<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Issue with running cam calibration]]></title><description><![CDATA[<p dir="auto">I am having a few issues running the camera calibration on the VOXL<br />
I am following the steps in <a href="https://docs.modalai.com/calibrate-cameras/" rel="nofollow ugc">https://docs.modalai.com/calibrate-cameras/</a></p>
<p dir="auto">When I try to run any of the voxl_cam_ros features I get the following error</p>
<pre><code>yocto:/$ roslaunch voxl_cam_ros tracking_slave.launch
[tracking_slave.launch] is neither a launch file in package [voxl_cam_ros] nor is [voxl_cam_ros] a launch file name
The traceback for the exception was written to the log file
<p dir="auto">Here is my current installed packages</p>
<pre><code>yocto:/$ opkg list-installed | grep "voxl"
libvoxl_cutils - 0.0.2
libvoxl_io - 0.5.4
voxl-camera-server - 0.7.1
voxl-cpu-monitor - 0.1.7
voxl-dfs-server - 0.2.0
voxl-docker-support - 1.1.3
voxl-gphoto2 - 0.0.5
voxl-imu-server - 0.8.1
voxl-mavlink - 0.0.2
voxl-modem - 0.12.0
voxl-mpa-tools - 0.2.6
voxl-nodes - 0.1.7
voxl-qvio-server - 0.3.1
voxl-streamer - 0.2.3
voxl-suite - 0.4.6
voxl-tag-detector - 0.0.2
voxl-tflite - 0.0.1
voxl-tflite-server - 0.1.1
voxl-utils - 0.7.1
voxl-vision-px4 - 0.9.2
voxl-vpn - 0.0.3
<p dir="auto">I assume I am missing something but I have read through the documentation a few times to try and work out what I have done wrong</p>
]]></description><link>https://forum.modalai.com/topic/347/issue-with-running-cam-calibration</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 16:28:15 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/347.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 22 Jul 2021 06:10:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Issue with running cam calibration on Mon, 26 Jul 2021 15:50:04 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-macnamara" aria-label="Profile: Thomas-MacNamara">@<bdi>Thomas-MacNamara</bdi></a> ,</p>
<p dir="auto">I totally hear you...  We are reeeeal close to a big docs update......  Should be dropping on the server within days and hopefully we can clear things up.  Appreciate the patience and please keep providing feedback as you have issues!</p>
<p dir="auto">-Travis</p>
]]></description><link>https://forum.modalai.com/post/1698</link><guid isPermaLink="true">https://forum.modalai.com/post/1698</guid><dc:creator><![CDATA[modaltb]]></dc:creator><pubDate>Mon, 26 Jul 2021 15:50:04 GMT</pubDate></item><item><title><![CDATA[Reply to Issue with running cam calibration on Fri, 23 Jul 2021 02:08:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi thanks for your help with that.</p>
<p dir="auto">Just a note: I love this thing, it is going to save me months of development time. What you all have done here is amazing.</p>
<p dir="auto">But, please could you at least put some <em>We are messing with this code at the moment</em> or some <em>Deprecated</em> warnings in your documentation.</p>
<p dir="auto">This is the third rabbit-hole I have gone down just to find out that the code does not exist or has been refactored.</p>
<p dir="auto">Part of the issue is I am trying not to be too much of a pain asking questions and i assume that often it is an issue on my side so by the time I have posted I am already a day into hitting my head against a wall.</p>
]]></description><link>https://forum.modalai.com/post/1679</link><guid isPermaLink="true">https://forum.modalai.com/post/1679</guid><dc:creator><![CDATA[Thomas MacNamara]]></dc:creator><pubDate>Fri, 23 Jul 2021 02:08:51 GMT</pubDate></item><item><title><![CDATA[Reply to Issue with running cam calibration on Thu, 22 Jul 2021 16:53:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi Thomas,</p>
<p dir="auto">This is an error in our documentation as we're halfway between calibration projects, sorry about that. We're currently close to having a non-ros based onboard camera calibrator published, but in the meantime you should run</p>
<pre><code>roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
<p dir="auto">Instead of the voxl cam rosnode. This will pull frames from voxl-camera-server (so make sure that's also running) and publish them over ros in the same way that voxl-cam ros would, so the rest of the calibration docs are current.</p>
]]></description><link>https://forum.modalai.com/post/1664</link><guid isPermaLink="true">https://forum.modalai.com/post/1664</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 22 Jul 2021 16:53:22 GMT</pubDate></item></channel></rss>
