<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VOXL 2 CAMERA CONNECTION]]></title><description><![CDATA[<p dir="auto">Hello Team,<br />
We are using VOXL2 for one of our project and we are planning to connect Camera module OV09282 directly to the camera connector. Actually it need some power up sequencing. I want to know that is that ok to connect the omni vision OV09282 directly to the cam connector? ,is VOXL2 support the  power up sequencing for OV09282 ?</p>
]]></description><link>https://forum.modalai.com/topic/1408/voxl-2-camera-connection</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 09:32:39 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1408.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Sep 2022 09:21:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to VOXL 2 CAMERA CONNECTION on Fri, 30 Sep 2022 15:07:00 GMT]]></title><description><![CDATA[<p dir="auto">HI <a class="plugin-mentions-user plugin-mentions-a" href="/user/akhil-raj" aria-label="Profile: Akhil-Raj">@<bdi>Akhil-Raj</bdi></a> ,<br />
We might be OK with the sequencing.<br />
All OVT's specs are shared under NDA, so we do not have access to every sensor spec sheet that they make.<br />
However, it should be OK if you can share the one chart of power up sequence requirements, and I can check our design to flag any issues or concerns. Most sensors have "no required sequence" such as the OV9782 Chad mentioned, and we have only come across 2 or 3 in our history that care about it, but I like to check.<br />
So, let me know if you can re-post that data in whatever format is easy for you (screen shot, re-type, etc) But be sure to respect your NDA with OVT.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.modalai.com/post/6563</link><guid isPermaLink="true">https://forum.modalai.com/post/6563</guid><dc:creator><![CDATA[Vinny]]></dc:creator><pubDate>Fri, 30 Sep 2022 15:07:00 GMT</pubDate></item><item><title><![CDATA[Reply to VOXL 2 CAMERA CONNECTION on Fri, 30 Sep 2022 14:00:03 GMT]]></title><description><![CDATA[<p dir="auto">The OV9282 driver is supported. I'm not sure what power up sequencing means.</p>
<p dir="auto">Can you use OV9782 (RGB)? We have an OV9782 module for VOXL 2</p>
]]></description><link>https://forum.modalai.com/post/6557</link><guid isPermaLink="true">https://forum.modalai.com/post/6557</guid><dc:creator><![CDATA[Chad Sweet]]></dc:creator><pubDate>Fri, 30 Sep 2022 14:00:03 GMT</pubDate></item></channel></rss>
