<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[vscode remote ssh connection not working anymore with voxl sdk 0.9]]></title><description><![CDATA[<p dir="auto">Hello!</p>
<p dir="auto">Is there any workaround that I can do to get vscode remote ssh to work again with voxl? It was working fine a couple of months ago, but now it seems like it's not working anymore. I checked from <a href="https://code.visualstudio.com/docs/remote/linux#_remote-host-container-wsl-linux-prerequisites" rel="nofollow ugc">here</a> and it seems that the current SDK running on my voxl runs on an older Kernel which is not supported anymore for vscode ssh remote connection? I suspect it's due to the VOXL running on an outdated kernel. I'm guessing that because the error that it throws away while trying to connect says:</p>
<pre><code>The remote host may not meet VS Code Server's prerequisites for glibc and libstdc++
/home/root/.vscode-server/bin/903b1e9d8990623e3d7da1df3d33db3e42d80eda/bin/helpers/check-requirements.sh: line 22: getconf: not found
<p dir="auto">Did anyone face a similar issue and manage to solve it?</p>
<p dir="auto">Below is the output of <code>voxl-version</code> command on my current setup.</p>
<pre><code>--------------------------------------------------------------------------------
system-image: 4.0.0
kernel:       #1 SMP PREEMPT Thu Oct 13 17:57:05 UTC 2022 3.18.71-perf
hw version:   VOXL
voxl-suite:   0.9.4
Packages:
Repo: http://voxl-packages.modalai.com/dists/apq8096/sdk-0.9/binary-arm64/
Last Updated: 1970-01-01 00:05:23
List:
	apq8096-dfs-server       0.3.1
	apq8096-imu-server       1.0.3
	apq8096-libpng           1.6.38-1
	apq8096-system-tweaks    0.1.3
	apq8096-tflite           2.8.3-1
	libapq8096-io            0.6.0
	libmodal-cv              0.2.3
	libmodal-exposure        0.0.7
	libmodal-journal         0.2.1
	libmodal-json            0.4.3
	libmodal-pipe            2.6.0
	libvoxl-cci-direct       0.1.5
	libvoxl-cutils           0.1.1
	voxl-camera-calibration  0.2.3
	voxl-camera-server       1.3.5
	voxl-ceres-solver        1.14.0-9
	voxl-cpu-monitor         0.3.0
	voxl-docker-support      1.2.4
	voxl-eigen3              3.4.0
	voxl-gphoto2-server      0.0.10
	voxl-jpeg-turbo          2.1.3-4
	voxl-libgphoto2          0.0.4
	voxl-libuvc              1.0.7
	voxl-logger              0.3.4
	voxl-mapper              0.1.9
	voxl-mavlink             0.1.0
	voxl-mavlink-server      0.2.0
	voxl-modem               0.16.1
	voxl-mongoose            7.7.0-1
	voxl-mpa-to-ros          0.3.6
	voxl-mpa-tools           0.7.6
	voxl-nlopt               2.5.0-4
	voxl-opencv              4.5.5-1
	voxl-portal              0.4.2
	voxl-qvio-server         0.8.2
	voxl-streamer            0.4.1
	voxl-suite               0.9.4
	voxl-system-image        4.0-r0
	voxl-tag-detector        0.0.4
	voxl-tflite-server       0.3.1
	voxl-utils               1.2.2
	voxl-uvc-server          0.1.3
	voxl-vision-px4          1.4.0
	voxl-voxblox             1.1.3
	voxl-vpn                 0.0.6
<p dir="auto">I think an SDK upgrade might be the solution, but I'm looking for a quick fix to tide me over until my current project is completed.</p>
<p dir="auto">Thanks in advance for your help.</p>
]]></description><link>https://forum.modalai.com/topic/3130/vscode-remote-ssh-connection-not-working-anymore-with-voxl-sdk-0-9</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 02:39:37 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3130.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Feb 2024 06:31:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to vscode remote ssh connection not working anymore with voxl sdk 0.9 on Tue, 20 Feb 2024 16:39:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/1674">@aashry</a></p>
<p dir="auto">Yes, definitely update the SDK first! We're many versions past SDK 0.9. Once you do, try again and let me know, I'll be happy to help.</p>
<p dir="auto">Thomas</p>
]]></description><link>https://forum.modalai.com/post/14840</link><guid isPermaLink="true">https://forum.modalai.com/post/14840</guid><dc:creator><![CDATA[[[global:former_user]]]]></dc:creator><pubDate>Tue, 20 Feb 2024 16:39:13 GMT</pubDate></item></channel></rss>
