<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[OV9782 VIO jumps but does not reset]]></title><description><![CDATA[<p dir="auto">Hi there!</p>
<p dir="auto">We are using the OV9782 with a VOXL2 on sdk1.0 to pass VIO along to an external autopilot. The system is performing well, but when I inspect the logs on the autopilot side I see that the estimate tends to jump sometimes. The qvio pipe does not return resets, lack of features or error codes. The logs on the autopilot sider show this:<br />
<img src="/assets/uploads/files/1690991402879-52859acd-8f17-4e65-9019-1f616891c1c5-image.png" alt="52859acd-8f17-4e65-9019-1f616891c1c5-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Those small jumps are causing a lane switch in the EKF. From time to time it will cause it to throw a failsafe.</p>
<p dir="auto">Similar flights with the OV7251 camera do not show the same problem. Although we do get hard resets in that case.</p>
<p dir="auto">Is the higher resolution camera making the system drop frames or messing with the timing? Should the parameters in the qvio-server change for this camera? Any help/pointers/ideas would be much appreciated.</p>
<p dir="auto">Cheers!</p>
]]></description><link>https://forum.modalai.com/topic/2524/ov9782-vio-jumps-but-does-not-reset</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 16:41:16 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2524.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 02 Aug 2023 15:58:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to OV9782 VIO jumps but does not reset on Fri, 04 Aug 2023 13:27:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/moderator" aria-label="Profile: Moderator">@<bdi>Moderator</bdi></a> will try to on our next flight. Do you have an easy way to trigger a capture when certain conditions are met? It is hard to correlate hundred of images to the autopilot logs to find these instances. We are working on streaming the qvio-overlay as an RTSP stream down to the GCS. That might be easier.</p>
<p dir="auto">Unrelated question. Can the VIO algorithm use the colored images coming from the camera? If yes, is there an advantage at all?</p>
]]></description><link>https://forum.modalai.com/post/11709</link><guid isPermaLink="true">https://forum.modalai.com/post/11709</guid><dc:creator><![CDATA[david.moro]]></dc:creator><pubDate>Fri, 04 Aug 2023 13:27:16 GMT</pubDate></item><item><title><![CDATA[Reply to OV9782 VIO jumps but does not reset on Wed, 02 Aug 2023 21:54:01 GMT]]></title><description><![CDATA[<p dir="auto">Can you screen capture the qvio-overlay? That might show some clues</p>
<p dir="auto"><code>voxl-logger --preset_odometry</code> might be useful as well</p>
]]></description><link>https://forum.modalai.com/post/11677</link><guid isPermaLink="true">https://forum.modalai.com/post/11677</guid><dc:creator><![CDATA[Moderator]]></dc:creator><pubDate>Wed, 02 Aug 2023 21:54:01 GMT</pubDate></item></channel></rss>
