<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VOXL 2 Unable to connect to QGC after VOXL SDK Update]]></title><description><![CDATA[<p dir="auto">I am running voxl-suite version 1.0.0 on the Sentinel drone, hw version M0054.</p>
<p dir="auto">I recently updated the voxl-suite version, and after that, I am unable to connect to the QGC.</p>
<p dir="auto">Insights:</p>
<ol>
<li>
<p dir="auto">Both the Sentinel drone and the QGC are on the same network.<br />
<code>QGC IP: 192.168.0.178</code><br />
<code>Sentinel drone IP: 192.168.0.196</code></p>
</li>
<li>
<p dir="auto">voxl-vision-hub.conf</p>
</li>
</ol>
<pre><code>{
	"config_file_version":	1,
	"en_localhost_mavlink_udp":	true,
	"localhost_udp_port_number":	14551,
	"en_vio":	true,
	"vio_pipe":	"qvio",
	"secondary_vio_pipe":	"mvio",
	"en_reset_vio_if_initialized_inverted":	true,
	"vio_warmup_s":	3,
	"send_odom_while_failed":	false,
	"horizon_cal_tolerance":	0.5,
	"offboard_mode":	"figure_eight",
	"follow_tag_id":	0,
	"figure_eight_move_home":	true,
	"robot_radius":	0.300000011920929,
	"collision_sampling_dt":	0.1,
	"max_lookahead_distance":	1,
	"en_tag_fixed_frame":	false,
	"fixed_frame_filter_len":	5,
	"en_transform_mavlink_pos_setpoints_from_fixed_frame":	false,
	"en_voa":	true,
	"voa_upper_bound_m":	-0.15000000596046448,
	"voa_lower_bound_m":	0.15000000596046448,
	"voa_voa_memory_s":	1,
	"voa_max_pc_per_fusion":	100,
	"voa_pie_max_dist_m":	20,
	"voa_pie_min_dist_m":	0.25,
	"voa_pie_under_trim_m":	1,
	"voa_pie_threshold":	3,
	"voa_send_rate_hz":	20,
	"voa_pie_slices":	36,
	"voa_pie_bin_depth_m":	0.15000000596046448,
	"voa_inputs":	[{
			"enabled":	true,
			"type":	"point_cloud",
			"input_pipe":	"dfs_point_cloud",
			"frame":	"stereo_l",
			"max_depth":	8,
			"min_depth":	0.300000011920929,
			"cell_size":	0.079999998211860657,
			"threshold":	4,
			"x_fov_deg":	68,
			"y_fov_deg":	56,
			"conf_cutoff":	0
			"enabled":	true,
			"input_pipe":	"stereo_front_pc",
			"frame":	"stereo_front_l",
			"max_depth":	8,
			"threshold":	4,
			"x_fov_deg":	68,
			"y_fov_deg":	56,
			"conf_cutoff":	0
			"enabled":	true,
			"input_pipe":	"stereo_rear_pc",
			"frame":	"stereo_rear_l",
			"max_depth":	8,
			"threshold":	4,
			"x_fov_deg":	68,
			"y_fov_deg":	56,
			"conf_cutoff":	0
			"enabled":	true,
			"type":	"tof",
			"input_pipe":	"tof",
			"frame":	"tof",
			"max_depth":	6,
			"min_depth":	0.15000000596046448,
			"threshold":	3,
			"x_fov_deg":	106.5,
			"y_fov_deg":	85.0999984741211,
			"conf_cutoff":	125
			"enabled":	true,
			"type":	"rangefinder",
			"input_pipe":	"rangefinders",
			"frame":	"body",
			"max_depth":	8,
			"threshold":	4,
			"x_fov_deg":	68,
			"y_fov_deg":	56,
			"conf_cutoff":	0
<ol start="3">
<li>voxl-mavlink-server.conf</li>
</ol>
<pre><code>{
	"primary_static_gcs_ip":	"192.168.0.178",
	"secondary_static_gcs_ip":	"192.168.8.11",
	"onboard_port_to_autopilot":	14556,
	"onboard_port_from_autopilot":	14557,
	"gcs_port_to_autopilot":	14558,
	"gcs_port_from_autopilot":	14559,
	"en_external_uart_ap":	true,
	"autopilot_uart_bus":	1,
	"autopilot_uart_baudrate":	921600,
	"en_external_ap_timesync":	1,
	"en_external_ap_heartbeat":	1,
	"udp_mtu":	0,
	"gcs_timeout_s":	4.5
<ol start="4">
<li>voxl-inspect-services</li>
</ol>
<pre><code> Service Name          |  Enabled  |   Running   |  CPU Usage
 docker-autorun        | Disabled  | Not Running |
 docker-daemon         | Disabled  | Not Running |
 modallink-relink      | Disabled  | Not Running |
 voxl-camera-server    |  Enabled  |   Running   |   106.0%
 voxl-cpu-monitor      |  Enabled  |   Running   |     0.5%
 voxl-dfs-server       | Disabled  | Not Running |
 voxl-feature-tracker  | Disabled  | Not Running |
 voxl-flow-server      | Disabled  | Not Running |
 voxl-imu-server       |  Enabled  |   Running   |     5.1%
 voxl-lepton-server    | Disabled  | Not Running |
 voxl-mavcam-manager   |  Enabled  |   Running   |     0.0%
 voxl-mavlink-server   |  Enabled  |   Running   |     0.6%
 voxl-modem            | Disabled  | Not Running |
 voxl-portal           |  Enabled  |   Running   |    93.6%
 voxl-px4-imu-server   | Disabled  | Not Running |
 voxl-px4              |  Enabled  | Not Running |
 voxl-qvio-server      |  Enabled  |   Running   |    26.0%
 voxl-remote-id        | Disabled  | Not Running |
 voxl-softap           | Disabled  | Not Running |
 voxl-static-ip        | Disabled  | Not Running |
 voxl-streamer         |  Enabled  |   Running   |     0.0%
 voxl-tag-detector     | Disabled  | Not Running |
 voxl-tflite-server    | Disabled  | Not Running |
 voxl-time-sync        | Disabled  | Not Running |
 voxl-uvc-server       | Disabled  | Not Running |
 voxl-vision-hub       |  Enabled  |   Running   |     1.0%
 voxl-wait-for-fs      |  Enabled  |  Completed  |
<ol start="5">
<li>Auto connect enabled inside QGC<br />
<img src="/assets/uploads/files/1692629448501-ce2b0b55-a54b-4bee-8f83-d0506ecab9cb-image.png" alt="ce2b0b55-a54b-4bee-8f83-d0506ecab9cb-image.png" class=" img-fluid img-markdown" /></li>
</ol>
<p dir="auto">Please help.</p>
]]></description><link>https://forum.modalai.com/topic/2582/voxl-2-unable-to-connect-to-qgc-after-voxl-sdk-update</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 01:19:17 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2582.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Aug 2023 14:51:50 GMT</pubDate><ttl>60</ttl></channel></rss>
