<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Telemetry interfering with UART?]]></title><description><![CDATA[<p dir="auto">I have a custom module running with modified PX4 firmware on the FlightCore.  It uses the UART on J4 to receive data from a custom sensor board.  This has been working for over a year.</p>
<p dir="auto">In default.cmake I comment out TEL3:/dev/ttyS1 so that I can use it for my sensor board.</p>
<p dir="auto">We had previously used the RFD900 with the FlightCore for updating some parameters, but since we are an underwater system we had removed it a long time ago to save power.</p>
<p dir="auto">For an upcoming customer demo in the field I was asked to install the RFD900 so that during testing the system could be removed from the water and verified to still be operational without opening up the system.</p>
<p dir="auto">I have been having intermittent issues with getting data from my custom sensor board whenever the radio is connected.  After a very short time the topic stops publishing and using listener I just see stale data.  The data is also being published to the datalog and I see the data stop, while other data from the system continues to log.</p>
<p dir="auto">I thought maybe this was a power issue, so instead of powering my sensor board from the 5V on the J4 connector I am powering directly from the battery, but am still seeing the issue.</p>
<p dir="auto">As far as I can tell, no one else is using ttyS1.  Is there an issue with having high data bandwidth on both ttyS1 and ttyS6 (UART7 on J5) that would kill my connection?</p>
]]></description><link>https://forum.modalai.com/topic/1911/telemetry-interfering-with-uart</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 00:02:30 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1911.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Mar 2023 15:00:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Telemetry interfering with UART? on Mon, 06 Mar 2023 21:08:19 GMT]]></title><description><![CDATA[<p dir="auto">I have discovered that the entire module seems to stop. I had been assuming it was the UART that was failing.  Is there some PX4 setting where when a telemetry link occurs that something would stop/pause running modules?</p>
]]></description><link>https://forum.modalai.com/post/8857</link><guid isPermaLink="true">https://forum.modalai.com/post/8857</guid><dc:creator><![CDATA[Andrew Keefe]]></dc:creator><pubDate>Mon, 06 Mar 2023 21:08:19 GMT</pubDate></item><item><title><![CDATA[Reply to Telemetry interfering with UART? on Mon, 06 Mar 2023 15:44:26 GMT]]></title><description><![CDATA[<p dir="auto">When I stream the data in the terminal by launching the module manually, connected via USB to QGC, I see the stream.  I then plug my base station radio in, and as soon as it gives me a blinking red light the data stream stops.</p>
<p dir="auto">I am using RFD900x radios in a multi-radio network.  Previously when I tested these radios I was using RFD900+ in a single set.</p>
]]></description><link>https://forum.modalai.com/post/8843</link><guid isPermaLink="true">https://forum.modalai.com/post/8843</guid><dc:creator><![CDATA[Andrew Keefe]]></dc:creator><pubDate>Mon, 06 Mar 2023 15:44:26 GMT</pubDate></item><item><title><![CDATA[Reply to Telemetry interfering with UART? on Mon, 06 Mar 2023 15:30:14 GMT]]></title><description><![CDATA[<p dir="auto">I set the module to no longer run in the background. When I use MAVLink Console to launch the module and the base station radio is disconnected (but not the radio connected to the FlightCore) I can run the module and it runs fine.</p>
<p dir="auto">When I have the radio link connected and I use MAVLink Console to launch the module I get an error in trying to configure the port.</p>
<p dir="auto"><img src="/assets/uploads/files/1678116609913-a9c76b74-2f54-4af5-a02b-17a287ebb871-image.png" alt="a9c76b74-2f54-4af5-a02b-17a287ebb871-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/post/8841</link><guid isPermaLink="true">https://forum.modalai.com/post/8841</guid><dc:creator><![CDATA[Andrew Keefe]]></dc:creator><pubDate>Mon, 06 Mar 2023 15:30:14 GMT</pubDate></item></channel></rss>
