<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ROS 2 Setup on RB5 Flight]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am currently working on Ubuntu 22.04 (Jammy) with my RB5 flight connected. I am trying to install ROS 2 on my drone. I was only able to find this video (<a href="https://youtube.com/watch?v=zEGe-5EdXC0" rel="nofollow ugc">https://youtube.com/watch?v=zEGe-5EdXC0</a>) for reference that explains how to install ROS and not ROS 2 which would not work for me given the version of Ubuntu I am using. Therefore, I found another video (<a href="https://www.youtube.com/watch?v=onJFNSNiiIU" rel="nofollow ugc">https://www.youtube.com/watch?v=onJFNSNiiIU</a>), this tutorial explains how to install ROS 2 on RB5 Robotics platform. Before I proceed I wanted to know if this would work on my RB5 flight? If not how do you suggest I should proceed. Thank you.</p>
]]></description><link>https://forum.modalai.com/topic/3102/ros-2-setup-on-rb5-flight</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 13:23:13 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3102.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 08 Feb 2024 23:13:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ROS 2 Setup on RB5 Flight on Fri, 09 Feb 2024 18:23:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/4">@tom</a></p>
<p dir="auto">Thank you for your response, I went through the link you mentioned and had the following issues:</p>
<p dir="auto">I had already setup the environment source from the video I mentioned earlier with the line:<br />
source opt/ros/dashing/setup.bash<br />
Is there a way to change it, or would it require a clean install?</p>
<p dir="auto">Moreover, as I am new to this, I am having some trouble understanding the "MPA - to - Ros2" steps mentioned in the document. Can you please elaborate on the command lines I should  execute for the steps mentioned. Thanks again!</p>
]]></description><link>https://forum.modalai.com/post/14672</link><guid isPermaLink="true">https://forum.modalai.com/post/14672</guid><dc:creator><![CDATA[Advait Pandit]]></dc:creator><pubDate>Fri, 09 Feb 2024 18:23:51 GMT</pubDate></item><item><title><![CDATA[Reply to ROS 2 Setup on RB5 Flight on Thu, 08 Feb 2024 23:36:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2169">@Advait-Pandit</a> see here <a href="https://docs.modalai.com/ros2-installation-voxl2/#ros2-installation-on-voxl-2" rel="nofollow ugc">https://docs.modalai.com/ros2-installation-voxl2/#ros2-installation-on-voxl-2</a></p>
]]></description><link>https://forum.modalai.com/post/14650</link><guid isPermaLink="true">https://forum.modalai.com/post/14650</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Thu, 08 Feb 2024 23:36:28 GMT</pubDate></item></channel></rss>
