<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Extension board]]></title><description><![CDATA[<p dir="auto">Hello everyone:</p>
<p dir="auto">I am planning on adding a gimbal for my drone for that I would need either another serial port or PWM capabilities. I found <a href="https://www.modalai.com/products/voxl2-io?variant=40610514206771" rel="nofollow ugc">this</a> I/O board for the VOXL 2. I wanted to know if this could be used to control a gimbals using PX4 using the PWM outputs. I read the docs and it seems to plug into the J19 connector where the GPS and spektrum receiver plug in on the flight deck. Could I modifiy the connector to use this board alongside the GPS as I can connect the receiver to the expansion board?</p>
<p dir="auto">Thanks in advanced <img src="https://forum.modalai.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=524adfeda5f" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
]]></description><link>https://forum.modalai.com/topic/1932/extension-board</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 15:25:52 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1932.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 Mar 2023 17:48:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Extension board on Fri, 10 Mar 2023 18:17:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/jose-alfredo-rosas-cordova" aria-label="Profile: Jose-Alfredo-Rosas-Cordova">@<bdi>Jose-Alfredo-Rosas-Cordova</bdi></a><br />
Yes, absolutely.<br />
That is one of the use-cases to have this along with GPS/Mag/RC.</p>
<p dir="auto">These cables are all related to those functions and can help you make whatever custom adapter you may need:<br />
<a href="https://docs.modalai.com/cable-datasheets/#mcbl-00061" rel="nofollow ugc">https://docs.modalai.com/cable-datasheets/#mcbl-00061</a><br />
<a href="https://docs.modalai.com/cable-datasheets/#mcbl-00064" rel="nofollow ugc">https://docs.modalai.com/cable-datasheets/#mcbl-00064</a><br />
<a href="https://docs.modalai.com/cable-datasheets/#mcbl-00070" rel="nofollow ugc">https://docs.modalai.com/cable-datasheets/#mcbl-00070</a></p>
<p dir="auto">Note, MCBL-00070 is brand new so we'll have the purchase link up soon.</p>
<p dir="auto">This guide also tells you some tips on how to modify these cables to your needs:<br />
<a href="https://docs.modalai.com/cable-userguides/" rel="nofollow ugc">https://docs.modalai.com/cable-userguides/</a><br />
So, if we do not have exactly what you need, you can easily modify some others to get you there.</p>
<p dir="auto">Hope this helps!<br />
Thanks</p>
]]></description><link>https://forum.modalai.com/post/8973</link><guid isPermaLink="true">https://forum.modalai.com/post/8973</guid><dc:creator><![CDATA[Vinny]]></dc:creator><pubDate>Fri, 10 Mar 2023 18:17:54 GMT</pubDate></item></channel></rss>
