<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[voxl-feature-tracker with TOF error]]></title><description><![CDATA[<p dir="auto">Hi there, i`m trying to use the voxl-feature-tracker with Tof camera, I was able to achieve this with voxl-feature-tracker V0.08 without any problem. However, when im trying to run the version 0.1.3, im getting the same warning all the time: <strong>WARNING: failed to track any points</strong>. I even tried to play with the new version 0.1.4 but I got new error and warning: <strong>ERROR in get_data_over_range, requested timestamp must be &gt;0</strong>, <strong>WARNING: Failed to match, dropping frame</strong>.<br />
Could you help me to fix these errors @Matt-Turi?</p>
]]></description><link>https://forum.modalai.com/topic/1632/voxl-feature-tracker-with-tof-error</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 12:03:42 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1632.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Dec 2022 08:01:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to voxl-feature-tracker with TOF error on Sun, 15 Jan 2023 17:26:52 GMT]]></title><description><![CDATA[<p dir="auto">You need to calibrate the thermal camera to generate the intrinsic. There is no off the shelf way to do this. You will need to create a to-scale checkerboard that the sensor can see</p>
]]></description><link>https://forum.modalai.com/post/7884</link><guid isPermaLink="true">https://forum.modalai.com/post/7884</guid><dc:creator><![CDATA[Chad Sweet]]></dc:creator><pubDate>Sun, 15 Jan 2023 17:26:52 GMT</pubDate></item><item><title><![CDATA[Reply to voxl-feature-tracker with TOF error on Sun, 15 Jan 2023 14:12:06 GMT]]></title><description><![CDATA[<p dir="auto">@Matt-Turi Hi there, im trying now with the flir thermal camera. However it`s looking for a intrinsics cal file. How can i find/create this file?</p>
]]></description><link>https://forum.modalai.com/post/7882</link><guid isPermaLink="true">https://forum.modalai.com/post/7882</guid><dc:creator><![CDATA[Maxim Temp]]></dc:creator><pubDate>Sun, 15 Jan 2023 14:12:06 GMT</pubDate></item><item><title><![CDATA[Reply to voxl-feature-tracker with TOF error on Wed, 21 Dec 2022 06:40:18 GMT]]></title><description><![CDATA[<p dir="auto">@Matt-Turi I`m using the Voxl apq8096, with version 0.1.4 it displays the tof camera but without features, I was able to fix the <strong>ERROR in get_data_over_range, requested timestamp must be &gt;0</strong> by adding some lines to your code, but still I have the 2 warnings mentioned above.</p>
]]></description><link>https://forum.modalai.com/post/7601</link><guid isPermaLink="true">https://forum.modalai.com/post/7601</guid><dc:creator><![CDATA[Maxim Temp]]></dc:creator><pubDate>Wed, 21 Dec 2022 06:40:18 GMT</pubDate></item><item><title><![CDATA[Reply to voxl-feature-tracker with TOF error on Wed, 21 Dec 2022 06:33:34 GMT]]></title><description><![CDATA[<p dir="auto">@Matt-Turi {<br />
"cam0_enable":	0,<br />
"cam0_name":	"",<br />
"cam0_mode":	"",<br />
"cam0_extrinsics_extension_first":	"",<br />
"cam0_extrinsics_extension_second":	"",<br />
"cam1_enable":	1,<br />
"cam1_name":	"tof_ir",<br />
"cam1_mode":	"MONO",<br />
"cam1_extrinsics_extension_first":	"",<br />
"cam1_extrinsics_extension_second":	"",<br />
"cam2_enable":	0,<br />
"cam3_enable":	0,<br />
"imu_name":	"imu1",<br />
"num_features_to_track":	50,<br />
"grid_x":	10,<br />
"grid_y":	10,<br />
"min_pix_dist":	10,<br />
"pyramid_levels":	3,<br />
"window_size":	15,<br />
"forward_images":	true,<br />
"en_flow_estimate":	true,<br />
"forward_to_px4":	true,<br />
"tracker_mode":	"KLT",<br />
"en_gyro":	true,<br />
"en_descriptors":	true,<br />
"en_database":	true,<br />
"database_size":	12,<br />
"max_angular_rate_before_blur":	40<br />
}</p>
]]></description><link>https://forum.modalai.com/post/7600</link><guid isPermaLink="true">https://forum.modalai.com/post/7600</guid><dc:creator><![CDATA[Maxim Temp]]></dc:creator><pubDate>Wed, 21 Dec 2022 06:33:34 GMT</pubDate></item><item><title><![CDATA[Reply to voxl-feature-tracker with TOF error on Tue, 20 Dec 2022 17:22:49 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/user/maxim-temp" aria-label="Profile: Maxim-Temp">@<bdi>Maxim-Temp</bdi></a>,</p>
<p dir="auto">voxl-feature-tracker is a beta project that is under active development, specifically targeting a thermal camera right now. I have not tested with a tof camera, but could you share your config file under <code>/etc/modalai/voxl-feature-tracker.conf</code></p>
]]></description><link>https://forum.modalai.com/post/7587</link><guid isPermaLink="true">https://forum.modalai.com/post/7587</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 20 Dec 2022 17:22:49 GMT</pubDate></item></channel></rss>
