<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[hires camera crashes camera server]]></title><description><![CDATA[<p dir="auto">I was working on streaming the hires camera frames to ROS and i noticed that whenever i try to read from the hires pipe, the camera server crashes. I have identified the following</p>
<ol>
<li>
<p dir="auto">I dont think its a hardware issue as i tried connecting my board with a brand new camera without any flex cable extension and the issue persists. I am also facing this problem with 3 other boards</p>
</li>
<li>
<p dir="auto">When the camera server is started, i get a few seconds worth of frames and then the crash happens. If I have the voxl portal open with the option to view the hires selected and then start the camera server i can see the camera frames for a few seconds and then it freezes. While the camera server is frozen, I see the stream from the tracking and stereo seem fine for a few more seconds after which all camera streams stop and the camera server crashes</p>
</li>
<li>
<p dir="auto">The error seen is -19 which can be seen by starting the camera server using -d 0 parameter and when checking the journalctl for the camera server i see the following<br />
Sep 05 22:24:10 voxl6 bash[2117]: Segmentation fault:<br />
Sep 05 22:24:10 voxl6 bash[2117]: Fault thread: CAM_METADATA(tid: 3214)<br />
Sep 05 22:24:10 voxl6 bash[2117]: Fault address: 0x581<br />
Sep 05 22:24:10 voxl6 bash[2117]: Unknown reason</p>
</li>
<li>
<p dir="auto">I have also tried updating to the latest firmware v3.8.0-0.7</p>
</li>
<li>
<p dir="auto">I tried multiple resolution configuration (640x480, 1280x720, 1920x1080 and 4000x3000)</p>
</li>
</ol>
<p dir="auto">If anyone can help me out, that would be appreciated</p>
<p dir="auto">Regards<br />
Vivek</p>
]]></description><link>https://forum.modalai.com/topic/1295/hires-camera-crashes-camera-server</link><generator>RSS for Node</generator><lastBuildDate>Sat, 08 Aug 2026 10:39:55 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1295.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 05 Sep 2022 23:01:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to hires camera crashes camera server on Sun, 11 Sep 2022 20:39:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vivek-rk" aria-label="Profile: vivek-rk">@<bdi>vivek-rk</bdi></a> For anyone looking for a quick fix, you can use the voxl rtsp server for the hires only, for MPA support use the add-mpa-support branch</p>
]]></description><link>https://forum.modalai.com/post/6206</link><guid isPermaLink="true">https://forum.modalai.com/post/6206</guid><dc:creator><![CDATA[vivek rk]]></dc:creator><pubDate>Sun, 11 Sep 2022 20:39:28 GMT</pubDate></item></channel></rss>
