<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VOXL2(mini) Serial Number]]></title><description><![CDATA[<p dir="auto">Is there a way to get a unique serial number from VOXL2 hardware? We'd like to do checkouts on each VOXL2/mini platform and track units through assembly and be able to access this in software.  I would imagine this gets overwritten the moment you also do a factory image flash. Just wanted to check!</p>
<p dir="auto">It looks like maybe you guys had something like this working in: <a href="https://docs.modalai.com/Qualcomm-Flight-RB5-sdk-utils/#rb5-flight-versions" rel="nofollow ugc">https://docs.modalai.com/Qualcomm-Flight-RB5-sdk-utils/#rb5-flight-versions</a></p>
<p dir="auto">Perhaps based on: <a href="https://github.com/quic/sample-apps-for-robotics-platforms/blob/master/RB5/linux_kernel_4_x/platform-bringup/Device-info/src/qrb5165_info.c" rel="nofollow ugc">https://github.com/quic/sample-apps-for-robotics-platforms/blob/master/RB5/linux_kernel_4_x/platform-bringup/Device-info/src/qrb5165_info.c</a></p>
<p dir="auto">Or just <code>cat /sys/bus/soc/devices/soc0/serial_number</code> and we associate that with our ModalAI Serial Number.</p>
<p dir="auto">What hardware are you using? VOXL2, VOXL2mini<br />
What version of software are you using? SDK 1.1.1<br />
How have you configured the software? Yes (mpa, etc)<br />
Do you have any logs? Not required for this issue.<br />
Can you share pictures of your setup? If needed -- applies to any VOXL2(mini) based hardware.<br />
Have you looked at the source code? Yes -- did see that the RB5 has a utility that maybe can do this and the SKU utils.</p>
]]></description><link>https://forum.modalai.com/topic/2923/voxl2-mini-serial-number</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 17:13:49 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2923.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 05 Dec 2023 17:49:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to VOXL2(mini) Serial Number on Tue, 05 Dec 2023 18:06:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/601">@Steve-Turner</a> <code>cat /sys/bus/soc/devices/soc0/serial_number</code> is unique and will be unchanged after a factory flash.</p>
<p dir="auto">That is what we use internally in our prod line as a board UID</p>
]]></description><link>https://forum.modalai.com/post/13472</link><guid isPermaLink="true">https://forum.modalai.com/post/13472</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Tue, 05 Dec 2023 18:06:19 GMT</pubDate></item></channel></rss>
