<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Microhard pMDDL 2450 Video Disconnects from QGC after ~15 Seconds]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">Having a strange issue with the Microhard pMDDL 2450 Video Disconnecting from QGC. This issue occurs probably 1 in every 5 power cycles, where the video will cut out. Consistently, without issue, the video will disconnect for a moment after 15 seconds and then reconnect. We've inspected the camera server during these events and there is nothing to indicate that the camera server is going down, we're running SDK 1.0.0 currently. We've tried QGC 4.2.9 and 4.2.8 and have seen similar results.</p>
]]></description><link>https://forum.modalai.com/topic/2861/microhard-pmddl-2450-video-disconnects-from-qgc-after-15-seconds</link><generator>RSS for Node</generator><lastBuildDate>Thu, 12 Mar 2026 11:07:41 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2861.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Nov 2023 21:11:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Microhard pMDDL 2450 Video Disconnects from QGC after ~15 Seconds on Tue, 14 Nov 2023 21:36:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/1949">@Jeremy-Frederick</a></p>
<p dir="auto">I would look at this being a radio thing. I would try</p>
<ol>
<li>get some distance between the radios. if they are too close together there might be too much noise in the system</li>
<li>monitor the radio health when you see the cut out (should be able to see that from the menu of microhard 192.168.168.2)</li>
<li>see if this happens if you connect over straight ethernet (use this cable: <a href="https://www.amazon.com/USB-Ethernet-Adapter-Gigabit-Switch/dp/B09GRL3VCN/ref=sr_1_2_sspa?crid=1ZBIC6DOI8DB5&amp;keywords=ethernet+to+usb+adapter&amp;qid=1699997723&amp;sprefix=ehternet+to+usb%2Caps%2C124&amp;sr=8-2-spons&amp;sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&amp;psc=1" rel="nofollow ugc">https://www.amazon.com/USB-Ethernet-Adapter-Gigabit-Switch/dp/B09GRL3VCN/ref=sr_1_2_sspa?crid=1ZBIC6DOI8DB5&amp;keywords=ethernet+to+usb+adapter&amp;qid=1699997723&amp;sprefix=ehternet+to+usb%2Caps%2C124&amp;sr=8-2-spons&amp;sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&amp;psc=1</a>). If you dont see the issue, i would look closer into how the radios are configured</li>
<li>antennas: make sure you have the right radio antennas suggested by microhard</li>
</ol>
]]></description><link>https://forum.modalai.com/post/13221</link><guid isPermaLink="true">https://forum.modalai.com/post/13221</guid><dc:creator><![CDATA[wilkinsaf]]></dc:creator><pubDate>Tue, 14 Nov 2023 21:36:05 GMT</pubDate></item></channel></rss>
