GMT</pubDate></item><item><title><![CDATA[Reply to Video streaming delay on Thu, 29 Jul 2021 16:22:23 GMT]]></title><description><![CDATA[<p dir="auto">Our normal test platform is QGroundControl. Delay is less than one second. VLC is known to introduce extra buffering and latency. You can change the VLC settings to get lower latency but, in my experience, it will always be much higher than QGroundControl.</p>
]]></description><link>https://forum.modalai.com/post/1727</link><guid isPermaLink="true">https://forum.modalai.com/post/1727</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Thu, 29 Jul 2021 16:22:23 GMT</pubDate></item><item><title><![CDATA[Reply to Video streaming delay on Thu, 29 Jul 2021 04:13:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/14">@Eric-Katzfey</a> I used both of them.</p>
<p dir="auto">I tested  latest version of voxl-suite with M500 VOXL flight.</p>
<p dir="auto">Camera sources are hire-solution mpa, stereo and tracking camera also.</p>
<p dir="auto">wireless connection is home 300Mbps wifi with 5.4GHz.</p>
<p dir="auto">I got the stream data using VLC client for mpa and rqt_image_view for voxl_mpa_ros.</p>
<p dir="auto">all of them has 3-4 seconds latency from source.</p>
<p dir="auto">Is it normal?</p>
<p dir="auto">Could you please let me know your latency for video streamming if you can measure?</p>
]]></description><link>https://forum.modalai.com/post/1723</link><guid isPermaLink="true">https://forum.modalai.com/post/1723</guid><dc:creator><![CDATA[shlee853]]></dc:creator><pubDate>Thu, 29 Jul 2021 04:13:01 GMT</pubDate></item><item><title><![CDATA[Reply to Video streaming delay on Wed, 28 Jul 2021 20:31:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/153">@shlee853</a> Can you please provide some more details? Are you using voxl-rtsp or voxl-streamer? Which camera are you streaming video from? What are you using to view the video?</p>
]]></description><link>https://forum.modalai.com/post/1721</link><guid isPermaLink="true">https://forum.modalai.com/post/1721</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Wed, 28 Jul 2021 20:31:21 GMT</pubDate></item></channel></rss>
