<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Turning off ESC regenrative braking for calibration]]></title><description><![CDATA[<p dir="auto">Hi, I would like to calibrate my M0129 ESC using a power supply, but I understand it's advised not to do so as this can damage the ESC. Would thus like to ask if the regenerative braking can be turned off only for ESC calibration.</p>
<p dir="auto">I did notice that there is a brake_to_stop param in the parameters file, however it is unclear whether a 1 or 0 parameter deactivates the regenerative braking.</p>
]]></description><link>https://forum.modalai.com/topic/3495/turning-off-esc-regenrative-braking-for-calibration</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 12:41:45 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3495.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 May 2024 06:14:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Turning off ESC regenrative braking for calibration on Thu, 30 May 2024 03:02:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schew" aria-label="Profile: schew">@<bdi>schew</bdi></a>,</p>
<p dir="auto">Regenerative braking happens when you command the ESC to transition from a higher speed to a lower speed. Also, if <code>brake_to_stop</code> parameter is set to 1, the ESC will apply braking when it is commanded to stop (0 rpm or 0 power) or it times out. If the <code>brake_to_stop</code> parameter is set to 0, the ESC will not brake during stopping or time out, instead the motor will spin freely (coast) to a stop.</p>
<p dir="auto">So, <code>brake_to_stop</code> parameter does not affect normal operation and you should just keep that at zero, unless you REALLY need the motor to stop very fast when you disarm. (but then if you are connected to a power supply at that point, it can cause issues described here : <a href="https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/master/voxl-esc-tools/doc/regenerative_braking.md" rel="nofollow ugc">https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/master/voxl-esc-tools/doc/regenerative_braking.md</a> )</p>
<p dir="auto">Turning off Regenerative Braking completely is possible on M0129 ESC, but it is not currently supported in the firmware.</p>
<p dir="auto">So, to answer your question, if you run the ESC calibration using <code>voxl-calibrate-esc.py</code> script (according to these instructions : <a href="https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/master/voxl-esc-tools/calibration.md" rel="nofollow ugc">https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/master/voxl-esc-tools/calibration.md</a>), there will not be a regenerative braking event during this procedure (unless you set <code>brake_to_stop</code> to 1, see above). In the calibration procedure, the ESC is commanded to increase the applied power in small steps and at the end the commands from the script stop, so ESC times out and spins down.</p>
<p dir="auto">I have just run a test using a power supply (set to 12V) and modified calibration script, which shows voltage and current data after the calibration has finished. See plot below:<br />
<img src="/assets/uploads/files/1717037084592-ad88ce7f-2a54-48a5-96cb-970af729443a-image-resized.png" alt="ad88ce7f-2a54-48a5-96cb-970af729443a-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">From the plot you can see that at t=12s, the test stops, the voltage (which was dipping during the test as current increased) comes back to 12V without overshoot and the current just drops to zero (does not become negative, which would be the case, if regenerative current was present).</p>
<p dir="auto">I have explained what will happen if you run the esc calibration procedure (in its current version) while using a power supply. However, you should not do any aggressive spin testing with a power supply, especially step tests, where the ESC is commanded to ramp up and then down. The reason why we do not recommend doing any testing  with a power supply is that it is possible to forget that the ESC is plugged into the power supply (not battery) and start performing tests which can damage the ESC or power supply. If you start hitting the Power Supply's over-current limit, voltage may drop and there could be strange behavior and ESC could de-sync.</p>
<p dir="auto">You also need to ensure that the Power Supply can source enough current to perform the calibration. If needed, you can decrease the maximum power that is applied during calibration (using <code>--pwm-max</code> parameter)</p>
<p dir="auto">So, with all that being said.. We still do not recommend testing the ESC with a power supply. If you still choose to do it, it would be at your own risk and i suggest starting by limiting <code>--pwm-max</code> parameter to a low value, say 40-50 and looking at the plot to ensure all the data looks similar to the plot in the calibration doc. Then gradually increase the <code>--pwm-max</code> parameter to 60, 70, 80, 90, checking the plot each time. You could stop at 90 and use that calibration result.</p>
<p dir="auto">Alex</p>
]]></description><link>https://forum.modalai.com/post/17293</link><guid isPermaLink="true">https://forum.modalai.com/post/17293</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Thu, 30 May 2024 03:02:23 GMT</pubDate></item></channel></rss>
