<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Missing sensor-imu]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I was testing out how to build ros nodes within voxl-emulator and following instructions from the README on this page:<br />
<a href="https://gitlab.com/voxl-public/ros/voxl-nodes" rel="nofollow ugc">https://gitlab.com/voxl-public/ros/voxl-nodes</a></p>
<p dir="auto">When running <code>./build.sh</code>, the compilation fails with <code>fatal error: sensor-imu/sensor_imu_api.h: No such file or directory</code>. I am using voxl-emulator v1.4. How can I obtain the package?</p>
]]></description><link>https://forum.modalai.com/topic/124/missing-sensor-imu</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 13:37:29 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/124.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 03 Feb 2021 19:08:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Missing sensor-imu on Fri, 05 Feb 2021 18:04:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chad-sweet" aria-label="Profile: Chad-Sweet">@<bdi>Chad-Sweet</bdi></a><br />
This works, thanks. When will this be fixed?</p>
]]></description><link>https://forum.modalai.com/post/536</link><guid isPermaLink="true">https://forum.modalai.com/post/536</guid><dc:creator><![CDATA[ray tsou]]></dc:creator><pubDate>Fri, 05 Feb 2021 18:04:34 GMT</pubDate></item><item><title><![CDATA[Reply to Missing sensor-imu on Thu, 04 Feb 2021 18:04:27 GMT]]></title><description><![CDATA[<p dir="auto">As a workaround, can you please try this?</p>
<ol>
<li>In voxl-emulator, edit /etc/opkg/opkg.conf and add the following line to the end of the file: "src/gz stable <a href="http://voxl-packages.modalai.com/stable" rel="nofollow ugc">http://voxl-packages.modalai.com/stable</a>".</li>
<li>Then run: sudo opkg update</li>
<li>Then run: sudo opkg install imu_app</li>
<li>Finally: ./build.sh</li>
</ol>
<p dir="auto">It seems there is some incompatibility with our v1.4 emulator that needs to be fixed</p>
]]></description><link>https://forum.modalai.com/post/531</link><guid isPermaLink="true">https://forum.modalai.com/post/531</guid><dc:creator><![CDATA[Chad Sweet]]></dc:creator><pubDate>Thu, 04 Feb 2021 18:04:27 GMT</pubDate></item><item><title><![CDATA[Reply to Missing sensor-imu on Thu, 04 Feb 2021 06:04:53 GMT]]></title><description><![CDATA[<p dir="auto">I can repeat this error, will look into it. Thanks for reporting.</p>
]]></description><link>https://forum.modalai.com/post/530</link><guid isPermaLink="true">https://forum.modalai.com/post/530</guid><dc:creator><![CDATA[Chad Sweet]]></dc:creator><pubDate>Thu, 04 Feb 2021 06:04:53 GMT</pubDate></item></channel></rss>
