<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New VOXL2 not connecting to Windows machine that connects to Older VOXL2]]></title><description><![CDATA[<p dir="auto">I was previously able to connect to an older VOXL2 with my windows machine with both CMD and WSL. Just got a new VOXL2 yesterday and it is not recognized by the same windows machine.</p>
<p dir="auto">USB-C to USB-A</p>
<p dir="auto">QUSB_BULK_SN:A37F2E68</p>
<p dir="auto">This is the device in device manager. Is there a driver for this device?</p>
]]></description><link>https://forum.modalai.com/topic/3252/new-voxl2-not-connecting-to-windows-machine-that-connects-to-older-voxl2</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 13:33:52 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3252.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Mar 2024 18:01:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New VOXL2 not connecting to Windows machine that connects to Older VOXL2 on Tue, 26 Mar 2024 14:42:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rdjarvis" aria-label="Profile: rdjarvis">@<bdi>rdjarvis</bdi></a> ,</p>
<p dir="auto">The board is in eDL mode (emergency download). Can you please check that SW2 is off and if the issue is persists, provide serial number of voxl2 board, we will check test records.</p>
]]></description><link>https://forum.modalai.com/post/15712</link><guid isPermaLink="true">https://forum.modalai.com/post/15712</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Tue, 26 Mar 2024 14:42:47 GMT</pubDate></item><item><title><![CDATA[Reply to New VOXL2 not connecting to Windows machine that connects to Older VOXL2 on Tue, 26 Mar 2024 14:35:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alex-kushleyev" aria-label="Profile: Alex-Kushleyev">@<bdi>Alex-Kushleyev</bdi></a> Thank you for the response. I have not tried unbricking.</p>
]]></description><link>https://forum.modalai.com/post/15711</link><guid isPermaLink="true">https://forum.modalai.com/post/15711</guid><dc:creator><![CDATA[rdjarvis]]></dc:creator><pubDate>Tue, 26 Mar 2024 14:35:24 GMT</pubDate></item><item><title><![CDATA[Reply to New VOXL2 not connecting to Windows machine that connects to Older VOXL2 on Tue, 26 Mar 2024 04:43:44 GMT]]></title><description><![CDATA[<p dir="auto">I believe that if the device is showing up as QBULK, it boots into recovery mode. It is strange that this is happening to a brand new VOXL2. I will check about this. Have you ever tried the unbricking procedure for VOXL2? <a href="https://docs.modalai.com/voxl2-unbricking/" rel="nofollow ugc">https://docs.modalai.com/voxl2-unbricking/</a> ?</p>
<p dir="auto">Before you do try it on this board, let us get back to you.</p>
]]></description><link>https://forum.modalai.com/post/15705</link><guid isPermaLink="true">https://forum.modalai.com/post/15705</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Tue, 26 Mar 2024 04:43:44 GMT</pubDate></item><item><title><![CDATA[Reply to New VOXL2 not connecting to Windows machine that connects to Older VOXL2 on Mon, 25 Mar 2024 15:43:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alex-kushleyev" aria-label="Profile: Alex-Kushleyev">@<bdi>Alex-Kushleyev</bdi></a> Thank you the reply.</p>
<p dir="auto">Yes I have the VOXL and multiple VOXL2s. I have used the same cables (USB-A-USB-C).</p>
<p dir="auto">Device Manager sees the QBULK (Qualcomm) device, but cant install any drivers.</p>
<p dir="auto">Both VOXL1 and previous VOXL2 connects without an issue.</p>
<p dir="auto">I have tried ADB kill-server/start-server. then adb devices. Nothing appears.</p>
<p dir="auto">I had the same issue with the VOXL in October and received help from the DEV team. No Luck. CHAT GPT helped and I was able to get the device recognized by adjusting the environmental variables on the Windows machine with success on VOXL and VOXL 2.</p>
<p dir="auto">The new VOXL2 I just received isnt popping up under adb devices, and I cant find the driver for the QBULK device.</p>
<p dir="auto">RDJ</p>
]]></description><link>https://forum.modalai.com/post/15673</link><guid isPermaLink="true">https://forum.modalai.com/post/15673</guid><dc:creator><![CDATA[rdjarvis]]></dc:creator><pubDate>Mon, 25 Mar 2024 15:43:56 GMT</pubDate></item><item><title><![CDATA[Reply to New VOXL2 not connecting to Windows machine that connects to Older VOXL2 on Mon, 25 Mar 2024 15:27:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rdjarvis" aria-label="Profile: rdjarvis">@<bdi>rdjarvis</bdi></a> , please make sure you are using a proper USB3.0 cable (USB-C to USB-A) or try another cable.</p>
<p dir="auto">How are you testing if the device is recognized?  Are you using <code>adb</code> to test this? On some machines you need run <code>sudo adb</code> in order to access VOXL2. (may need to run <code>adb kill-server</code> before trying <code>sudo adb</code>)</p>
]]></description><link>https://forum.modalai.com/post/15670</link><guid isPermaLink="true">https://forum.modalai.com/post/15670</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Mon, 25 Mar 2024 15:27:38 GMT</pubDate></item><item><title><![CDATA[Reply to New VOXL2 not connecting to Windows machine that connects to Older VOXL2 on Mon, 25 Mar 2024 13:45:32 GMT]]></title><description><![CDATA[<p dir="auto">**<br />
Does anyone have a driver for this?</p>
]]></description><link>https://forum.modalai.com/post/15663</link><guid isPermaLink="true">https://forum.modalai.com/post/15663</guid><dc:creator><![CDATA[rdjarvis]]></dc:creator><pubDate>Mon, 25 Mar 2024 13:45:32 GMT</pubDate></item></channel></rss>
