<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ToF Performance Degrades as CPU heats up]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I'm seeing degraded ToF performance when the CPU is operating at 60C versus 40C. Degraded means fewer point returns, at less of a max distance.  Is this the expected behavior of the sensor?</p>
<p dir="auto">System details:</p>
<ul>
<li>ToF: <code>M0040-1 (Legacy TOF)</code></li>
<li>VOXL2</li>
<li>voxl-camera-server version <code>1.8.4</code></li>
<li>System image: <code>1.7.1-M0054-14.1a-perf-nightly-20231009</code></li>
<li>Kernel: <code>#1 SMP PREEMPT Tue Oct 10 03:21:29 UTC 2023 4.19.125</code></li>
</ul>
]]></description><link>https://forum.modalai.com/topic/3270/tof-performance-degrades-as-cpu-heats-up</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 13:36:38 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3270.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 Mar 2024 15:15:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ToF Performance Degrades as CPU heats up on Thu, 28 Mar 2024 18:58:02 GMT]]></title><description><![CDATA[<p dir="auto">if CPU was causing the issue, then you would see slower FPS, not degraded performance.</p>
<p dir="auto">This sounds like the actual TOF sensor is heating up and at some point starts throttling itself by reducing the emitted power, which helps cool it down.</p>
<p dir="auto">You could test it by selectively cooling TOF sensor (and not voxl) and see if performance goes back up.</p>
]]></description><link>https://forum.modalai.com/post/15817</link><guid isPermaLink="true">https://forum.modalai.com/post/15817</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Thu, 28 Mar 2024 18:58:02 GMT</pubDate></item><item><title><![CDATA[Reply to ToF Performance Degrades as CPU heats up on Thu, 28 Mar 2024 18:11:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/1443">@Rowan-Dempster</a> On the ground it's helpful to point a cheap desk fan at the drone while developing and debugging. Once it's in the air, there is unlimited airflow and things will cool down quickly.</p>
]]></description><link>https://forum.modalai.com/post/15815</link><guid isPermaLink="true">https://forum.modalai.com/post/15815</guid><dc:creator><![CDATA[Moderator]]></dc:creator><pubDate>Thu, 28 Mar 2024 18:11:10 GMT</pubDate></item></channel></rss>
