<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error starting camera: tof]]></title><description><![CDATA[<p dir="auto">@Alex-Gardner<br />
Hi,</p>
<p dir="auto">I am getting an error while running voxl-camera-server it's not getting connected to TOF camera, the output is shown below.</p>
<pre><code>voxl:/$ voxl-camera-server
WARNING Failed to set priority, errno = 1
This may be because the FIFO scheduler is not available when running in a console.
It should work properly when run as a systemd background process on boot.
WARNING: failed to set scheduler
------ voxl-camera-server: Starting camera server
	Started Camera: tracking
	Started Camera: stereo
ERROR: Invalid Preview Format!
Encountered error starting camera: tof, exiting
	Stopped Camera: tracking
	Stopped Camera: stereo
<p dir="auto">can you tell me how to resolve this issue. below I have also attached voxl-camera-server.conf file.</p>
<pre><code>voxl:/$ cat /etc/modalai/voxl-camera-server.conf
	"version":	0.1,
	"cameras":	[{
			"name":	"tracking",
			"enabled":	true,
			"frame_rate":	30,
			"type":	"ov7251",
			"camera_id":	1,
			"ae_desired_msv":	60,
			"ae_exposure_period":	1,
			"ae_gain_period":	1
			"name":	"stereo",
			"enabled":	true,
			"frame_rate":	30,
			"type":	"ov7251",
			"camera_id":	2,
			"camera_id_second":	3,
			"ae_gain_period":	1
			"name":	"tof",
			"enabled":	true,
			"frame_rate":	-1,
			"type":	"pmd-tof",
			"camera_id":	0
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.modalai.com/topic/1293/error-starting-camera-tof</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 16:10:34 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1293.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 05 Sep 2022 18:50:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error starting camera: tof on Tue, 06 Sep 2022 17:22:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi @Alex-Gardner,</p>
<p dir="auto">The problem is solved and TOF camera is working fine now, previously I have flashed voxl system image 3.8 and now I have again re-flashed it with 3.3 system image.</p>
<p dir="auto">Thanks for your input!</p>
]]></description><link>https://forum.modalai.com/post/6114</link><guid isPermaLink="true">https://forum.modalai.com/post/6114</guid><dc:creator><![CDATA[Anubhav]]></dc:creator><pubDate>Tue, 06 Sep 2022 17:22:22 GMT</pubDate></item><item><title><![CDATA[Reply to Error starting camera: tof on Tue, 06 Sep 2022 16:30:45 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">It looks like you're running a version of camera server that doesn't yet support tof. We did a major refactor of camera server a few months ago and are finally merging tof support back into the mainline. How did you install this version? The complied versions shouldn't be available on any of our non-beta repos.</p>
]]></description><link>https://forum.modalai.com/post/6106</link><guid isPermaLink="true">https://forum.modalai.com/post/6106</guid><dc:creator><![CDATA[[[global:former_user]]]]></dc:creator><pubDate>Tue, 06 Sep 2022 16:30:45 GMT</pubDate></item></channel></rss>
