<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Does VOXL2 support UAVCAN?]]></title><description><![CDATA[<p dir="auto">In particular, I want to use Here3 RTK and (if I understand correctly - perhaps I'm mistaken?) this is only supported over CAN</p>
]]></description><link>https://forum.modalai.com/topic/1505/does-voxl2-support-uavcan</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 08:54:00 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1505.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 31 Oct 2022 17:50:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Does VOXL2 support UAVCAN? on Tue, 01 Nov 2022 21:55:30 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Eric, I'll look into the legacy mode</p>
]]></description><link>https://forum.modalai.com/post/7019</link><guid isPermaLink="true">https://forum.modalai.com/post/7019</guid><dc:creator><![CDATA[Patrick Hinchey]]></dc:creator><pubDate>Tue, 01 Nov 2022 21:55:30 GMT</pubDate></item><item><title><![CDATA[Reply to Does VOXL2 support UAVCAN? on Tue, 01 Nov 2022 15:00:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/746">@Patrick-Hinchey</a> The supported interface for the Here3 RTK is CAN bus and VOXL 2 does not support that interface. However, there is a "legacy" mode in that unit that allows operation using UART for GPS and I2C for the magnetometer. There isn't really any documentation about this mode but we were able to get it working in the past. It requires that you open the unit and turn the switch to the I2C setting and build some custom cabling. It isn't really a supported mode but it is possible.</p>
]]></description><link>https://forum.modalai.com/post/7016</link><guid isPermaLink="true">https://forum.modalai.com/post/7016</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Tue, 01 Nov 2022 15:00:53 GMT</pubDate></item></channel></rss>
