<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M0125 vs M0151]]></title><description><![CDATA[<p dir="auto">What are the differences between M0125 and M0151? I can't find any references to M0151 in the forums or technical docs.</p>
]]></description><link>https://forum.modalai.com/topic/3009/m0125-vs-m0151</link><generator>RSS for Node</generator><lastBuildDate>Sat, 08 Aug 2026 10:16:02 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3009.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Jan 2024 17:49:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M0125 vs M0151 on Fri, 12 Jan 2024 05:14:00 GMT]]></title><description><![CDATA[<p dir="auto">I want to add that M0125 is no longer being manufactured and we use M0151 as a direct substitute going forward. I'll try to have our product folks clarify the website for that.</p>
]]></description><link>https://forum.modalai.com/post/13887</link><guid isPermaLink="true">https://forum.modalai.com/post/13887</guid><dc:creator><![CDATA[Vinny]]></dc:creator><pubDate>Fri, 12 Jan 2024 05:14:00 GMT</pubDate></item><item><title><![CDATA[Reply to M0125 vs M0151 on Fri, 12 Jan 2024 05:04:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/bendraper" aria-label="Profile: bendraper">@<bdi>bendraper</bdi></a><br />
M0151 is identical to M0125 in all ways except one...<br />
we added series USB caps on the SS lines on both TX and RX.<br />
This was due to the fact we normally include them on the Modem Board (M0090) and we realized that not everyone uses the Modem board, so we needed to make sure some other solution had them in there as well.<br />
If you were experiencing USB3 connection issues with M0125, M0151 should fix that issue.</p>
<p dir="auto">So now our only "gap" on including the series USB caps on SS lines is on VOXL 2 Mini as noted here:<br />
<a href="https://docs.modalai.com/voxl2-mini-connectors/#j3-usb-3-10-pin" rel="nofollow ugc">https://docs.modalai.com/voxl2-mini-connectors/#j3-usb-3-10-pin</a><br />
We do hope to spin that board in the next couple quarters, but no set time frame yet. Thankfully, most robotics use cases are more than satisfied with USB2.</p>
]]></description><link>https://forum.modalai.com/post/13886</link><guid isPermaLink="true">https://forum.modalai.com/post/13886</guid><dc:creator><![CDATA[Vinny]]></dc:creator><pubDate>Fri, 12 Jan 2024 05:04:51 GMT</pubDate></item></channel></rss>
