<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Possible throughput problem with MPA - multiple cameras ?]]></title><description><![CDATA[<p dir="auto">We are having problems running multiple cameras over MPA. System image 0.9 (4.0).<br />
We are running 2 UVC cameras via voxl-uvc-server and one TOF via voxl-camera server.</p>
<p dir="auto">One UVC camera is a color, 640x480 @ 30fps frame. The other is a RAW16 of 160x120 @ 5fps.<br />
The TOF is 224x172 @ 10 fps, gray image + depth.</p>
<p dir="auto">When we try to run all three together, we start to get problems. Running each one alone works fine.<br />
The problems are usually that the camera/uvc server either gets stuck (frames are not published to the pipe) or the server crashes.</p>
<p dir="auto">It seems like there is some sort of throughput problem, where the MPA cannot handle these 4 pipes simultaneously.</p>
<p dir="auto">Any suggestions?<br />
Unfortunately we cannot change the FPS of the color camera, as the resolution and fps are native.</p>
]]></description><link>https://forum.modalai.com/topic/1991/possible-throughput-problem-with-mpa-multiple-cameras</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 10:38:09 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1991.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Mar 2023 11:35:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Possible throughput problem with MPA - multiple cameras ? on Thu, 23 Mar 2023 13:58:53 GMT]]></title><description><![CDATA[<p dir="auto">Each service is using MPA, so there are many pipes going at any given time. With two TOF, you are likely overheating the CPU</p>
<p dir="auto">Do you have airflow on the board?<br />
Are you using voxl-inspect-cpu to monitor how hot you are getting the CPU?</p>
]]></description><link>https://forum.modalai.com/post/9253</link><guid isPermaLink="true">https://forum.modalai.com/post/9253</guid><dc:creator><![CDATA[Chad Sweet]]></dc:creator><pubDate>Thu, 23 Mar 2023 13:58:53 GMT</pubDate></item></channel></rss>
