<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[voxl-camera server 6 (i.e. running ToF, hires, and tracking cameras) not working on VOXL2 SDK 1.1.1]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I just upgraded my VOXL2 from <code>voxl2_platform_0.9.5</code> to <code>voxl2_SDK_1.1.1</code> and noticed that my suite of sensors is not running properly anymore. I have a ToF, hires IMX214, and tracking cameras connected to the VOXL2 and I can see all the cameras streamed correctly on <code>voxl-portal</code> using <code>voxl2_platform_0.9.5</code>.</p>
<p dir="auto">However, as soon as I flash the new voxl2_SDK_1.1.1 (same problem with voxl2_SDK_1.0) only the ToF camera is shown on the <code>voxl-portal</code> but the tracking and hires do not stream data.</p>
<p dir="auto">After checking the <code>voxl-inspect-services</code> I can see that the <code>voxl-camera-service</code> is running correctly even if the tracking and hires cameras are not working.<br />
To double-check the cameras connection I run <code>voxl-camera-service 4</code> (i.e. only hires and tracking ) and I am able to see the tracking and hires camera working on the <code>voxl-portal</code>.<br />
Same if I run only ToF with <code>voxl-camera-service 9</code> as the ToF is correctly streaming while the other cameras are off.</p>
<p dir="auto">The problem arises only once I set <code> voxl-camera-service 6</code> which is supposed to run all the 3 cameras but only the ToF is streamed while the hires and tracking are stuck.</p>
<p dir="auto">To finish double check things I quickly changed the voxl sdk to 0.9.5 and after setting <code> voxl-camera-service 6</code> everything worked fine again and all the 3 cameras were streamed correctly confirming that it was not a hardware problem but a software condition.</p>
<p dir="auto">What can I do to solve this problem? I need to use the new SDK since it has a lot of advantages w.r.t. 0.9.5 but of course I need all the cameras to work properly.</p>
<p dir="auto">Thank you very much for your time and I can send you more info, including screenshots if needed.</p>
<p dir="auto">Thanks a lot</p>
]]></description><link>https://forum.modalai.com/topic/2924/voxl-camera-server-6-i-e-running-tof-hires-and-tracking-cameras-not-working-on-voxl2-sdk-1-1-1</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Mar 2026 03:08:38 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2924.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 06 Dec 2023 00:53:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to voxl-camera server 6 (i.e. running ToF, hires, and tracking cameras) not working on VOXL2 SDK 1.1.1 on Wed, 06 Dec 2023 18:18:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/780">@frafrat</a> Try out <code>voxl-configure-cameras 21</code> which is labeled "old C6"</p>
<p dir="auto">We screwed up the C6 config when moving from SDK 0.9.5 to SDK 1.0.0</p>
<p dir="auto">21 should be equivalent to the old 6</p>
]]></description><link>https://forum.modalai.com/post/13491</link><guid isPermaLink="true">https://forum.modalai.com/post/13491</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Wed, 06 Dec 2023 18:18:00 GMT</pubDate></item></channel></rss>
