<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PID parameters for F-450]]></title><description><![CDATA[<p dir="auto">I am using F-450 frame with voxl2 +voxl2 io board. I am using 1000 kv a2212 with 40 amps ESC. The quad is wobbling too much. I am not able to hover it for few seconds. How to fix this?<br />
I am putting all the parameters here. Please help me to solve this.</p>
<pre><code># Onboard parameters for Vehicle 1
# Stack: PX4 Pro
# Vehicle: Multi-Rotor
# Version: 1.4.28 beta
# Git Revision: 17f524d47f000000
# Vehicle-Id Component-Id Name Value Type
1	1	ASPD_SCALE	1.000000000000000000	9
1	1	ATT_W_MAG	0.000000000000000000	9
1	1	BAT1_CAPACITY	5200.000000000000000000	9
1	1	BAT1_N_CELLS	3	6
1	1	BAT1_R_INTERNAL	0.008000000379979610	9
1	1	BAT1_SOURCE	0	6
1	1	BAT1_V_CHARGED	4.150000095367431641	9
1	1	BAT1_V_EMPTY	3.500000000000000000	9
1	1	BAT1_V_LOAD_DROP	0.300000011920928955	9
1	1	BAT_A_PER_V	-1.000000000000000000	9
1	1	BAT_CAPACITY	5200.000000000000000000	9
1	1	BAT_CRIT_THR	0.100000001490116119	9
1	1	BAT_EMERGEN_THR	0.050000000745058060	9
1	1	BAT_LOW_THR	0.150000005960464478	9
1	1	BAT_N_CELLS	3	6
1	1	BAT_R_INTERNAL	0.008000000379979610	9
1	1	BAT_SOURCE	0	6
1	1	BAT_V_CHARGED	4.150000095367431641	9
1	1	BAT_V_DIV	-1.000000000000000000	9
1	1	BAT_V_EMPTY	3.500000000000000000	9
1	1	BAT_V_LOAD_DROP	0.300000011920928955	9
1	1	CAL_ACC0_ID	2490378	6
1	1	CAL_ACC0_PRIO	50	6
1	1	CAL_ACC0_ROT	-1	6
1	1	CAL_ACC0_XOFF	-0.030445575714111328	9
1	1	CAL_ACC0_XSCALE	0.998159468173980713	9
1	1	CAL_ACC0_YOFF	0.006990909576416016	9
1	1	CAL_ACC0_YSCALE	0.998862206935882568	9
1	1	CAL_ACC0_ZOFF	-0.025464057922363281	9
1	1	CAL_ACC0_ZSCALE	1.001702070236206055	9
1	1	CAL_ACC1_PRIO	50	6
1	1	CAL_ACC2_PRIO	50	6
1	1	CAL_ACC3_PRIO	50	6
1	1	CAL_AIR_CMODEL	0	6
1	1	CAL_AIR_TUBED_MM	1.500000000000000000	9
1	1	CAL_AIR_TUBELEN	0.200000002980232239	9
1	1	CAL_GYRO0_ID	2490378	6
1	1	CAL_GYRO0_PRIO	50	6
1	1	CAL_GYRO0_ROT	-1	6
1	1	CAL_GYRO0_XOFF	0.000965127372182906	9
1	1	CAL_GYRO0_YOFF	0.012642575427889824	9
1	1	CAL_GYRO0_ZOFF	-0.005749725736677647	9
1	1	CAL_GYRO1_PRIO	50	6
1	1	CAL_GYRO2_PRIO	50	6
1	1	CAL_GYRO3_PRIO	50	6
1	1	CAL_MAG0_ID	0	6
1	1	CAL_MAG0_PRIO	50	6
1	1	CAL_MAG0_ROT	-1	6
1	1	CAL_MAG1_ID	0	6
1	1	CAL_MAG1_PRIO	50	6
1	1	CAL_MAG1_ROT	-1	6
1	1	CAL_MAG2_ID	0	6
1	1	CAL_MAG2_PRIO	50	6
1	1	CAL_MAG2_ROT	-1	6
1	1	CAL_MAG3_ID	0	6
1	1	CAL_MAG3_PRIO	50	6
1	1	CAL_MAG3_ROT	-1	6
1	1	CBRK_AIRSPD_CHK	0	6
1	1	CBRK_ENGINEFAIL	284953	6
1	1	CBRK_FLIGHTTERM	121212	6
1	1	CBRK_IO_SAFETY	22027	6
1	1	CBRK_RATE_CTRL	0	6
1	1	CBRK_SUPPLY_CHK	894281	6
1	1	CBRK_USB_CHK	0	6
1	1	CBRK_VELPOSERR	0	6
1	1	CBRK_VTOLARMING	0	6
1	1	COM_ARM_AUTH_ID	10	6
1	1	COM_ARM_AUTH_MET	0	6
1	1	COM_ARM_AUTH_REQ	0	6
1	1	COM_ARM_AUTH_TO	1.000000000000000000	9
1	1	COM_ARM_CHK_ESCS	1	6
1	1	COM_ARM_EKF_HGT	1.000000000000000000	9
1	1	COM_ARM_EKF_POS	0.500000000000000000	9
1	1	COM_ARM_EKF_VEL	0.500000000000000000	9
1	1	COM_ARM_EKF_YAW	0.500000000000000000	9
1	1	COM_ARM_IMU_ACC	0.699999988079071045	9
1	1	COM_ARM_IMU_GYR	0.250000000000000000	9
1	1	COM_ARM_MAG_STR	1	6
1	1	COM_ARM_MIS_REQ	0	6
1	1	COM_ARM_SWISBTN	0	6
1	1	COM_ARM_WO_GPS	1	6
1	1	COM_DISARM_LAND	2.000000000000000000	9
1	1	COM_DISARM_PRFLT	-1.000000000000000000	9
1	1	COM_DL_LOSS_T	10	6
1	1	COM_EF_C2T	5.000000000000000000	9
1	1	COM_EF_THROT	0.500000000000000000	9
1	1	COM_EF_TIME	10.000000000000000000	9
1	1	COM_FLIGHT_UUID	93	6
1	1	COM_FLTMODE1	0	6
1	1	COM_FLTMODE2	-1	6
1	1	COM_FLTMODE3	-1	6
1	1	COM_FLTMODE4	2	6
1	1	COM_FLTMODE5	-1	6
1	1	COM_FLTMODE6	8	6
1	1	COM_FLT_PROFILE	0	6
1	1	COM_HLDL_LOSS_T	120	6
1	1	COM_HLDL_REG_T	0	6
1	1	COM_HOME_H_T	5.000000000000000000	9
1	1	COM_HOME_IN_AIR	0	6
1	1	COM_HOME_V_T	10.000000000000000000	9
1	1	COM_KILL_DISARM	5.000000000000000000	9
1	1	COM_LKDOWN_TKO	3.000000000000000000	9
1	1	COM_LOW_BAT_ACT	0	6
1	1	COM_MOT_TEST_EN	1	6
1	1	COM_OBL_ACT	0	6
1	1	COM_OBL_RC_ACT	0	6
1	1	COM_OBS_AVOID	0	6
1	1	COM_OF_LOSS_T	0.500000000000000000	9
1	1	COM_POSCTL_NAVL	0	6
1	1	COM_POS_FS_DELAY	1	6
1	1	COM_POS_FS_EPH	5.000000000000000000	9
1	1	COM_POS_FS_EPV	10.000000000000000000	9
1	1	COM_POS_FS_GAIN	10	6
1	1	COM_POS_FS_PROB	30	6
1	1	COM_PREARM_MODE	0	6
1	1	COM_PREARM_ODID	0	6
1	1	COM_RC_ARM_HYST	1000	6
1	1	COM_RC_IN_MODE	0	6
1	1	COM_RC_LOSS_T	2.000000000000000000	9
1	1	COM_RC_OVERRIDE	1	6
1	1	COM_RC_STICK_OV	30.000000000000000000	9
1	1	COM_REARM_GRACE	1	6
1	1	COM_TAKEOFF_ACT	0	6
1	1	COM_VEL_FS_EVH	1.000000000000000000	9
1	1	CP_DELAY	0.400000005960464478	9
1	1	CP_DIST	-1.000000000000000000	9
1	1	CP_GO_NO_DATA	0.000000000000000000	9
1	1	CP_GUIDE_ANG	30.000000000000000000	9
1	1	EKF2_ABIAS_INIT	0.200000002980232239	9
1	1	EKF2_ABL_ACCLIM	25.000000000000000000	9
1	1	EKF2_ABL_GYRLIM	3.000000000000000000	9
1	1	EKF2_ABL_LIM	0.800000011920928955	9
1	1	EKF2_ABL_TAU	0.500000000000000000	9
1	1	EKF2_ACC_B_NOISE	0.003000000026077032	9
1	1	EKF2_ACC_NOISE	0.349999994039535522	9
1	1	EKF2_AID_MASK	280	6
1	1	EKF2_ANGERR_INIT	0.100000001490116119	9
1	1	EKF2_ARSP_THR	0.000000000000000000	9
1	1	EKF2_ASPD_MAX	20.000000000000000000	9
1	1	EKF2_ASP_DELAY	100.000000000000000000	9
1	1	EKF2_AVEL_DELAY	5.000000000000000000	9
1	1	EKF2_BARO_DELAY	0.000000000000000000	9
1	1	EKF2_BARO_GATE	5.000000000000000000	9
1	1	EKF2_BARO_NOISE	3.500000000000000000	9
1	1	EKF2_BCOEF_X	25.000000000000000000	9
1	1	EKF2_BCOEF_Y	25.000000000000000000	9
1	1	EKF2_BETA_GATE	5.000000000000000000	9
1	1	EKF2_BETA_NOISE	0.300000011920928955	9
1	1	EKF2_DECL_TYPE	7	6
1	1	EKF2_DRAG_NOISE	2.500000000000000000	9
1	1	EKF2_EAS_NOISE	1.399999976158142090	9
1	1	EKF2_EVA_NOISE	0.050000000745058060	9
1	1	EKF2_EVP_GATE	5.000000000000000000	9
1	1	EKF2_EVP_NOISE	0.100000001490116119	9
1	1	EKF2_EVV_GATE	3.000000000000000000	9
1	1	EKF2_EVV_NOISE	0.100000001490116119	9
1	1	EKF2_EV_DELAY	5.000000000000000000	9
1	1	EKF2_EV_NOISE_MD	0	6
1	1	EKF2_EV_POS_X	0.000000000000000000	9
1	1	EKF2_EV_POS_Y	0.000000000000000000	9
1	1	EKF2_EV_POS_Z	0.000000000000000000	9
1	1	EKF2_FUSE_BETA	0	6
1	1	EKF2_GBIAS_INIT	0.100000001490116119	9
1	1	EKF2_GND_EFF_DZ	0.000000000000000000	9
1	1	EKF2_GND_MAX_HGT	0.500000000000000000	9
1	1	EKF2_GPS_CHECK	245	6
1	1	EKF2_GPS_DELAY	110.000000000000000000	9
1	1	EKF2_GPS_POS_X	0.000000000000000000	9
1	1	EKF2_GPS_POS_Y	0.000000000000000000	9
1	1	EKF2_GPS_POS_Z	0.000000000000000000	9
1	1	EKF2_GPS_P_GATE	5.000000000000000000	9
1	1	EKF2_GPS_P_NOISE	0.500000000000000000	9
1	1	EKF2_GPS_V_GATE	5.000000000000000000	9
1	1	EKF2_GPS_V_NOISE	0.300000011920928955	9
1	1	EKF2_GSF_TAS	15.000000000000000000	9
1	1	EKF2_GYR_B_NOISE	0.001000000047497451	9
1	1	EKF2_GYR_NOISE	0.014999999664723873	9
1	1	EKF2_HDG_GATE	2.599999904632568359	9
1	1	EKF2_HEAD_NOISE	0.300000011920928955	9
1	1	EKF2_HGT_MODE	3	6
1	1	EKF2_IMU_POS_X	0.027000000700354576	9
1	1	EKF2_IMU_POS_Y	0.008999999612569809	9
1	1	EKF2_IMU_POS_Z	-0.018999999389052391	9
1	1	EKF2_MAG_ACCLIM	0.500000000000000000	9
1	1	EKF2_MAG_B_NOISE	0.000099999997473788	9
1	1	EKF2_MAG_CHECK	0	6
1	1	EKF2_MAG_DECL	0.000000000000000000	9
1	1	EKF2_MAG_DELAY	0.000000000000000000	9
1	1	EKF2_MAG_E_NOISE	0.001000000047497451	9
1	1	EKF2_MAG_GATE	3.000000000000000000	9
1	1	EKF2_MAG_NOISE	0.050000000745058060	9
1	1	EKF2_MAG_TYPE	5	6
1	1	EKF2_MAG_YAWLIM	0.250000000000000000	9
1	1	EKF2_MIN_OBS_DT	20	6
1	1	EKF2_MIN_RNG	0.100000001490116119	9
1	1	EKF2_MOVE_TEST	1.000000000000000000	9
1	1	EKF2_NOAID_NOISE	10.000000000000000000	9
1	1	EKF2_NOAID_TOUT	5000000	6
1	1	EKF2_OF_DELAY	20.000000000000000000	9
1	1	EKF2_OF_GATE	3.000000000000000000	9
1	1	EKF2_OF_N_MAX	0.500000000000000000	9
1	1	EKF2_OF_N_MIN	0.150000005960464478	9
1	1	EKF2_OF_POS_X	0.000000000000000000	9
1	1	EKF2_OF_POS_Y	0.000000000000000000	9
1	1	EKF2_OF_POS_Z	0.000000000000000000	9
1	1	EKF2_OF_QMIN	1	6
1	1	EKF2_PCOEF_XN	0.000000000000000000	9
1	1	EKF2_PCOEF_XP	0.000000000000000000	9
1	1	EKF2_PCOEF_YN	0.000000000000000000	9
1	1	EKF2_PCOEF_YP	0.000000000000000000	9
1	1	EKF2_PCOEF_Z	0.000000000000000000	9
1	1	EKF2_REQ_EPH	3.000000000000000000	9
1	1	EKF2_REQ_EPV	5.000000000000000000	9
1	1	EKF2_REQ_GPS_H	10.000000000000000000	9
1	1	EKF2_REQ_HDRIFT	0.100000001490116119	9
1	1	EKF2_REQ_NSATS	6	6
1	1	EKF2_REQ_PDOP	2.500000000000000000	9
1	1	EKF2_REQ_SACC	0.500000000000000000	9
1	1	EKF2_REQ_VDRIFT	0.200000002980232239	9
1	1	EKF2_RNG_AID	0	6
1	1	EKF2_RNG_A_HMAX	5.000000000000000000	9
1	1	EKF2_RNG_A_IGATE	1.000000000000000000	9
1	1	EKF2_RNG_A_VMAX	1.000000000000000000	9
1	1	EKF2_RNG_DELAY	5.000000000000000000	9
1	1	EKF2_RNG_GATE	5.000000000000000000	9
1	1	EKF2_RNG_NOISE	0.100000001490116119	9
1	1	EKF2_RNG_PITCH	0.000000000000000000	9
1	1	EKF2_RNG_POS_X	0.000000000000000000	9
1	1	EKF2_RNG_POS_Y	0.000000000000000000	9
1	1	EKF2_RNG_POS_Z	0.000000000000000000	9
1	1	EKF2_RNG_QLTY_T	1.000000000000000000	9
1	1	EKF2_RNG_SFE	0.050000000745058060	9
1	1	EKF2_SYNT_MAG_Z	0	6
1	1	EKF2_TAS_GATE	3.000000000000000000	9
1	1	EKF2_TAU_POS	0.250000000000000000	9
1	1	EKF2_TAU_VEL	0.250000000000000000	9
1	1	EKF2_TERR_GRAD	0.500000000000000000	9
1	1	EKF2_TERR_MASK	3	6
1	1	EKF2_TERR_NOISE	5.000000000000000000	9
1	1	EKF2_WIND_NOISE	0.100000001490116119	9
1	1	FD_ESCS_EN	1	6
1	1	FD_EXT_ATS_EN	0	6
1	1	FD_EXT_ATS_TRIG	1900	6
1	1	FD_FAIL_P	60	6
1	1	FD_FAIL_P_TTRI	0.300000011920928955	9
1	1	FD_FAIL_R	60	6
1	1	FD_FAIL_R_TTRI	0.300000011920928955	9
1	1	FW_MAN_P_SC	1.000000000000000000	9
1	1	FW_MAN_R_SC	1.000000000000000000	9
1	1	FW_MAN_Y_SC	1.000000000000000000	9
1	1	GF_ACTION	2	6
1	1	GF_ALTMODE	0	6
1	1	GF_COUNT	-1	6
1	1	GF_MAX_HOR_DIST	0.000000000000000000	9
1	1	GF_MAX_VER_DIST	0.000000000000000000	9
1	1	GF_SOURCE	0	6
1	1	GPS_1_GNSS	0	6
1	1	GPS_1_PROTOCOL	1	6
1	1	GPS_DUMP_COMM	0	6
1	1	GPS_UBX_DYNMODEL	7	6
1	1	GPS_UBX_MODE	0	6
1	1	GPS_YAW_OFFSET	0.000000000000000000	9
1	1	HTE_ACC_GATE	3.000000000000000000	9
1	1	HTE_HT_ERR_INIT	0.100000001490116119	9
1	1	HTE_HT_NOISE	0.003599999938160181	9
1	1	IMU_ACCEL_CUTOFF	30.000000000000000000	9
1	1	IMU_DGYRO_CUTOFF	30.000000000000000000	9
1	1	IMU_GYRO_CUTOFF	30.000000000000000000	9
1	1	IMU_GYRO_NF_BW	20.000000000000000000	9
1	1	IMU_GYRO_NF_FREQ	0.000000000000000000	9
1	1	IMU_GYRO_RATEMAX	0	6
1	1	IMU_INTEG_RATE	200	6
1	1	LNDMC_ALT_MAX	-1.000000000000000000	9
1	1	LNDMC_ROT_MAX	500.000000000000000000	9
1	1	LNDMC_XY_VEL_MAX	1.500000000000000000	9
1	1	LNDMC_Z_VEL_MAX	0.500000000000000000	9
1	1	LND_FLIGHT_T_HI	0	6
1	1	LND_FLIGHT_T_LO	1057633890	6
1	1	MAV_BROADCAST	0	6
1	1	MAV_COMP_ID	1	6
1	1	MAV_FWDEXTSP	1	6
1	1	MAV_HASH_CHK_EN	1	6
1	1	MAV_HB_FORW_EN	1	6
1	1	MAV_ODOM_LP	0	6
1	1	MAV_PROTO_VER	0	6
1	1	MAV_RADIO_TOUT	5	6
1	1	MAV_SIK_RADIO_ID	0	6
1	1	MAV_SYS_ID	1	6
1	1	MAV_TYPE	2	6
1	1	MAV_USEHILGPS	0	6
1	1	MC_ACRO_EXPO	0.689999997615814209	9
1	1	MC_ACRO_EXPO_Y	0.689999997615814209	9
1	1	MC_ACRO_P_MAX	720.000000000000000000	9
1	1	MC_ACRO_R_MAX	720.000000000000000000	9
1	1	MC_ACRO_SUPEXPO	0.699999988079071045	9
1	1	MC_ACRO_SUPEXPOY	0.699999988079071045	9
1	1	MC_ACRO_Y_MAX	540.000000000000000000	9
1	1	MC_AIRMODE	0	6
1	1	MC_BAT_SCALE_EN	1	6
1	1	MC_MAN_TILT_TAU	0.000000000000000000	9
1	1	MC_PITCHRATE_D	0.001300000003539026	9
1	1	MC_PITCHRATE_FF	0.000000000000000000	9
1	1	MC_PITCHRATE_I	0.200000002980232239	9
1	1	MC_PITCHRATE_K	1.000000000000000000	9
1	1	MC_PITCHRATE_MAX	220.000000000000000000	9
1	1	MC_PITCHRATE_P	0.079999998211860657	9
1	1	MC_PITCH_P	5.500000000000000000	9
1	1	MC_PR_INT_LIM	0.300000011920928955	9
1	1	MC_RATT_TH	0.800000011920928955	9
1	1	MC_ROLLRATE_D	0.001300000003539026	9
1	1	MC_ROLLRATE_FF	0.000000000000000000	9
1	1	MC_ROLLRATE_I	0.200000002980232239	9
1	1	MC_ROLLRATE_K	1.000000000000000000	9
1	1	MC_ROLLRATE_MAX	220.000000000000000000	9
1	1	MC_ROLLRATE_P	0.079999998211860657	9
1	1	MC_ROLL_P	5.500000000000000000	9
1	1	MC_RR_INT_LIM	0.300000011920928955	9
1	1	MC_YAWRATE_D	0.000000000000000000	9
1	1	MC_YAWRATE_FF	0.000000000000000000	9
1	1	MC_YAWRATE_I	0.100000001490116119	9
1	1	MC_YAWRATE_K	1.000000000000000000	9
1	1	MC_YAWRATE_MAX	200.000000000000000000	9
1	1	MC_YAWRATE_P	0.150000005960464478	9
1	1	MC_YAW_P	2.000000000000000000	9
1	1	MC_YAW_WEIGHT	0.400000005960464478	9
1	1	MC_YR_INT_LIM	0.300000011920928955	9
1	1	MIS_DIST_1WP	900.000000000000000000	9
1	1	MIS_DIST_WPS	900.000000000000000000	9
1	1	MIS_LTRMIN_ALT	-1.000000000000000000	9
1	1	MIS_MNT_YAW_CTL	0	6
1	1	MIS_TAKEOFF_ALT	2.500000000000000000	9
1	1	MIS_TAKEOFF_REQ	0	6
1	1	MIS_YAW_ERR	12.000000000000000000	9
1	1	MIS_YAW_TMT	-1.000000000000000000	9
1	1	MOT_ORDERING	0	6
1	1	MOT_SLEW_MAX	0.000000000000000000	9
1	1	MPC_ACC_DOWN_MAX	3.000000000000000000	9
1	1	MPC_ACC_HOR	3.000000000000000000	9
1	1	MPC_ACC_HOR_MAX	5.000000000000000000	9
1	1	MPC_ACC_UP_MAX	4.000000000000000000	9
1	1	MPC_ALT_MODE	0	6
1	1	MPC_HOLD_DZ	0.100000001490116119	9
1	1	MPC_HOLD_MAX_XY	0.800000011920928955	9
1	1	MPC_HOLD_MAX_Z	0.600000023841857910	9
1	1	MPC_JERK_AUTO	4.000000000000000000	9
1	1	MPC_JERK_MAX	8.000000000000000000	9
1	1	MPC_LAND_ALT1	10.000000000000000000	9
1	1	MPC_LAND_ALT2	5.000000000000000000	9
1	1	MPC_LAND_RC_HELP	0	6
1	1	MPC_LAND_SPEED	1.000000000000000000	9
1	1	MPC_LAND_VEL_XY	10.000000000000000000	9
1	1	MPC_MANTHR_MIN	0.050000000745058060	9
1	1	MPC_MAN_TILT_MAX	35.000000000000000000	9
1	1	MPC_MAN_Y_MAX	150.000000000000000000	9
1	1	MPC_MAN_Y_TAU	0.079999998211860657	9
1	1	MPC_POS_MODE	3	6
1	1	MPC_SPOOLUP_TIME	0.000000000000000000	9
1	1	MPC_THR_CURVE	0	6
1	1	MPC_THR_HOVER	0.419999986886978149	9
1	1	MPC_THR_MAX	0.750000000000000000	9
1	1	MPC_THR_MIN	0.079999998211860657	9
1	1	MPC_TILTMAX_AIR	45.000000000000000000	9
1	1	MPC_TILTMAX_LND	12.000000000000000000	9
1	1	MPC_TKO_RAMP_T	1.500000000000000000	9
1	1	MPC_TKO_SPEED	1.500000000000000000	9
1	1	MPC_USE_HTE	1	6
1	1	MPC_VELD_LP	5.000000000000000000	9
1	1	MPC_VEL_MANUAL	5.000000000000000000	9
1	1	MPC_XY_CRUISE	5.000000000000000000	9
1	1	MPC_XY_MAN_EXPO	0.200000002980232239	9
1	1	MPC_XY_P	0.949999988079071045	9
1	1	MPC_XY_TRAJ_P	0.500000000000000000	9
1	1	MPC_XY_VEL_D_ACC	2.000000000000000000	9
1	1	MPC_XY_VEL_I_ACC	0.400000005960464478	9
1	1	MPC_XY_VEL_MAX	5.000000000000000000	9
1	1	MPC_XY_VEL_P_ACC	1.200000047683715820	9
1	1	MPC_YAWRAUTO_MAX	45.000000000000000000	9
1	1	MPC_YAW_EXPO	0.200000002980232239	9
1	1	MPC_YAW_MODE	0	6
1	1	MPC_Z_MAN_EXPO	0.200000002980232239	9
1	1	MPC_Z_P	0.500000000000000000	9
1	1	MPC_Z_VEL_D_ACC	0.200000002980232239	9
1	1	MPC_Z_VEL_I_ACC	2.000000000000000000	9
1	1	MPC_Z_VEL_MAX_DN	1.500000000000000000	9
1	1	MPC_Z_VEL_MAX_UP	4.000000000000000000	9
1	1	MPC_Z_VEL_P_ACC	2.000000000000000000	9
1	1	NAV_ACC_RAD	10.000000000000000000	9
1	1	NAV_DLL_ACT	0	6
1	1	NAV_FORCE_VT	1	6
1	1	NAV_FT_DST	8.000000000000000000	9
1	1	NAV_FT_FS	1	6
1	1	NAV_FT_RS	0.500000000000000000	9
1	1	NAV_FW_ALTL_RAD	5.000000000000000000	9
1	1	NAV_FW_ALT_RAD	10.000000000000000000	9
1	1	NAV_GPSF_LT	0.000000000000000000	9
1	1	NAV_GPSF_P	0.000000000000000000	9
1	1	NAV_GPSF_R	15.000000000000000000	9
1	1	NAV_GPSF_TR	0.000000000000000000	9
1	1	NAV_LOITER_RAD	50.000000000000000000	9
1	1	NAV_MC_ALT_RAD	0.800000011920928955	9
1	1	NAV_MIN_FT_HT	8.000000000000000000	9
1	1	NAV_RCL_ACT	2	6
1	1	NAV_TRAFF_AVOID	1	6
1	1	NAV_TRAFF_A_RADM	500.000000000000000000	9
1	1	NAV_TRAFF_A_RADU	10.000000000000000000	9
1	1	PLD_BTOUT	5.000000000000000000	9
1	1	PLD_FAPPR_ALT	0.100000001490116119	9
1	1	PLD_HACC_RAD	0.200000002980232239	9
1	1	PLD_MAX_SRCH	3	6
1	1	PLD_SRCH_ALT	10.000000000000000000	9
1	1	PLD_SRCH_TOUT	10.000000000000000000	9
1	1	PWM_MAIN_DIS1	-1	6
1	1	PWM_MAIN_DIS2	-1	6
1	1	PWM_MAIN_DIS3	-1	6
1	1	PWM_MAIN_DIS4	-1	6
1	1	PWM_MAIN_DIS5	-1	6
1	1	PWM_MAIN_DIS6	-1	6
1	1	PWM_MAIN_DIS7	-1	6
1	1	PWM_MAIN_DIS8	-1	6
1	1	PWM_MAIN_DISARM	900	6
1	1	PWM_MAIN_FAIL1	0	6
1	1	PWM_MAIN_FAIL2	0	6
1	1	PWM_MAIN_FAIL3	0	6
1	1	PWM_MAIN_FAIL4	0	6
1	1	PWM_MAIN_FAIL5	0	6
1	1	PWM_MAIN_FAIL6	0	6
1	1	PWM_MAIN_FAIL7	0	6
1	1	PWM_MAIN_FAIL8	0	6
1	1	PWM_MAIN_MAX	2000	6
1	1	PWM_MAIN_MAX1	-1	6
1	1	PWM_MAIN_MAX2	-1	6
1	1	PWM_MAIN_MAX3	-1	6
1	1	PWM_MAIN_MAX4	-1	6
1	1	PWM_MAIN_MAX5	-1	6
1	1	PWM_MAIN_MAX6	-1	6
1	1	PWM_MAIN_MAX7	-1	6
1	1	PWM_MAIN_MAX8	-1	6
1	1	PWM_MAIN_MIN	1060	6
1	1	PWM_MAIN_MIN1	-1	6
1	1	PWM_MAIN_MIN2	-1	6
1	1	PWM_MAIN_MIN3	-1	6
1	1	PWM_MAIN_MIN4	-1	6
1	1	PWM_MAIN_MIN5	-1	6
1	1	PWM_MAIN_MIN6	-1	6
1	1	PWM_MAIN_MIN7	-1	6
1	1	PWM_MAIN_MIN8	-1	6
1	1	PWM_MAIN_RATE	400	6
1	1	PWM_MAIN_REV1	0	6
1	1	PWM_MAIN_REV2	0	6
1	1	PWM_MAIN_REV3	0	6
1	1	PWM_MAIN_REV4	0	6
1	1	PWM_MAIN_REV5	0	6
1	1	PWM_MAIN_REV6	0	6
1	1	PWM_MAIN_REV7	0	6
1	1	PWM_MAIN_REV8	0	6
1	1	PWM_MAIN_TRIM1	0.000000000000000000	9
1	1	PWM_MAIN_TRIM2	0.000000000000000000	9
1	1	PWM_MAIN_TRIM3	0.000000000000000000	9
1	1	PWM_MAIN_TRIM4	0.000000000000000000	9
1	1	PWM_MAIN_TRIM5	0.000000000000000000	9
1	1	PWM_MAIN_TRIM6	0.000000000000000000	9
1	1	PWM_MAIN_TRIM7	0.000000000000000000	9
1	1	PWM_MAIN_TRIM8	0.000000000000000000	9
1	1	PWM_SBUS_MODE	0	6
1	1	RC10_DZ	0.000000000000000000	9
1	1	RC10_MAX	2000.000000000000000000	9
1	1	RC10_MIN	1000.000000000000000000	9
1	1	RC10_REV	1.000000000000000000	9
1	1	RC10_TRIM	1500.000000000000000000	9
1	1	RC11_DZ	0.000000000000000000	9
1	1	RC11_MAX	2000.000000000000000000	9
1	1	RC11_MIN	1000.000000000000000000	9
1	1	RC11_REV	1.000000000000000000	9
1	1	RC11_TRIM	1500.000000000000000000	9
1	1	RC12_DZ	0.000000000000000000	9
1	1	RC12_MAX	2000.000000000000000000	9
1	1	RC12_MIN	1000.000000000000000000	9
1	1	RC12_REV	1.000000000000000000	9
1	1	RC12_TRIM	1500.000000000000000000	9
1	1	RC13_DZ	0.000000000000000000	9
1	1	RC13_MAX	2000.000000000000000000	9
1	1	RC13_MIN	1000.000000000000000000	9
1	1	RC13_REV	1.000000000000000000	9
1	1	RC13_TRIM	1500.000000000000000000	9
1	1	RC14_DZ	0.000000000000000000	9
1	1	RC14_MAX	2000.000000000000000000	9
1	1	RC14_MIN	1000.000000000000000000	9
1	1	RC14_REV	1.000000000000000000	9
1	1	RC14_TRIM	1500.000000000000000000	9
1	1	RC15_DZ	0.000000000000000000	9
1	1	RC15_MAX	2000.000000000000000000	9
1	1	RC15_MIN	1000.000000000000000000	9
1	1	RC15_REV	1.000000000000000000	9
1	1	RC15_TRIM	1500.000000000000000000	9
1	1	RC16_DZ	0.000000000000000000	9
1	1	RC16_MAX	2000.000000000000000000	9
1	1	RC16_MIN	1000.000000000000000000	9
1	1	RC16_REV	1.000000000000000000	9
1	1	RC16_TRIM	1500.000000000000000000	9
1	1	RC17_DZ	0.000000000000000000	9
1	1	RC17_MAX	2000.000000000000000000	9
1	1	RC17_MIN	1000.000000000000000000	9
1	1	RC17_REV	1.000000000000000000	9
1	1	RC17_TRIM	1500.000000000000000000	9
1	1	RC18_DZ	0.000000000000000000	9
1	1	RC18_MAX	2000.000000000000000000	9
1	1	RC18_MIN	1000.000000000000000000	9
1	1	RC18_REV	1.000000000000000000	9
1	1	RC18_TRIM	1500.000000000000000000	9
1	1	RC1_DZ	10.000000000000000000	9
1	1	RC1_MAX	2006.000000000000000000	9
1	1	RC1_MIN	982.000000000000000000	9
1	1	RC1_REV	1.000000000000000000	9
1	1	RC1_TRIM	1494.000000000000000000	9
1	1	RC2_DZ	10.000000000000000000	9
1	1	RC2_MAX	2006.000000000000000000	9
1	1	RC2_MIN	982.000000000000000000	9
1	1	RC2_REV	1.000000000000000000	9
1	1	RC2_TRIM	1495.000000000000000000	9
1	1	RC3_DZ	10.000000000000000000	9
1	1	RC3_MAX	2006.000000000000000000	9
1	1	RC3_MIN	984.000000000000000000	9
1	1	RC3_REV	1.000000000000000000	9
1	1	RC3_TRIM	984.000000000000000000	9
1	1	RC4_DZ	10.000000000000000000	9
1	1	RC4_MAX	2006.000000000000000000	9
1	1	RC4_MIN	982.000000000000000000	9
1	1	RC4_REV	1.000000000000000000	9
1	1	RC4_TRIM	1494.000000000000000000	9
1	1	RC5_DZ	10.000000000000000000	9
1	1	RC5_MAX	2006.000000000000000000	9
1	1	RC5_MIN	982.000000000000000000	9
1	1	RC5_REV	1.000000000000000000	9
1	1	RC5_TRIM	1494.000000000000000000	9
1	1	RC6_DZ	10.000000000000000000	9
1	1	RC6_MAX	2006.000000000000000000	9
1	1	RC6_MIN	982.000000000000000000	9
1	1	RC6_REV	1.000000000000000000	9
1	1	RC6_TRIM	1494.000000000000000000	9
1	1	RC7_DZ	10.000000000000000000	9
1	1	RC7_MAX	2006.000000000000000000	9
1	1	RC7_MIN	982.000000000000000000	9
1	1	RC7_REV	1.000000000000000000	9
1	1	RC7_TRIM	1494.000000000000000000	9
1	1	RC8_DZ	10.000000000000000000	9
1	1	RC8_MAX	2006.000000000000000000	9
1	1	RC8_MIN	982.000000000000000000	9
1	1	RC8_REV	1.000000000000000000	9
1	1	RC8_TRIM	1494.000000000000000000	9
1	1	RC9_DZ	0.000000000000000000	9
1	1	RC9_MAX	2006.000000000000000000	9
1	1	RC9_MIN	982.000000000000000000	9
1	1	RC9_REV	1.000000000000000000	9
1	1	RC9_TRIM	1494.000000000000000000	9
1	1	RC_ACRO_TH	0.750000000000000000	9
1	1	RC_ARMSWITCH_TH	0.750000000000000000	9
1	1	RC_ASSIST_TH	0.250000000000000000	9
1	1	RC_AUTO_TH	0.750000000000000000	9
1	1	RC_CHAN_CNT	18	6
1	1	RC_FAILS_THR	0	6
1	1	RC_GEAR_TH	0.750000000000000000	9
1	1	RC_KILLSWITCH_TH	0.750000000000000000	9
1	1	RC_LOITER_TH	0.750000000000000000	9
1	1	RC_MAN_TH	0.750000000000000000	9
1	1	RC_MAP_ACRO_SW	0	6
1	1	RC_MAP_ARM_SW	5	6
1	1	RC_MAP_AUX1	0	6
1	1	RC_MAP_AUX2	0	6
1	1	RC_MAP_AUX3	0	6
1	1	RC_MAP_AUX4	0	6
1	1	RC_MAP_AUX5	0	6
1	1	RC_MAP_AUX6	0	6
1	1	RC_MAP_FAILSAFE	0	6
1	1	RC_MAP_FLAPS	0	6
1	1	RC_MAP_FLTMODE	6	6
1	1	RC_MAP_GEAR_SW	0	6
1	1	RC_MAP_KILL_SW	7	6
1	1	RC_MAP_LOITER_SW	0	6
1	1	RC_MAP_MAN_SW	0	6
1	1	RC_MAP_MODE_SW	0	6
1	1	RC_MAP_OFFB_SW	0	6
1	1	RC_MAP_PARAM1	0	6
1	1	RC_MAP_PARAM2	0	6
1	1	RC_MAP_PARAM3	0	6
1	1	RC_MAP_PITCH	2	6
1	1	RC_MAP_POSCTL_SW	0	6
1	1	RC_MAP_RATT_SW	0	6
1	1	RC_MAP_RETURN_SW	0	6
1	1	RC_MAP_ROLL	1	6
1	1	RC_MAP_STAB_SW	0	6
1	1	RC_MAP_THROTTLE	3	6
1	1	RC_MAP_TRANS_SW	0	6
1	1	RC_MAP_YAW	4	6
1	1	RC_OFFB_TH	0.750000000000000000	9
1	1	RC_POSCTL_TH	0.750000000000000000	9
1	1	RC_RATT_TH	0.750000000000000000	9
1	1	RC_RETURN_TH	0.750000000000000000	9
1	1	RC_RSSI_PWM_CHAN	0	6
1	1	RC_RSSI_PWM_MAX	2000	6
1	1	RC_RSSI_PWM_MIN	1000	6
1	1	RC_STAB_TH	0.500000000000000000	9
1	1	RC_TRANS_TH	0.750000000000000000	9
1	1	RTL_CONE_ANG	45	6
1	1	RTL_DESCEND_ALT	10.000000000000000000	9
1	1	RTL_FLT_TIME	15.000000000000000000	9
1	1	RTL_LAND_DELAY	1.000000000000000000	9
1	1	RTL_MIN_DIST	10.000000000000000000	9
1	1	RTL_PLD_MD	0	6
1	1	RTL_RETURN_ALT	50.000000000000000000	9
1	1	RTL_TYPE	0	6
1	1	SDLOG_BOOT_BAT	0	6
1	1	SDLOG_DIRS_MAX	0	6
1	1	SDLOG_MISSION	0	6
1	1	SDLOG_PROFILE	1	6
1	1	SDLOG_UTC_OFFSET	0	6
1	1	SDLOG_UUID	1	6
1	1	SENS_BARO_QNH	1013.250000000000000000	9
1	1	SENS_BARO_RATE	20.000000000000000000	9
1	1	SENS_BOARD_ROT	0	6
1	1	SENS_BOARD_X_OFF	-0.337598025798797607	9
1	1	SENS_BOARD_Y_OFF	-2.207851886749267578	9
1	1	SENS_BOARD_Z_OFF	0.000000000000000000	9
1	1	SENS_DPRES_OFF	0.000000000000000000	9
1	1	SENS_EN_THERMAL	-1	6
1	1	SENS_FLOW_MAXHGT	3.000000000000000000	9
1	1	SENS_FLOW_MAXR	2.500000000000000000	9
1	1	SENS_FLOW_MINHGT	0.699999988079071045	9
1	1	SENS_FLOW_ROT	6	6
1	1	SENS_IMU_MODE	1	6
1	1	SYS_AUTOCONFIG	0	6
1	1	SYS_AUTOSTART	4001	6
1	1	SYS_CAL_TDEL	24	6
1	1	SYS_CAL_TMAX	10	6
1	1	SYS_CAL_TMIN	5	6
1	1	SYS_FAC_CAL_MODE	0	6
1	1	SYS_FAILURE_EN	0	6
1	1	SYS_HAS_BARO	1	6
1	1	SYS_HAS_MAG	0	6
1	1	SYS_HITL	0	6
1	1	SYS_MC_EST_GROUP	2	6
1	1	SYS_PARAM_VER	1	6
1	1	SYS_RESTART_TYPE	0	6
1	1	THR_MDL_FAC	0.000000000000000000	9
1	1	TRIG_MODE	0	6
1	1	TRIM_PITCH	0.000000000000000000	9
1	1	TRIM_ROLL	0.000000000000000000	9
1	1	TRIM_YAW	0.000000000000000000	9
1	1	UART_ESC_BAUD	250000	6
1	1	UART_ESC_CONFIG	1	6
1	1	UART_ESC_MODE	0	6
1	1	UART_ESC_MOTOR1	3	6
1	1	UART_ESC_MOTOR2	2	6
1	1	UART_ESC_MOTOR3	4	6
1	1	UART_ESC_MOTOR4	1	6
1	1	UART_ESC_RPM_MAX	10500	6
1	1	UART_ESC_RPM_MIN	1000	6
1	1	UART_ESC_T_COSP	0.990000009536743164	9
1	1	UART_ESC_T_DEAD	20	6
1	1	UART_ESC_T_EXPO	35	6
1	1	UART_ESC_T_MINF	0.150000005960464478	9
1	1	UART_ESC_T_PERC	90	6
1	1	UAVCAN_ENABLE	0	6
1	1	VOXLPM_SHUNT_BAT	0.000630000024102628	9
1	1	VT_B_DEC_MSS	2.000000000000000000	9
1	1	VT_B_REV_DEL	0.000000000000000000	9
1	1	WV_EN	0	6
]]></description><link>https://forum.modalai.com/topic/1440/pid-parameters-for-f-450</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Mar 2026 19:20:01 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1440.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Oct 2022 10:44:29 GMT</pubDate><ttl>60</ttl></channel></rss>
