<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[m500 motor replacement]]></title><description><![CDATA[<p dir="auto">Hi team,<br />
Since my m500 motors got issues, I replaced all of them with the latest Holybro version <a href="https://shop.holybro.com/spare-parts-s500-v2-kit_p1251.html" rel="nofollow ugc">https://shop.holybro.com/spare-parts-s500-v2-kit_p1251.html</a>.</p>
<p dir="auto">It seems Holybro update the motors with a higher 920kv value. I am wondering if I need to modify any configuration for the changes in VOXL or will they work fine by just plug-and-play?</p>
<p dir="auto">Also, should I do any ESC calibration or PWM connector checking after replacement? Do you have any calibration tools for motor checking in VOXL or it could be done via QGC?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.modalai.com/topic/1240/m500-motor-replacement</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 14:50:42 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1240.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 24 Aug 2022 15:30:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to m500 motor replacement on Wed, 11 Jan 2023 16:08:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/560">@yu-zhang</a> Hi! I got quite confuse with this topic but, I would like to know. Did it work using the new Holybro motors with 920kv? I guess all the answers from Adrian were to get to make them work.</p>
<p dir="auto">I ask because it has been difficult to find the motors I need for the m500.</p>
<p dir="auto">Regards.</p>
]]></description><link>https://forum.modalai.com/post/7808</link><guid isPermaLink="true">https://forum.modalai.com/post/7808</guid><dc:creator><![CDATA[Juan de Dios Oseas Gutiérrez Ortiz]]></dc:creator><pubDate>Wed, 11 Jan 2023 16:08:25 GMT</pubDate></item><item><title><![CDATA[Reply to m500 motor replacement on Wed, 31 Aug 2022 03:07:36 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/277">@Adrian-Hidalgo</a>, I finally realized why the issue happened.</p>
<p dir="auto">I put a wrong wire connection between the CW pair with the esc connectors under the wings.</p>
<p dir="auto"><img src="/assets/uploads/files/1661914942171-screen-shot-2022-08-31-at-1.00.25-pm.png" alt="Screen Shot 2022-08-31 at 1.00.25 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I used to connect the red wire to match the red connector of esc for all motors. That's why all motors spin in the same direction.</p>
<p dir="auto">So, after checking one of old pictures I took for m500, I found both red and black wires should be reversely connected to the side of esc for the CW pair (3, 4). And the shaking issue is gone after this.</p>
<p dir="auto">I didn't realize this detail before. All right, everything works well now. Thanks again for your help! <img src="https://forum.modalai.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60a.png?v=r4gp3i66d9g" class="not-responsive emoji emoji-android emoji--blush" title=":blush:" alt="😊" /></p>
]]></description><link>https://forum.modalai.com/post/5915</link><guid isPermaLink="true">https://forum.modalai.com/post/5915</guid><dc:creator><![CDATA[yu zhang]]></dc:creator><pubDate>Wed, 31 Aug 2022 03:07:36 GMT</pubDate></item><item><title><![CDATA[Reply to m500 motor replacement on Tue, 30 Aug 2022 06:02:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/277">@Adrian-Hidalgo</a> Thanks!</p>
<p dir="auto">After checking, I found that all 4 motors spin in the same direction as below shown:</p>
<p dir="auto"><img src="/assets/uploads/files/1661838940405-screen-shot-2022-08-30-at-3.53.55-pm.png" alt="Screen Shot 2022-08-30 at 3.53.55 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The issue is that the 3 and 4 motors spin in the wrong direction. And I double-checked the PWN breakout as below:</p>
<p dir="auto"><img src="/assets/uploads/files/1661839006052-screen-shot-2022-08-30-at-3.54.11-pm.png" alt="Screen Shot 2022-08-30 at 3.54.11 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">It seems I line up with the correct connection, right? E.g., from left to right, it shows 1, 2, 3, 4 connections with each motor. So, should the yellow wire be vertically above the black wire for each one? It should something wrong with the 3 and 4 connection, should I put it as 1, 2, 4,3?</p>
]]></description><link>https://forum.modalai.com/post/5882</link><guid isPermaLink="true">https://forum.modalai.com/post/5882</guid><dc:creator><![CDATA[yu zhang]]></dc:creator><pubDate>Tue, 30 Aug 2022 06:02:59 GMT</pubDate></item><item><title><![CDATA[Reply to m500 motor replacement on Mon, 29 Aug 2022 19:10:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/560">@yu-zhang</a> the first thing I'd look at would be if all the motors are spinning the correct way. It should look like the image where the white tip motors are the counter-clock-wise &amp; black tip motors are clock-wise:<br />
<img src="/assets/uploads/files/1661796280642-4521d87b-9e07-4e82-954f-14407926e94f-image.png" alt="4521d87b-9e07-4e82-954f-14407926e94f-image.png" class=" img-fluid img-markdown" /><br />
You have two options to check spin direction, both require you to take the props off.<br />
1: arm the drone &amp; carefully touch the motor to verify spin<br />
or<br />
2: connect to QGC, go to MavLink console, &amp; type</p>
<pre><code>motor_test test -m 0 -p 15
# m reflects motor selection, start with 0, 1, 2, 3
<p dir="auto">&amp; to stop the spin, type:</p>
<pre><code>motor_test stop
<p dir="auto">If motor is spinning opposite direction then flip any two motor wires.</p>
<p dir="auto">After checking the correct spin direction, verify that each motor that spins follows like the image above.<br />
With the drone matching the above image, front of the drone facing away from you, motor one should be front right, motor two should be bottom left, motor three top left and motor four should be bottom right.<br />
If it doesn't match, change the esc wire from the breakout board. There are numbers on it &amp; should line up with correct esc.</p>
]]></description><link>https://forum.modalai.com/post/5868</link><guid isPermaLink="true">https://forum.modalai.com/post/5868</guid><dc:creator><![CDATA[Adrian Hidalgo]]></dc:creator><pubDate>Mon, 29 Aug 2022 19:10:31 GMT</pubDate></item><item><title><![CDATA[Reply to m500 motor replacement on Sun, 28 Aug 2022 09:15:55 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/277">@Adrian-Hidalgo</a>, could you please advise about this issue? Many thanks.</p>
]]></description><link>https://forum.modalai.com/post/5815</link><guid isPermaLink="true">https://forum.modalai.com/post/5815</guid><dc:creator><![CDATA[yu zhang]]></dc:creator><pubDate>Sun, 28 Aug 2022 09:15:55 GMT</pubDate></item><item><title><![CDATA[Reply to m500 motor replacement on Thu, 25 Aug 2022 12:15:00 GMT]]></title><description><![CDATA[<p dir="auto">I tried to fly with indoor settings, but it seems m500 cannot take off even I used max thrust. Please double-check the below video:<br />
<a href="https://youtube.com/shorts/-aKPTE524uI?feature=share" rel="nofollow ugc">https://youtube.com/shorts/-aKPTE524uI?feature=share</a></p>
<p dir="auto">The story was that I got a crash last month. The frame broke and 2 of motors (CW pairs) were damaged. Please refer my previous post: <a href="https://forum.modalai.com/topic/1101/m500-motor-hot-and-vibration/7?_=1657365823867">https://forum.modalai.com/topic/1101/m500-motor-hot-and-vibration/7?_=1657365823867</a></p>
<p dir="auto">The damaged motors lead to noisy sounds and jerking. So, I found the above 920kv version by Holybro. After the replacement, the jerking issue is almost gone, but it slightly remains when taking off and landing. The main issue is that m500 cannot take off, and it seems some calibration process is missing. Also, I found that m500 will shaking a bit with a higher thrust (low thrust is fine), please check this video:<br />
<a href="https://youtube.com/shorts/6QrPMKwoohY" rel="nofollow ugc">https://youtube.com/shorts/6QrPMKwoohY</a></p>
<p dir="auto">Please advise what I should do to fix it. Thanks.</p>
]]></description><link>https://forum.modalai.com/post/5776</link><guid isPermaLink="true">https://forum.modalai.com/post/5776</guid><dc:creator><![CDATA[yu zhang]]></dc:creator><pubDate>Thu, 25 Aug 2022 12:15:00 GMT</pubDate></item></channel></rss>
