<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Listing/Changing Camera Resolution]]></title><description><![CDATA[<p dir="auto">tl;dr; How do I find supported camera resolutions? I'm trying to get the maximum resolution possible out of the IMX412.</p>
<p dir="auto"><strong>Details:</strong><br />
I have an IMX412 which theoretically can output 4056x3040 resolution (e.g. listed <a href="https://www.framos.com/wp-content/uploads/media/pdf/62/a7/f6/oNCmVuZHN0cmVhbQ0KZW5kb2JqDQp4cmVmDQowIDc0Mg0KMDAwMDAwMDA4NyA2NTUzNSBmDQowMDAwMDAwMDE3IDAwMDAwIG4NCjAwMDAwMDAxNjggMDAwMDAgbg0KMDAwMDAwMDIzOCAwMDAwMCBuDQowMDAwMDAwNzE5IDAwMDAwIG4NCj.pdf" rel="nofollow ugc">here</a>) or when running the voxl-camera-server with verbose output:</p>
<pre><code>voxl2:/$ voxl-camera-server -d0
No secondary id found for camera: hires, assuming mono
------ voxl-camera-server: Starting camera server
Attempting to open the hal module
SUCCESS: Camera module opened on attempt 0
----------- Number of cameras: 1
Stats for camera: 0:
ANDROID_SCALER_AVAILABLE_RAW_SIZES:
	4056x3040, 4056x2288, 3040x3040, 3040x3040, 3040x3040, 3040x3040, 4056x3040, 4056x3040, 4056x2288, 4056x2288, 4056x2288, 4056x2288, 2028x1112, 1920x1080,
ANDROID_SCALER_AVAILABLE_PROCESSED_SIZES:
ANDROID_SENSOR_INFO_SENSITIVITY_RANGE
	min = 54
	max = 863
ANDROID_SENSOR_MAX_ANALOG_SENSITIVITY
	862
ANDROID_SENSOR_INFO_EXPOSURE_TIME_RANGE
	min = 0ns
	max = 232155075ns
<p dir="auto">However, actually setting this resolution in voxl-camera-server.conf causes the following error:</p>
ERROR: Camera 0 failed to find supported preview config: 4056x3040
Encountered error starting camera: hires, exiting
<p dir="auto">Taking a look at the code, it looks like the actual configurations being searched are the ANDROID_SCALER_AVAILABLE_STREAM_CONFIGURATIONS. Adding a verbose output lists the following resolutions available, including the desired 4056x3040 resolution, albeit in different formats from the apparently desired 34:</p>
<pre><code>ANDROID_SCALER_AVAILABLE_STREAM_CONFIGURATIONS
format: 34	4000x3000	0==0
format: 34	4000x3000	1==0
format: 35	4000x3000	0==0
format: 35	4000x3000	1==0
format: 33	4000x3000	0==0
format: 34	3840x2160	0==0
format: 34	3840x2160	1==0
format: 35	3840x2160	0==0
format: 35	3840x2160	1==0
format: 33	3840x2160	0==0
format: 34	3264x2448	0==0
format: 34	3264x2448	1==0
format: 35	3264x2448	0==0
format: 35	3264x2448	1==0
format: 33	3264x2448	0==0
format: 34	3200x2400	0==0
format: 34	3200x2400	1==0
format: 35	3200x2400	0==0
format: 35	3200x2400	1==0
format: 33	3200x2400	0==0
format: 34	2976x2976	0==0
format: 34	2976x2976	1==0
format: 35	2976x2976	0==0
format: 35	2976x2976	1==0
format: 33	2976x2976	0==0
format: 34	2688x1512	0==0
format: 35	2688x1512	0==0
format: 33	2688x1512	0==0
format: 34	2592x1944	0==0
format: 34	2592x1944	1==0
format: 35	2592x1944	0==0
format: 35	2592x1944	1==0
format: 33	2592x1944	0==0
format: 34	2048x1536	0==0
format: 35	2048x1536	0==0
format: 33	2048x1536	0==0
format: 34	1920x1440	0==0
format: 35	1920x1440	0==0
format: 33	1920x1440	0==0
format: 34	1928x1208	0==0
format: 35	1928x1208	0==0
format: 33	1928x1208	0==0
format: 34	1920x1080	0==0
format: 35	1920x1080	0==0
format: 33	1920x1080	0==0
format: 34	1600x1200	0==0
format: 35	1600x1200	0==0
format: 33	1600x1200	0==0
format: 34	1440x1080	0==0
format: 35	1440x1080	0==0
format: 33	1440x1080	0==0
format: 34	1280x960	0==0
format: 35	1280x960	0==0
format: 33	1280x960	0==0
format: 34	1280x800	0==0
format: 35	1280x800	0==0
format: 33	1280x800	0==0
format: 34	1280x768	0==0
format: 35	1280x768	0==0
format: 33	1280x768	0==0
format: 34	1280x720	0==0
format: 35	1280x720	0==0
format: 33	1280x720	0==0
format: 34	1080x1080	0==0
format: 35	1080x1080	0==0
format: 33	1080x1080	0==0
format: 34	1024x738	0==0
format: 35	1024x738	0==0
format: 33	1024x738	0==0
format: 34	1024x768	0==0
format: 35	1024x768	0==0
format: 33	1024x768	0==0
format: 34	864x480	0==0
format: 35	864x480	0==0
format: 33	864x480	0==0
format: 34	800x600	0==0
format: 35	800x600	0==0
format: 33	800x600	0==0
format: 34	800x480	0==0
format: 35	800x480	0==0
format: 33	800x480	0==0
format: 34	720x1280	0==0
format: 35	720x1280	0==0
format: 33	720x1280	0==0
format: 34	720x480	0==0
format: 35	720x480	0==0
format: 33	720x480	0==0
format: 34	640x480	0==0
format: 35	640x480	0==0
format: 33	640x480	0==0
format: 34	640x400	0==0
format: 35	640x400	0==0
format: 33	640x400	0==0
format: 34	640x360	0==0
format: 35	640x360	0==0
format: 33	640x360	0==0
format: 34	352x288	0==0
format: 35	352x288	0==0
format: 33	352x288	0==0
format: 34	320x240	0==0
format: 35	320x240	0==0
format: 33	320x240	0==0
format: 34	240x320	0==0
format: 35	240x320	0==0
format: 33	240x320	0==0
format: 34	176x144	0==0
format: 35	176x144	0==0
format: 33	176x144	0==0
format: 37	4056x3040	0==0
format: 38	4056x3040	0==0
format: 32	4056x3040	0==0
format: 36	4056x3040	0==0
<p dir="auto">If I step down to the next largest supported resolution of 4000x3000, the camera server starts, but the image is all distorted:</p>
<p dir="auto"><img src="/assets/uploads/files/1672778862540-42b89314-77f4-41dd-bfb4-2a39e2d5ec4b-image.png" alt="42b89314-77f4-41dd-bfb4-2a39e2d5ec4b-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I came across this distortion before when using v4l2, which just required the stride to be corrected (increase it to the next multiple of 256).</p>
<p dir="auto">Ideas?</p>
<p dir="auto">Other than my hacked version of voxl-camera-server (based on v1.1.0 or SDK 0.8), my system is stock 1.3.1.</p>
<pre><code>--------------------------------------------------------------------------------
system-image: 1.3.1-M0054-14.1a-perf
kernel:       #1 SMP PREEMPT Tue Aug 2 05:23:05 UTC 2022 4.19.125
hw version:   M0054
voxl-suite:   0.8.1
]]></description><link>https://forum.modalai.com/topic/1657/listing-changing-camera-resolution</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 20:08:33 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1657.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Jan 2023 20:56:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Listing/Changing Camera Resolution on Thu, 05 Jan 2023 17:44:58 GMT]]></title><description><![CDATA[<p dir="auto">After some digging, I came across the <code>qtiqmmfsrc</code> GStreamer element. If I use this to get the video stream at 4000x3000 (video/x-raw, format=NV12), I get the same distortion shown above. However, if I request the H.264 stream (video/x-h264, format=NV12), I get a clear picture.</p>
<p dir="auto">Below are the pipelines that I tested using the IMX412.</p>
<pre><code class="language-bash"># Distorted Output
gst-launch-1.0 -e qtiqmmfsrc name=qmmf ! video/x-raw,format=NV12,width=4000,height=3000,framerate=30/1 ! \
omxh264enc control-rate=2 target-bitrate=6000000 ! h264parse ! \
matroskamux ! filesink location=43_raw.mkv
# Good Output
gst-launch-1.0 -e qtiqmmfsrc name=qmmf ! video/x-h264,format=NV12,width=4000,height=3000,framerate=30/1 ! \
h264parse ! \
matroskamux ! filesink location=43_h264.mkv
<p dir="auto">On a side note, the video's white balance from qtiqmmfsrc is better than when requesting images through voxl-camera-server. The video is extremely warm when delivered through voxl-camera-server, though I admit that I never looked into the configuration for this.</p>
<p dir="auto">In any case, it looks like this is maybe an issue with Qualcomm's libs. I haven't yet looked further into the voxl-camera-server source, though I don't suppose there's been an update to the qmmfsrc or related libs that can be updated on the VOXL2, is there?</p>
]]></description><link>https://forum.modalai.com/post/7717</link><guid isPermaLink="true">https://forum.modalai.com/post/7717</guid><dc:creator><![CDATA[PSI]]></dc:creator><pubDate>Thu, 05 Jan 2023 17:44:58 GMT</pubDate></item></channel></rss>
