<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Limit cameras problem]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">On a VOXL-CAM, I am trying to use <code>voxl-configure-cameras 2</code> to reduce the CPU usage. This is the output:<br />
<img src="/assets/uploads/files/1688995912776-d39f5224-ec89-46e2-86ec-28d515aeacf2-image.png" alt="d39f5224-ec89-46e2-86ec-28d515aeacf2-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">But when I run <code>voxl-inspect-cam -a</code>, all of the cameras are used:<br />
<img src="/assets/uploads/files/1688995980040-602a92c5-1aa1-48fb-8292-f86ac2d033f9-image-resized.png" alt="602a92c5-1aa1-48fb-8292-f86ac2d033f9-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">How can I configure it so that I use "tracking only"?</p>
<p dir="auto">Thanks in advance!</p>
]]></description><link>https://forum.modalai.com/topic/2390/limit-cameras-problem</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 07:32:59 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2390.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 10 Jul 2023 13:39:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Limit cameras problem on Tue, 11 Jul 2023 08:29:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aashry" aria-label="Profile: aashry">@<bdi>aashry</bdi></a> Thank you for your quick reply. It is working now!</p>
]]></description><link>https://forum.modalai.com/post/11108</link><guid isPermaLink="true">https://forum.modalai.com/post/11108</guid><dc:creator><![CDATA[SHofmeester]]></dc:creator><pubDate>Tue, 11 Jul 2023 08:29:38 GMT</pubDate></item><item><title><![CDATA[Reply to Limit cameras problem on Mon, 10 Jul 2023 19:59:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shofmeester" aria-label="Profile: SHofmeester">@<bdi>SHofmeester</bdi></a> I think you can choose the default configuration for your hardware from <code>voxl-configure-cameras</code> , and then you can turn off the cameras you don't want to use by modifying the config file directly at <code>etc/modalai/voxl-camera-server.conf</code> , and change the flags for the cameras you don't want to use to be <code>false</code> instead of true.</p>
]]></description><link>https://forum.modalai.com/post/11095</link><guid isPermaLink="true">https://forum.modalai.com/post/11095</guid><dc:creator><![CDATA[aashry]]></dc:creator><pubDate>Mon, 10 Jul 2023 19:59:36 GMT</pubDate></item></channel></rss>
