<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Why does QRB5 switch from Position mode to Hold mode?]]></title><description><![CDATA[<p dir="auto">Hi Dev Team,</p>
<p dir="auto">I flew the QRB5 in an outdoor environment with GPS only (<code>EKF2_AID_MASK=1</code>, please see image <a href="/assets/uploads/files/1669022914136-microsoftteams-image-4-resized.png">EKF2_AID_MASK</a>); and the GPS signal is very good (with 32 satellites, errors are below 0.8m).<br />
However, whenever I switched the drone to <strong>Position</strong> mode, it automatically switched back to <strong>Hold</strong> mode after a few seconds.</p>
<p dir="auto">Do you know <em>what is the reason</em> and <em>how to configure</em> the drone to let it runs in <strong>Position</strong> mode without VIO? Thank you.</p>
]]></description><link>https://forum.modalai.com/topic/1556/why-does-qrb5-switch-from-position-mode-to-hold-mode</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 08:04:43 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1556.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Nov 2022 09:31:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Why does QRB5 switch from Position mode to Hold mode? on Mon, 21 Nov 2022 11:03:41 GMT]]></title><description><![CDATA[<p dir="auto">Actually, I realized that the Hold mode can be switched back to Position mode once I move sticks more than 30%. However, the switching from Position to Hold mode was too fast (i.e., within 1 second), so whatever changes during that time was discarded and after moving 30% of sticks in order to switch from Hold to Position, the Altitude is either too high or too low for the next move.</p>
<p dir="auto">Do you know which parameters postpone the process of switching from Position to Hold mode? Thank you.</p>
]]></description><link>https://forum.modalai.com/post/7235</link><guid isPermaLink="true">https://forum.modalai.com/post/7235</guid><dc:creator><![CDATA[kitkatSG]]></dc:creator><pubDate>Mon, 21 Nov 2022 11:03:41 GMT</pubDate></item></channel></rss>
