<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rotating the Stereo Cameras 180 degrees]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I am a bit new with the recent SDK is there anyway to rotate the stereo cameras 180 degrees in software or configure files or resources to read up on this? Currently, I realized the stereo cameras are flipped upside down checking them in the VOXL Portal. Bottom is the ceiling and top is the floor</p>
<p dir="auto">Thanks,</p>
<p dir="auto">Jeff</p>
]]></description><link>https://forum.modalai.com/topic/3202/rotating-the-stereo-cameras-180-degrees</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 13:31:12 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3202.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Mar 2024 19:09:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rotating the Stereo Cameras 180 degrees on Tue, 12 Mar 2024 05:36:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jeffrey-mao" aria-label="Profile: Jeffrey-Mao">@<bdi>Jeffrey-Mao</bdi></a></p>
<p dir="auto">I am assuming you are asking about VOXL2 with ov7251 stereo in combo mode (using a single 4-lane camera port)</p>
<p dir="auto">Please check in <code>/usr/lib/camera</code>, you should see two <code>com.qti.sensormodule.ov7251_combo*</code> files. you should remove them and replace them with ones from <code>/usr/share/modalai/chi-cdk/ov7251-combo-flip</code>, making sure you copy the files with the same camera slot index (the number at the end before <code>.bin</code>). Then simply restart <code>voxl-camera-server</code> and the cameras should be rotated 180 (this happens by reversing the direction the images are read from the camera itself, not rotated in software)</p>
]]></description><link>https://forum.modalai.com/post/15234</link><guid isPermaLink="true">https://forum.modalai.com/post/15234</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Tue, 12 Mar 2024 05:36:04 GMT</pubDate></item></channel></rss>
