<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Voxl starling crashed all motors stop working mid air]]></title><description><![CDATA[<p dir="auto">My Starlink drone crashed while it was in mid-air, all 4 motors ceased working suddenly. After the crash, I saw qgc was not connected. Has anyone faced this problem? If so can anyone point out the reason and how to solve it? I am <strong>assuming</strong> it is because the communication failed or the Voxl restarted its services mid-air which led to the crash. If anyone has faced this problem can you please tell me how to sort this out?</p>
]]></description><link>https://forum.modalai.com/topic/3384/voxl-starling-crashed-all-motors-stop-working-mid-air</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 04:17:49 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3384.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 01 May 2024 14:30:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Voxl starling crashed all motors stop working mid air on Wed, 08 May 2024 13:12:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2294">@Manu-Verma</a> , that is great that you figured it out!</p>
<p dir="auto">Can you please help us understand where exactly the loose connection was? Could you please take a picture and mark the location of the issue? That would be really appreciated!</p>
<p dir="auto">Alex</p>
]]></description><link>https://forum.modalai.com/post/16764</link><guid isPermaLink="true">https://forum.modalai.com/post/16764</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Wed, 08 May 2024 13:12:47 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl starling crashed all motors stop working mid air on Wed, 08 May 2024 09:45:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/7">@Alex-Kushleyev</a> Just figured out why the motors were ceasing mid-air, it was the power module wire that was loose, so whenever I took off, the board was rebooting, (coz of the loose connection to the power module.)</p>
]]></description><link>https://forum.modalai.com/post/16762</link><guid isPermaLink="true">https://forum.modalai.com/post/16762</guid><dc:creator><![CDATA[Manu Verma]]></dc:creator><pubDate>Wed, 08 May 2024 09:45:57 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl starling crashed all motors stop working mid air on Fri, 03 May 2024 17:44:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/14">@Eric-Katzfey</a> All 4 motors ceased at the same time it was not spinning at a lower speed after the crash.</p>
]]></description><link>https://forum.modalai.com/post/16676</link><guid isPermaLink="true">https://forum.modalai.com/post/16676</guid><dc:creator><![CDATA[Manu Verma]]></dc:creator><pubDate>Fri, 03 May 2024 17:44:21 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl starling crashed all motors stop working mid air on Fri, 03 May 2024 17:46:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/7">@Alex-Kushleyev</a> How can I send you the system data logs from Voxl not the px4 logs, since I can't attach any file here, can you tell by checking the system data logs? And how can I share that file here? Also, I gave the throttle to zero after it crashed.</p>
]]></description><link>https://forum.modalai.com/post/16673</link><guid isPermaLink="true">https://forum.modalai.com/post/16673</guid><dc:creator><![CDATA[Manu Verma]]></dc:creator><pubDate>Fri, 03 May 2024 17:46:33 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl starling crashed all motors stop working mid air on Thu, 02 May 2024 19:26:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2294">@Manu-Verma</a>,</p>
<p dir="auto">some useful plots:</p>
<p dir="auto"><img src="/assets/uploads/files/1714677451324-515ca992-e2e4-4a50-93da-04fd95b40d8d-image.png" alt="515ca992-e2e4-4a50-93da-04fd95b40d8d-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Zooming into the Manual Control Inputs,<br />
<img src="/assets/uploads/files/1714677662687-manual_control_input.png" alt="manual_control_input.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">It looks like the vehicle switched from altitude hold mode to position mode, but then the operator dropped throttle to minimum. Does that sound like something that might have happened?</p>
<p dir="auto">The commanded and actual ESC commands went to minimum (it looks like around 3000rpm), the vehicle was not able to control attitude and flipped over, then motors were commanded to turn off.</p>
]]></description><link>https://forum.modalai.com/post/16652</link><guid isPermaLink="true">https://forum.modalai.com/post/16652</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Thu, 02 May 2024 19:26:57 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl starling crashed all motors stop working mid air on Thu, 02 May 2024 14:33:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2294">@Manu-Verma</a> That log does show that the throttle was pulled all the way down towards the end of the log. Are you sure this is the log from the crash? Did the 4 motors all stop completely or were they still spinning at a lower speed? Were they spinning at all after the vehicle crashed?</p>
]]></description><link>https://forum.modalai.com/post/16648</link><guid isPermaLink="true">https://forum.modalai.com/post/16648</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Thu, 02 May 2024 14:33:32 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl starling crashed all motors stop working mid air on Thu, 02 May 2024 13:48:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/14">@Eric-Katzfey</a> Following is the system_data logs and PX4 logs recorded during last flight.</p>
<p dir="auto"><a href="https://review.px4.io/plot_app?log=dd990b27-ef3a-453a-91ef-c51ff4dc4bbd" rel="nofollow ugc">https://review.px4.io/plot_app?log=dd990b27-ef3a-453a-91ef-c51ff4dc4bbd</a></p>
]]></description><link>https://forum.modalai.com/post/16647</link><guid isPermaLink="true">https://forum.modalai.com/post/16647</guid><dc:creator><![CDATA[Manu Verma]]></dc:creator><pubDate>Thu, 02 May 2024 13:48:24 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl starling crashed all motors stop working mid air on Wed, 01 May 2024 15:31:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2294">@Manu-Verma</a> This needs to be debugged. Obviously, that should never happen. The best way to debug this is to provide log information that can be analyzed for clues. If you see this happen and you can extract the log from <code>dmesg</code>, <code>journalctl -b -u voxl-px4</code>, and the px4 log from <code>/data/px4/log</code> directory that will really help to understand what went wrong.</p>
]]></description><link>https://forum.modalai.com/post/16632</link><guid isPermaLink="true">https://forum.modalai.com/post/16632</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Wed, 01 May 2024 15:31:06 GMT</pubDate></item></channel></rss>
