<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mavros/local_position/odom Z-Axis drift]]></title><description><![CDATA[<p dir="auto">Hello, we are running into an issue where the qvio-server doesn't match with the odometry msgs published on /mavros/local_position/odom on the Starling platform.<br />
I have run plotted the qvio and mavros/local_position odometries over time and there is an extensive divergence with the platform completely still<br />
<img src="/assets/uploads/files/1708383786977-bacfb1df-84c6-43c1-aaf7-29f43e5dd6a8-image-resized.png" alt="bacfb1df-84c6-43c1-aaf7-29f43e5dd6a8-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/topic/3131/mavros-local_position-odom-z-axis-drift</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 03:09:28 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3131.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Feb 2024 23:03:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mavros/local_position/odom Z-Axis drift on Thu, 14 Mar 2024 15:38:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/riccardo-franceschini" aria-label="Profile: Riccardo-Franceschini">@<bdi>Riccardo-Franceschini</bdi></a> We were not able to resolve this issue. However because our control stack is sending TRPY commands to mavros, this didn't come into play at all. The concern for us originated when the drone was taking off significantly higher than commanded. It turned out the propeller coefficients we received from ModalAI were insufficient.</p>
]]></description><link>https://forum.modalai.com/post/15343</link><guid isPermaLink="true">https://forum.modalai.com/post/15343</guid><dc:creator><![CDATA[Kashish Garg]]></dc:creator><pubDate>Thu, 14 Mar 2024 15:38:15 GMT</pubDate></item><item><title><![CDATA[Reply to Mavros/local_position/odom Z-Axis drift on Fri, 23 Feb 2024 18:46:23 GMT]]></title><description><![CDATA[<p dir="auto">Is this indoor our outdoor flight? If you are running indoors, then the barometer should not be the main item used for ekf2_hgt_mode in PX4 and vision should be the detector for height source.</p>
<p dir="auto">Can you attach an altimeter like a benewake lidar or something that is very bare metal and have that sensor become the range finder in the px4 instance?</p>
<p dir="auto">Zach</p>
]]></description><link>https://forum.modalai.com/post/14892</link><guid isPermaLink="true">https://forum.modalai.com/post/14892</guid><dc:creator><![CDATA[Zachary Lowell 0]]></dc:creator><pubDate>Fri, 23 Feb 2024 18:46:23 GMT</pubDate></item><item><title><![CDATA[Reply to Mavros/local_position/odom Z-Axis drift on Fri, 23 Feb 2024 13:03:06 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/moderator" aria-label="Profile: Moderator">@<bdi>Moderator</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/kashish-garg" aria-label="Profile: Kashish-Garg">@<bdi>Kashish-Garg</bdi></a>, we have noticed a similar behavior involving a discrepancy between the qvio server and /mavros/local_position/pose on the z-axis. We have attempted to resolve this by disabling and re-enabling the barometer sensor, but the issue persists. The inconsistency does not always occur and does not appear to be related to aggressive flight behaviors.</p>
]]></description><link>https://forum.modalai.com/post/14884</link><guid isPermaLink="true">https://forum.modalai.com/post/14884</guid><dc:creator><![CDATA[Riccardo Franceschini]]></dc:creator><pubDate>Fri, 23 Feb 2024 13:03:06 GMT</pubDate></item><item><title><![CDATA[Reply to Mavros/local_position/odom Z-Axis drift on Wed, 21 Feb 2024 16:48:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kashish-garg" aria-label="Profile: Kashish-Garg">@<bdi>Kashish-Garg</bdi></a> Does it fly properly without your code in manual and position modes? What does local_position report in QGC when you fly?</p>
<p dir="auto">Are you waiting a long time before taking off? What if you fly first to let EKF2 converge?</p>
<p dir="auto">We don't have enough information to help you, you'll need to start with first principles to debug the system</p>
]]></description><link>https://forum.modalai.com/post/14853</link><guid isPermaLink="true">https://forum.modalai.com/post/14853</guid><dc:creator><![CDATA[Moderator]]></dc:creator><pubDate>Wed, 21 Feb 2024 16:48:57 GMT</pubDate></item><item><title><![CDATA[Reply to Mavros/local_position/odom Z-Axis drift on Tue, 20 Feb 2024 21:39:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kashish-garg" aria-label="Profile: Kashish-Garg">@<bdi>Kashish-Garg</bdi></a> Just bumping to get a hand with this. i have tried disabling Baro sensors and playing with enabling/disabling other sensors. Its clear the mavros/vision/pose is accurate, but on the z-axis in local_position is drifting/showing significant error. Any help is greatly appreciated!</p>
]]></description><link>https://forum.modalai.com/post/14845</link><guid isPermaLink="true">https://forum.modalai.com/post/14845</guid><dc:creator><![CDATA[Kashish Garg]]></dc:creator><pubDate>Tue, 20 Feb 2024 21:39:23 GMT</pubDate></item></channel></rss>
