<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Doodle Labs Not Connecting to QGC]]></title><description><![CDATA[<p dir="auto">I received a Doodle Labs Radio in my last shipment that I believe to have an issue. After programming the VOXL2 I am unable to get connection over QGC. I have multiple VOXL2 and Doodle Labs set up in house that I have been able to use to help troubleshoot this issue.</p>
<p dir="auto">The Doodle Labs Radio that is in question is in the air vehicle. I am able to ping the IP of the Air radio from my Laptop which is connected to a Doodle Labs radio. I am also able to pull up the Web interface for the Air Radio as well. I am not able to ping the VOXL2 or open VOXL Portal. I have tried to reset the radio to factory defaults and also flash a backup file from a known working radio with no luck. I was also able to test out different harnesses and even plugged the Radio in question to a known working VOXL2 setup with the same issue. I was able to plug the VOXL2 that is in the same vehicle with the questionable Doodle Labs radio to another Doodle Labs Radio and it linked up to QGC with no Issues.</p>
<p dir="auto">With my troubleshooting it seems I have narrowed it down to this Doodle Labs Radio. I am not sure how to continue troubleshooting the issue. I guess it could be something wrong with the actual hardware of the radio.</p>
<p dir="auto">Any information to help me solve this issue will be appreciated. Thanks!</p>
]]></description><link>https://forum.modalai.com/topic/3421/doodle-labs-not-connecting-to-qgc</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 13:17:20 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3421.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 May 2024 12:33:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Doodle Labs Not Connecting to QGC on Fri, 10 May 2024 20:20:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chase-riley" aria-label="Profile: Chase-Riley">@<bdi>Chase-Riley</bdi></a> yes, we can work with Doodle Labs to get this resolved</p>
]]></description><link>https://forum.modalai.com/post/16819</link><guid isPermaLink="true">https://forum.modalai.com/post/16819</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Fri, 10 May 2024 20:20:34 GMT</pubDate></item><item><title><![CDATA[Reply to Doodle Labs Not Connecting to QGC on Fri, 10 May 2024 19:17:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: tom">@<bdi>tom</bdi></a> I checked wire harness going from the VOXL 2 to the Doodle Labs. Everything seems in check there. Haven't noticed anything wrong with the connector or solder joints on the pcb located on top of the Doodle Labs. Would you recommend getting a RMA going for this radio?</p>
]]></description><link>https://forum.modalai.com/post/16818</link><guid isPermaLink="true">https://forum.modalai.com/post/16818</guid><dc:creator><![CDATA[Chase Riley]]></dc:creator><pubDate>Fri, 10 May 2024 19:17:49 GMT</pubDate></item><item><title><![CDATA[Reply to Doodle Labs Not Connecting to QGC on Fri, 10 May 2024 18:16:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chase-riley" aria-label="Profile: Chase-Riley">@<bdi>Chase-Riley</bdi></a> I'm coming to the same hypothesis that you did that there might be an issue with that specific doodle radio (maybe a bad connector?)</p>
]]></description><link>https://forum.modalai.com/post/16816</link><guid isPermaLink="true">https://forum.modalai.com/post/16816</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Fri, 10 May 2024 18:16:20 GMT</pubDate></item><item><title><![CDATA[Reply to Doodle Labs Not Connecting to QGC on Fri, 10 May 2024 17:36:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: tom">@<bdi>tom</bdi></a> I am not able to ping the Doodle Labs Radio from the VOXL2 that is connected to it.</p>
]]></description><link>https://forum.modalai.com/post/16813</link><guid isPermaLink="true">https://forum.modalai.com/post/16813</guid><dc:creator><![CDATA[Chase Riley]]></dc:creator><pubDate>Fri, 10 May 2024 17:36:45 GMT</pubDate></item><item><title><![CDATA[Reply to Doodle Labs Not Connecting to QGC on Fri, 10 May 2024 17:08:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chase-riley" aria-label="Profile: Chase-Riley">@<bdi>Chase-Riley</bdi></a> Are you able to ping said doodle labs modem from the voxl 2 it is physically connected to?</p>
]]></description><link>https://forum.modalai.com/post/16812</link><guid isPermaLink="true">https://forum.modalai.com/post/16812</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Fri, 10 May 2024 17:08:28 GMT</pubDate></item></channel></rss>
