<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New unit fails UART Loopback test]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">We recently purchased a Voxl Deck (not our first) and our application (which has been running great on other units) wasn't working - specifically we weren't getting anything on the UART line. Sure enough, we ran the included loopback test on UART 12 and it failed - the other ports passed.</p>
<p dir="auto">Needing only 2 uarts, we moved our application to the other two UART ports... But we find that if one is in use, the other drops out. I assume this is a hardware issue with our unit. Furthermore, we ideally need all three available UART ports for our application so one and a half is a non-starter.</p>
<p dir="auto">As part of our setup we flash the system image and the issue persists after a re-flash. An identical software setup has worked just fine on multiple other Voxl Decks.</p>
<p dir="auto">Assuming this to be a hardware defect, we requested a return in private support channel but were instructed to post here instead. Can someone either facilitate a return/replacement or provide other guidance?</p>
]]></description><link>https://forum.modalai.com/topic/2444/new-unit-fails-uart-loopback-test</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 15:54:01 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2444.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Jul 2023 02:38:50 GMT</pubDate><ttl>60</ttl></channel></rss>
