<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VOXL-UVC-Server on QGC latency &amp; ethernet]]></title><description><![CDATA[<p dir="auto">I got the UVC-Server working now with a USB camera, but it has a ~1 second latency when viewed on QGC compared to voxl-portal with only milliseconds delay over wifi, can that be fixed?</p>
<p dir="auto">And is there also a way to get the USB camera to work via ethernet as it currently only works on QGC with the IP of the wifi and I want it to work on the IP of the ethernet adapter attached to the VOXL.</p>
]]></description><link>https://forum.modalai.com/topic/1650/voxl-uvc-server-on-qgc-latency-ethernet</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 07:16:56 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1650.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 Jan 2023 12:26:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to VOXL-UVC-Server on QGC latency &amp; ethernet on Fri, 06 Jan 2023 06:10:04 GMT]]></title><description><![CDATA[<p dir="auto">It sounds like QGC is buffering, have you reached out to the QGC team?</p>
<p dir="auto">The VOXL is a Linux device with standard Linux networking. You should be able to use standard Linux routing techniques to route your IP traffic</p>
]]></description><link>https://forum.modalai.com/post/7727</link><guid isPermaLink="true">https://forum.modalai.com/post/7727</guid><dc:creator><![CDATA[Chad Sweet]]></dc:creator><pubDate>Fri, 06 Jan 2023 06:10:04 GMT</pubDate></item></channel></rss>
