<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Does VOXL CAM work with generic PX4 autopilot?]]></title><description><![CDATA[<p dir="auto">Does VOXL CAM work with generic PX4 autopilot? Does it has to work with with VOXL flight controller or companion computer? How accurate the position and angles will be when used indoor? Does it work well in narrow warehouse which has a lot of plastic wraps that could reflect lights?</p>
]]></description><link>https://forum.modalai.com/topic/2501/does-voxl-cam-work-with-generic-px4-autopilot</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 08:02:51 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2501.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 28 Jul 2023 19:44:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Does VOXL CAM work with generic PX4 autopilot? on Tue, 01 Aug 2023 13:03:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/moderator" aria-label="Profile: Moderator">@<bdi>Moderator</bdi></a> Thanks for your response. I didn't realize that the VOXL CAM is actually a combination of VOXL companion computer and camera module. My drone uses Pixhawk 6C autopilot, I have a companion computer connected to its TELEM2, now I am looking for tracking camera. If I use VOXL CAM, will the VOXL computer conflict with the computer that I am currently using? If not, which port can I connect VOXL CAM to? And what settings need to be made, do you have a manual/instruction for the setup?</p>
]]></description><link>https://forum.modalai.com/post/11592</link><guid isPermaLink="true">https://forum.modalai.com/post/11592</guid><dc:creator><![CDATA[droneGuy]]></dc:creator><pubDate>Tue, 01 Aug 2023 13:03:15 GMT</pubDate></item><item><title><![CDATA[Reply to Does VOXL CAM work with generic PX4 autopilot? on Fri, 28 Jul 2023 19:47:10 GMT]]></title><description><![CDATA[<p dir="auto">There is documentation regarding connecting VOXL to an external flight controller here: <a href="https://docs.modalai.com/how-to-connect-voxl-to-pixhawk/" rel="nofollow ugc">https://docs.modalai.com/how-to-connect-voxl-to-pixhawk/</a></p>
<p dir="auto">VIO performance is entirely environment dependent, so there is no way to promise any specific answer. In a high-feature, well-lit environment it generally drifts about 1.5% over distance.</p>
]]></description><link>https://forum.modalai.com/post/11531</link><guid isPermaLink="true">https://forum.modalai.com/post/11531</guid><dc:creator><![CDATA[Moderator]]></dc:creator><pubDate>Fri, 28 Jul 2023 19:47:10 GMT</pubDate></item></channel></rss>
