<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[5G expansion board Peripherals]]></title><description><![CDATA[<p dir="auto">Is the 5G M2 slot capable of hosting a WiFi card? Is there plans to support a particular card in the future rather than running a USB Dongle?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.modalai.com/topic/1308/5g-expansion-board-peripherals</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Nov 2026 17:03:48 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1308.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 08 Sep 2022 16:22:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 5G expansion board Peripherals on Mon, 24 Oct 2022 16:47:04 GMT]]></title><description><![CDATA[<p dir="auto">Moved to <a href="https://forum.modalai.com/topic/1481/5g-add-on-board-accessing-the-quectel-module-linux-shell">https://forum.modalai.com/topic/1481/5g-add-on-board-accessing-the-quectel-module-linux-shell</a></p>
]]></description><link>https://forum.modalai.com/post/6901</link><guid isPermaLink="true">https://forum.modalai.com/post/6901</guid><dc:creator><![CDATA[Mark Lee]]></dc:creator><pubDate>Mon, 24 Oct 2022 16:47:04 GMT</pubDate></item><item><title><![CDATA[Reply to 5G expansion board Peripherals on Sat, 22 Oct 2022 21:55:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mark-lee" aria-label="Profile: Mark-Lee">@<bdi>Mark-Lee</bdi></a> Hi Mark,<br />
Can you please start a fresh thread for this topic?<br />
I have some comments, but want to be sure they are under an aptly named title so others can find it if they have similar questions.<br />
Feel free to tag me in the post so I get notified.<br />
Thanks!</p>
]]></description><link>https://forum.modalai.com/post/6881</link><guid isPermaLink="true">https://forum.modalai.com/post/6881</guid><dc:creator><![CDATA[Vinny]]></dc:creator><pubDate>Sat, 22 Oct 2022 21:55:09 GMT</pubDate></item><item><title><![CDATA[Reply to 5G expansion board Peripherals on Thu, 20 Oct 2022 22:37:50 GMT]]></title><description><![CDATA[<p dir="auto">I have a 5G Add on board (MSA-M0090-3-01-01) with a Quectel M.2 (RM502Q-AE) module connected to the VOXL 2 board.  I can access the VOXL Linux shell with ADB to the VOXL2 USB-C connector.  Is there a way to connect to the Linux LE shell on the RM502Q-AE module?</p>
]]></description><link>https://forum.modalai.com/post/6864</link><guid isPermaLink="true">https://forum.modalai.com/post/6864</guid><dc:creator><![CDATA[Mark Lee]]></dc:creator><pubDate>Thu, 20 Oct 2022 22:37:50 GMT</pubDate></item><item><title><![CDATA[Reply to 5G expansion board Peripherals on Fri, 09 Sep 2022 05:27:38 GMT]]></title><description><![CDATA[<p dir="auto">@daniel-p-nikolov Hi,<br />
Our 5G modem board has an M.2 "B" key connector typical of modem plug-in cards.<br />
If you have a specific WiFi M.2 module in mind, please share the part number and I can investigate if it is an electro-mechanical fit with our B-key socket.<br />
<a href="https://en.wikipedia.org/wiki/M.2" rel="nofollow ugc">https://en.wikipedia.org/wiki/M.2</a><br />
Most likely I suspect the WiFi module falls under the "socket 1" option which will use A or E keying and may not be compatable.</p>
<p dir="auto">That said, I cannot speak to the SW drivers, since the device needs to have a Linux driver for it, and it may or may not be already in the platform.<br />
However, let's not even ask our SW team if your desired module can't plug in.</p>
<p dir="auto">Regarding WiFi support of dongles, believe it or not, many customers do not want WiFi (and want it disabled on Voxl or VoxlFlight), hence why we default removed it from Voxl2. So, we thought this was the best compromise instead of adding cost to every single PCB. We may add more support in the future, but our focus has been NDAA capable modules.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.modalai.com/post/6185</link><guid isPermaLink="true">https://forum.modalai.com/post/6185</guid><dc:creator><![CDATA[Vinny]]></dc:creator><pubDate>Fri, 09 Sep 2022 05:27:38 GMT</pubDate></item></channel></rss>
