<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ZMQ library]]></title><description><![CDATA[<p dir="auto">Is there an existing package to get ZMQ (c++ binding) available on the platform ?</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://forum.modalai.com/topic/1114/zmq-library</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Apr 2026 20:28:46 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1114.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 12 Jul 2022 19:14:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ZMQ library on Thu, 21 Jul 2022 18:34:33 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Steve,</p>
<p dir="auto">I went to compile the source code with  the voxl emulator and it compiled without issues.</p>
]]></description><link>https://forum.modalai.com/post/5272</link><guid isPermaLink="true">https://forum.modalai.com/post/5272</guid><dc:creator><![CDATA[Chris P]]></dc:creator><pubDate>Thu, 21 Jul 2022 18:34:33 GMT</pubDate></item><item><title><![CDATA[Reply to ZMQ library on Wed, 20 Jul 2022 05:11:34 GMT]]></title><description><![CDATA[<p dir="auto">I'm not aware of anything specifically for the VOXL 1 that would run right on the device other than compiling your own in one of the <a href="https://docs.modalai.com/build-environments/" rel="nofollow ugc">VOXL docker images</a>.</p>
<p dir="auto">You could try <a href="https://github.com/ASMfreaK/zeromq-openwrt" rel="nofollow ugc">https://github.com/ASMfreaK/zeromq-openwrt</a> since ZMQ is available for OpenWRT (which also uses the same package manager since it is based on Yocto Linux). ZMQ is fairly portable as well and should run under <code>aarch64</code>.</p>
<p dir="auto">The other option is to run a bridge from any MPA/ROS topics to <a href="https://docs.modalai.com/docker-on-voxl/" rel="nofollow ugc">ZMQ in a container</a>.</p>
<p dir="auto">If VOXL2, I would imagine it will work out of the box since that runs Ubuntu natively.</p>
]]></description><link>https://forum.modalai.com/post/5245</link><guid isPermaLink="true">https://forum.modalai.com/post/5245</guid><dc:creator><![CDATA[Steve Turner]]></dc:creator><pubDate>Wed, 20 Jul 2022 05:11:34 GMT</pubDate></item></channel></rss>
