<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[HAL not detecting any cameras in SDK version 1.0.0 but does under 0.9.5]]></title><description><![CDATA[<p dir="auto">Hello!<br />
I am using a Voxl2 that got shipped with version 0.9.5 of the SDK. I verified that my cameras (one M0061 imx412 and two M0072 ov7251 image sensors) are working before upgrading the SDK. Under version 0.9.5, running <code>voxl-camera-server -l</code> listed all my cameras, but after upgrading to 1.0.0 and running this command again, I am prompted with:</p>
<pre><code>DEBUG:   Attempting to open the hal module
DEBUG:   ----------- Number of cameras: 0
DEBUG:   Note: This list comes from the HAL module and may not be indicative
DEBUG:   	of configurations that have full pipelines
DEBUG:   Number of cameras: 0
<p dir="auto">If I downgrade again, the cameras show up, so I'm sure that they didn't die. Even if I don't configure anything <code>voxl-camera-server -l</code> shows my connected cameras under 0.9.5, so I don't think camera configurations are at fault here, I have still tried to use the exact same configs and ran <code>voxl-configure-sku</code> and <code>voxl-configure-mpa</code>, but to no avail.</p>
<p dir="auto">Following <a href="https://docs.modalai.com/voxl-hi-res-sensor-user-guide/" rel="nofollow ugc">instructions to read from hi-res sensors</a> I took a look at the dmesg output and found this:</p>
<pre><code>[    1.908280] cam_cc-kona ad00000.qcom,camcc: Registered CAM CC clocks
[    2.118543] CAM_INFO: CAM-SMMU: cam_smmu_get_memory_regions_info: 3730 [icp] : Discard region specified [0xdff00000 0xe0200000] in [0x10c00000 0xfef00000]
[    2.124113] CAM_INFO: CAM-ISP: cam_vfe_bus_ver3_init_hw: 3659 Overriding clock gating at bus input
[    2.124118] CAM_INFO: CAM-ISP: cam_vfe_top_ver3_init_hw: 246 Disable clock gating at IFE top
[    2.125415] CAM_INFO: CAM-ISP: cam_vfe_bus_ver3_init_hw: 3659 Overriding clock gating at bus input
[    2.125420] CAM_INFO: CAM-ISP: cam_vfe_top_ver3_init_hw: 246 Disable clock gating at IFE top
[    2.125873] CAM_INFO: CAM-UTIL: cam_soc_util_get_option_clk_by_name: 559 No clk data for ife_dsp_clk
[    2.125882] CAM_WARN: CAM-ISP: cam_vfe_init_soc_resources: 154 Option clk get failed with rc -22
[    2.126427] CAM_INFO: CAM-ISP: cam_vfe_bus_ver3_init_hw: 3659 Overriding clock gating at bus input
[    2.126433] CAM_INFO: CAM-ISP: cam_vfe_top_ver3_init_hw: 246 Disable clock gating at IFE top
[    2.126819] CAM_INFO: CAM-UTIL: cam_soc_util_get_option_clk_by_name: 559 No clk data for ife_dsp_clk
[    2.126823] CAM_WARN: CAM-ISP: cam_vfe_init_soc_resources: 154 Option clk get failed with rc -22
[    2.127334] CAM_INFO: CAM-ISP: cam_vfe_bus_ver3_init_hw: 3659 Overriding clock gating at bus input
[    2.127339] CAM_INFO: CAM-ISP: cam_vfe_top_ver3_init_hw: 246 Disable clock gating at IFE top
[    2.127765] CAM_INFO: CAM-UTIL: cam_soc_util_get_option_clk_by_name: 559 No clk data for ife_dsp_clk
[    2.127768] CAM_WARN: CAM-ISP: cam_vfe_init_soc_resources: 154 Option clk get failed with rc -22
[    2.128271] CAM_INFO: CAM-ISP: cam_vfe_bus_ver3_init_hw: 3659 Overriding clock gating at bus input
[    2.128276] CAM_INFO: CAM-ISP: cam_vfe_top_ver3_init_hw: 246 Disable clock gating at IFE top
[    2.128656] CAM_INFO: CAM-UTIL: cam_soc_util_get_option_clk_by_name: 559 No clk data for ife_dsp_clk
[    2.128658] CAM_WARN: CAM-ISP: cam_vfe_init_soc_resources: 154 Option clk get failed with rc -22
[    2.129158] CAM_INFO: CAM-ISP: cam_vfe_bus_ver3_init_hw: 3659 Overriding clock gating at bus input
[    2.129162] CAM_INFO: CAM-ISP: cam_vfe_top_ver3_init_hw: 246 Disable clock gating at IFE top
[    2.129557] CAM_INFO: CAM-UTIL: cam_soc_util_get_option_clk_by_name: 559 No clk data for ife_dsp_clk
[    2.129560] CAM_WARN: CAM-ISP: cam_vfe_init_soc_resources: 154 Option clk get failed with rc -22
[    2.130062] CAM_INFO: CAM-ISP: cam_vfe_bus_ver3_init_hw: 3659 Overriding clock gating at bus input
[    2.130066] CAM_INFO: CAM-ISP: cam_vfe_top_ver3_init_hw: 246 Disable clock gating at IFE top
[    2.130543] CAM_ERR: CAM-ISP: cam_ife_hw_mgr_init: 8806 Offline IFE thresholds max 720000000 nom 560000000  min360000000
[    2.130547] CAM_ERR: CAM-ISP: cam_ife_hw_mgr_init: 8806 Offline IFE thresholds max 720000000 nom 560000000  min360000000
[    2.130633] CAM_ERR: CAM-ISP: cam_isp_context_debug_register: 5406 failed to create dentry
[    2.130646] CAM_ERR: CAM-ISP: cam_isp_context_debug_register: 5406 failed to create dentry
[    2.130659] CAM_ERR: CAM-ISP: cam_isp_context_debug_register: 5406 failed to create dentry
[    2.130671] CAM_ERR: CAM-ISP: cam_isp_context_debug_register: 5406 failed to create dentry
[    2.130684] CAM_ERR: CAM-ISP: cam_isp_context_debug_register: 5406 failed to create dentry
[    2.130697] CAM_ERR: CAM-ISP: cam_isp_context_debug_register: 5406 failed to create dentry
[    2.130709] CAM_ERR: CAM-ISP: cam_isp_context_debug_register: 5406 failed to create dentry
[    2.130721] CAM_ERR: CAM-ISP: cam_isp_context_debug_register: 5406 failed to create dentry
[    2.130733] CAM_ERR: CAM-ISP: cam_isp_context_debug_register: 5406 failed to create dentry
[    2.130736] CAM_INFO: CAM-ISP: cam_isp_dev_probe: 163 Camera ISP probe complete
[    2.131032] CAM_INFO: CAM: cam_res_mgr_probe: 685 Enable shared gpio support.
[    2.131600] CAM_INFO: CAM-CCI: cam_cci_platform_probe: 454 Device Type :0
[    2.131995] CAM_INFO: CAM-CCI: cam_cci_platform_probe: 454 Device Type :1
[    2.133150] CAM_WARN: CAM-ICP: cam_a5_get_dt_properties: 46 QoS need not be set
[    2.134670] CAM_INFO: CAM-JPEG: cam_jpeg_dev_probe: 162 Camera JPEG probe complete
[    2.415770] CAM_ERR: CAM-CCI: cam_cci_assign_fops: 528 Invalid dev node:000000004a8e8296 offset: 0
[    5.438602] CAM_INFO: CAM-HFI: cam_hfi_init: 878 Init IO1 : [0x10c00000 0xcf300000] IO2 [0xe0200000 0x1ed00000]
[    5.448912] CAM_INFO: CAM-ICP: cam_icp_mgr_hw_open: 3879 FW download done successfully
[    5.449114] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI  :QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079,OEM_IMAGE_VERSION_STRING=CRM,BUILD_TIME: Oct 17 2019 05:49:19,CACHE_ENABLED at icphostinterface.c:636 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
[    5.449116] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI  :ELF variant: CACHE-ENABLED:T480:API_V2:USE_CDM_1_1: , API version: 0x2000049 at icphostinterface.c:637 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
[    5.555516] CAM_ERR: CAM-CCI: cam_cci_irq: 264 Base:        pK-error, M1_Q1 NACK ERROR: 0x40000000
[    5.555538] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0x34:
[    5.555540] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
[    5.555542] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
[    5.555543] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x577:
[    5.683988] CAM_ERR: CAM-CCI: cam_cci_irq: 258 Base:        pK-error, M1_Q0 NACK ERROR: 0x20000000
[    5.684050] CAM_ERR: CAM-CCI: cam_cci_wait: 270 failed rc -22
[    5.684054] CAM_ERR: CAM-CCI: cam_cci_transfer_end: 345 failed rc -22
[    5.684057] CAM_ERR: CAM-CCI: cam_cci_data_queue: 870 Slave: 0x34 failed rc -22
[    5.684059] CAM_ERR: CAM-CCI: cam_cci_i2c_write: 1450 failed rc: -22
[    5.684063] CAM_ERR: CAM-SENSOR: cam_cci_i2c_write_table_cmd: 123 Failed rc = -22
[    5.768082] CAM_ERR: CAM-SENSOR: cam_sensor_imx678_disable_standby: 816 [Setting register to standby] camera_io_dev_write failed: rc=-22
[    5.768221] CAM_ERR: CAM-CCI: cam_cci_irq: 264 Base:        pK-error, M1_Q1 NACK ERROR: 0x40000000
[    5.768249] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0x34:
[    5.768254] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
[    5.768258] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
[    5.768266] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0xa602:
[    5.813458] CAM_WARN: CAM-CRM: cam_req_mgr_close: 160 release invoked associated userspace process has died
<p dir="auto">I don't know why it seems to fail the important read..</p>
]]></description><link>https://forum.modalai.com/topic/2518/hal-not-detecting-any-cameras-in-sdk-version-1-0-0-but-does-under-0-9-5</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Mar 2026 03:05:14 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2518.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Aug 2023 08:16:51 GMT</pubDate><ttl>60</ttl></channel></rss>
