<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Avoidance]]></title><description><![CDATA[<p dir="auto">I'm not able to activate flight mode on QCG. The error message is saying: Avoidance System not ready.<br />
The Not Ready error message shows GPS is disabled, Gyro 2 is disabled, and Accelerometer 2 is disabled.<br />
Do I need these enabled for flight mode?<br />
If so, how do I enable them?</p>
]]></description><link>https://forum.modalai.com/topic/1087/avoidance</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Nov 2026 22:13:44 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1087.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 05 Jul 2022 19:08:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Avoidance on Tue, 26 May 2026 15:46:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ward-javoronok" aria-label="Profile: Ward-Javoronok">@<bdi>Ward-Javoronok</bdi></a> How is the parameter COM_OBS_AVOID set? If you set it to 0 that disables obstacle avoidance and should get rid of that error.</p>
]]></description><link>https://forum.modalai.com/post/25929</link><guid isPermaLink="true">https://forum.modalai.com/post/25929</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Tue, 26 May 2026 15:46:37 GMT</pubDate></item><item><title><![CDATA[Reply to Avoidance on Tue, 26 May 2026 06:09:27 GMT]]></title><description><![CDATA[<p dir="auto">You might also want to look into combining depth sensing with a simple occupancy grid or voxel map instead of relying only on direct obstacle detection. It usually gives smoother avoidance behavior, especially in tighter spaces. I had better results once I started filtering noisy sensor data too.</p>
]]></description><link>https://forum.modalai.com/post/25926</link><guid isPermaLink="true">https://forum.modalai.com/post/25926</guid><dc:creator><![CDATA[kailyGen]]></dc:creator><pubDate>Tue, 26 May 2026 06:09:27 GMT</pubDate></item></channel></rss>
