<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Issues with SFTP with python]]></title><description><![CDATA[<p dir="auto">drone m500<br />
If I try to use scp command line (which use ssh) in ubuntu terminal to copy a file into the drone it is possible and does not give any error but while trying to use SFTP in python with paramiko or pysftp throws an error and does not allow me to send it through the own drones's wifi.</p>
<p dir="auto">Port 22 for SSH is open in drone. Turned off and back on tried. Hostname, password and usarname double-checked.</p>
<p dir="auto">Any other idea of how can I copy/transfer a file from the PC to the drone? I want to automate this process</p>
<pre><code># create SSH client
client = paramiko.SSHClient()
client.set_missing_host_key_policy(paramiko.AutoAddPolicy())
 # connect to the drone
 client.connect(hostname=hostname, username=username, password=password)
 print("SSH connection established")
sftp = client.open_sftp()
sftp.put(file_path,drone_path)
sftp.close()
time.sleep(2)
print("File in drone")
# close the SSH connection
client.close()
print("SSH connection closed")
]]></description><link>https://forum.modalai.com/topic/2090/issues-with-sftp-with-python</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 20:13:04 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2090.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Apr 2023 21:35:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Issues with SFTP with python on Sun, 23 Apr 2023 12:23:29 GMT]]></title><description><![CDATA[<p dir="auto">I believe you first need to enable SFTP functionality in ssh server on the drone, for example <a href="https://www.pcwdld.com/setup-sftp-server-on-ubuntu" rel="nofollow ugc">https://www.pcwdld.com/setup-sftp-server-on-ubuntu</a> seems to provide instructions (i did not verify the correctness of the instructions).</p>
<p dir="auto">A better solution, in my opinion, would be to use <code>scp</code> from your python client. You can copy the ssh key directly to the drone, so you don't have to enter the password in the script. Then you could call the <code>scp</code> command directly from Python using a <code>system</code> call or using Paramiko like in this example : <a href="https://stackoverflow.com/questions/250283/how-to-scp-in-python" rel="nofollow ugc">https://stackoverflow.com/questions/250283/how-to-scp-in-python</a> . Installing the ssh key on the drone will avoid storing plain text password on your PC.</p>
<p dir="auto">Is there a reason why you are trying SFTP instead of SCP?</p>
]]></description><link>https://forum.modalai.com/post/9796</link><guid isPermaLink="true">https://forum.modalai.com/post/9796</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Sun, 23 Apr 2023 12:23:29 GMT</pubDate></item></channel></rss>
