<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Heating and Excessive CPU usage in VOXL 2 under normal operation]]></title><description><![CDATA[<p dir="auto">Greetings,<br />
I am seeing CPU loads of 50-60 percent while idling in voxl2. I have voxl camera server (which is handling hires (streaming at 480p only to portal)+trecking+ToF sensors), voxl qvio server and mavlink running. Is this kind of cpu usage stat normal? The voxl2 is heating up well over 80C in a room with 24C temp  in this situation and a 25mm fan is not helping the situation much.<br />
I wanted to ask if this is something to be worried about?</p>
<p dir="auto">Your advice regarding this will be highly appreciated.<br />
Thank you.</p>
]]></description><link>https://forum.modalai.com/topic/2267/heating-and-excessive-cpu-usage-in-voxl-2-under-normal-operation</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 12:09:59 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2267.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Jun 2023 14:52:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Heating and Excessive CPU usage in VOXL 2 under normal operation on Thu, 27 Jul 2023 06:50:38 GMT]]></title><description><![CDATA[<p dir="auto">Similar to you both:</p>
<pre><code> voxl-camera-server    |  Enabled  |   Running   |    71.1%
 voxl-cpu-monitor      |  Enabled  |   Running   |     0.1%
 voxl-dfs-server       | Disabled  | Not Running |
 voxl-feature-tracker  | Disabled  | Not Running |
 voxl-flow-server      | Disabled  | Not Running |
 voxl-imu-server       |  Enabled  |   Running   |     1.5%
 voxl-lepton-server    | Disabled  | Not Running |
 voxl-mavcam-manager   | Disabled  | Not Running |
 voxl-mavlink-server   |  Enabled  |   Running   |     0.2%
 voxl-modem            | Disabled  | Not Running |
 voxl-portal           |  Enabled  |   Running   |    60.1%
<p dir="auto">This is with HIRES, Tracking, Stereo on SDK 1.0. I also disabled large encoding on the HIRES from the camera server. Just bumping to see if this is expected.</p>
]]></description><link>https://forum.modalai.com/post/11491</link><guid isPermaLink="true">https://forum.modalai.com/post/11491</guid><dc:creator><![CDATA[Steve Turner]]></dc:creator><pubDate>Thu, 27 Jul 2023 06:50:38 GMT</pubDate></item><item><title><![CDATA[Reply to Heating and Excessive CPU usage in VOXL 2 under normal operation on Thu, 22 Jun 2023 08:43:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jyotish-kumar" aria-label="Profile: Jyotish-Kumar">@<bdi>Jyotish-Kumar</bdi></a> Same Issues here. Running camera server with 4 tracking cams and px4 flight stack with mavlink server and reaching over 90 Degree CPU temp.</p>
]]></description><link>https://forum.modalai.com/post/10746</link><guid isPermaLink="true">https://forum.modalai.com/post/10746</guid><dc:creator><![CDATA[Benjamin Ruks]]></dc:creator><pubDate>Thu, 22 Jun 2023 08:43:01 GMT</pubDate></item></channel></rss>
